Question about Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190
I recieved a replacement inducer blower for a trane HVAC (gas) unit. The new blower has 3 wires plus ground (red,white,black). Apparently this is a 2 speed motor. Can I use this motor somehow. It is getting very cold after 2 days of waiting for the part.
3 Suggested Answers
  • 2692 Answers
SOURCE: Draft inducer blower going bad
I agree close enough. Only slightly slower. If it fits mechanically , useit.
Posted on Jan 17, 2009
  • 9 Answers
SOURCE: i have a trane furnace that is between 10-20 years
dodgy relay possibly
Posted on Mar 06, 2010
HVAC Problem: Trane 1400XL furnace 'microcycling' every minute. blower 25s on, 10s off
Check the fan relay, the limit switches(Klixons) on the heat exchanger and the electronics that control the fan relay.
Oct 30, 2017 | Heating & Cooling
Replacing home a/c blower motor the unit has black and white wires my new motoe has blue lack red and yellow wres How do i wi it?
DO YOU HAVE A WIRING DIAGRAM OF THE NEW MOTOR? TYPICALLY NEW MOTOR WILL HAVE OPTION FOR MULTIPLE SPEED MOTORS.
WIRES ON UNIT NEW MOTOR
WHITE.............................NEUTRAL.........WHITE
BLACK ...........................HOT...................RED=LOW
OPTION 2 YELLOW=MED/LOW
OPTION 3 BLUE=MED/HI
OPTION 4 BLACK=HI
Dec 09, 2014 | Heating & Cooling
I have a Trane gas furnace with White Rodgers 50A50-474 board is flashing a 2 flash code which is a system lockout-no flame/Check line polarity message. The furnace blower contines to run, but the gas...
Sounds like your ignitor is bad, not lighting the gas. If this happens 3x, then controler goes into lockout and induced draft motor continues to run to extract the gas fumes as a safety.
Either replace the HSI (Hot Surface Ignitor) or sand down the end of the electronic spark ignitor and it's ground rod (they work like an exposed spark plug) to remove the carbon buildup on it so it can spark again. All with the power off, of course!
If you need more help, please ask, I'm glad to help! 25 year HVAC service Tech- residential & commercial systems.
Apr 05, 2013 | Heating & Cooling
Leviton three way has two red, one black plus ground. Old switch one each,white,black red. What goes where.
Typically in three way residential switching the Red and White are used as travelers from 3 way to 3 way. That in mind, connect the black to black, red to one red and the other red to the white. mark the white wire with black tape.
Mar 04, 2013 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Furnace won't stay lit
Are your air filters relatively new? Is a bird nesting in your units combustion air exhaust pipe? Does your draft inducer motor run before and after the gas has ignited? Check and confirm these 3 things first. Good Luck!
Mar 03, 2013 | Omega Trane Furnace Draft Inducer Blower...
Helping a friend install a new unit... he has 3 wires where we took out the old unit (the old unit had 4 wires) .. the (source) 3 wire is black, white & bare.... the old and new unit have black, red,...
I suspect on teh wiring from the house the black&white will be the hot wires and the bare will be ground/neutral
use a volt meter before connecting tonew cooktop and check for;
black/bare to have 120volts
white/bare to have 120volts
if that is what you find...connect new cooktop as such;
black to black
red to (house) white
(cooktop) white and green to bare
GENE
Sep 07, 2011 | Whirlpool GJC3034 Electric Cooktop
HVAC Blower Motor Replacement
Ain't nothing to it. Slide out the blower and take it outside. Use some rust buster to get the blower out. Don't beat on the shaft. Spread that shaft and the wheel won't come off. Use a rubber mallet. Most generic blowers have white as a common wire and the speeds are black-hi blue med and red, for low. 2 brown wires will go to the capacitor. other wires will reverse direction. Wash the housing and blower wheel good. any wire unused will be taped off to themselves. Nothing to it.
Mar 11, 2010 | Carrier 38CKC042 Air Conditioner
What wires go to what when replacing a inducer. the man cut the wires instead of taking it off right. the new inducer has different colored wires. two orange,one with stripe and a black wire which is a...
I would get an electrician or an HVAC tech to hook up this unit ,you do not want to get electricuted or blow up the unit it will cost you more to replace the unit if you blow it up that to get the proper person. REMEMBER SAFETY FIRST.
Mar 02, 2009 | Weather King 10AJA3601AH Air Conditioner
Trying to install 3 way cord with a 4 way replacement cord. I have disconnected all wires and put them back. My question is concerning the white wire.The wires that are already connected to the dryer red,...
In a three wire system you have 2 hot wires (black and red) and a neutral (white). the ground is connected to the neutral at the dryer. In a 4 wire system you have the 2 hot wires, neutral, and a ground. (green). The ground is connected with the neutral at the circuit panel. The hot wires at the dryer should be on the outside scres, the neutral should be in the center and the ground should be under the green screw. *****. .
Sep 23, 2008 | Dryers
Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190 Logo
53 people viewed this question
Top Omega Tools & Hardware - Others Experts
yoopertech
Terry Hair
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
