Question about Dryers
Electrician confirmed there's any internal ground short in dryer. Admiral (by Whirlpool) model AED7000AYW electric dryer.
Replaced both thermal fuses, but not broken door switch & dryer used for a month or two using the timer control switch to stop dryer spinning. Just replaced the door switch, timer control switch & circuit breaker in main fuse panel. Electrician confirmed there's any internal ground short in dryer. Admiral (by Whirlpool) model AED7000AYW electric dryer.
Oceti
  • 51 Answers
SOURCE: DRYER
The thermal cut-out is located on the side of the heater housing assm. To gain access you need to use a putty knife to depress the two spring clips between the top and the front panel and raise the top. The heater is on the back wall. The part number for the t-stat and thermal cut-out kit is LA-1053 and is about $20.00. Don't forget to clean your vent, and check your blower assm. Either one could have caused the problem.
Posted on Jan 10, 2008
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
docjohn174
  • 943 Answers
SOURCE: Admiral Capacity Plus Dryer won't
hi yes there is a thermal fuse in the dryer at the back on the air duct a small plastic piece with 2 small blue wires check that also door switch thanks the appliance doc
Posted on Sep 22, 2008
Excellency
  • 20 Answers
SOURCE: Dryer won't start
Thermal fuse is your most likely suspect LA 1053
Posted on Dec 10, 2008
  • 172 Answers
SOURCE: control panel looks ok but dryer wont start
Sounds like an electronic problem on the timer circuit board.
Posted on Aug 12, 2009
I have a Whirlpool electric dryer M/ WEP5300o that will not heat. I have replaced the Cycling Thermostat, High limit thermostat, Thermal fuse and heating element. It still doesn't heat. There are
If you have fuses on your electric panel it normally uses 2 fuses, 1 for electric power 1 for heat. The same may be true on the circuit board panel check this to eliminate this possibility
Feb 02, 2013 | Whirlpool Dryers
My fisher & paykel model ad39 dryer has stopped working
Always unplug the appliance before working on it.
I would suggest checking the circuit breaker in the breaker box for your apartment, to see if it has tripped. You have probably already done this, but try to reset (open all the way and then close) the circuit breaker. Plug the power cord in again and try to operate the dryer.
If it trips the circuit breaker again, there is a short circuit or a ground, and you should unplug the machine and diagnose the problem. 240 volts AC, when shorted or grounded can start fires or kill people.
Many Dryers are equipped with a "non-resettable thermal fuse". When the air being blown through the dryer gets too hot, this thing melts and opens up the entire power circuit.The dyer doesn't do anything, as if it had no power.
This non-resettable thermal fuse can usually be purchased from the manufacturer or a good appliance supply store, and comes in a kit which also includes a new thermostat, to replace the one that probably failed and overheated the machine to start with.
Get a friend who is an Electrician to help you if you are at all unsure of replacing parts in your power circuit. Be sure to unplug the machine / use a VOM to check it dead before you touch anything electrical. BE SAFE. 240 Volts AC is not just playing around.
Oct 06, 2012 | Dryers
Amana electric dryer LE8317W2 tripped circuit breaker. Orange wire fried at end by heat element and was off terminal end. Also the purple wire was fried at thermostat end. I cleaned up connections and...
These units are totally repairable and will run for ever. Need to assume that other damage has occurred as a result of the failed shorted terminal connections.
Possible that the circuit breaker is defective caused by the dryer failure.
Assume that one of the components has shorted to the grounded frame of the dryer.
The 11 ohms of the heater is about right.
Confirm that heater element is not shorted to the dryer frame (heater housing)! This condition would have caused the initial wire terminals to fail and now trip the circuit breaker!
Use an ohm meter and check resistance between hot leads on back of dryer. Check resistance between each hot and neutral.
There is a switch located on the motor that connects power to the heater. When the motor is running the centrifugal switch closes. This saftey circuit confirms that the blower is running before heat is turned on. Check that the switch is not damaged from prior terminal short circuit failure, Repair kit is p/n WPL-501218
Timer is the next check. Same thing confirm that no damage to the switch circuits has occured. Last check thermal fuses and thermostars for short to netural.
Hope this helps?
Jun 25, 2017 | Amana ALE643RB Electric Dryer
Where are fuses located on Whirlpool electric dryer?
Check the internal thermal fuse, which is located within the back panel. The fuse is about an inch long and oval-shaped.
If your dryer is not getting hot, the thermal fuse may be blown. Instead of calling an expensive repairman, you can replace this simple part yourself in less than an hour. Make sure you purchase the correct replacement fuse for your make and model of dryer. Your owner's manual should have a list of compatible part numbers. You may also be able to order a replacement directly from your dryer manufacturer's website.
Things You'll Need
  • Hex nut screwdriver
  • Replacement thermal fuse
    • 1 Disconnect the dryer from the electrical outlet. Remove the dryer vent from the back of the dryer by loosening the retaining screw on the clamp attaching the vent to the dryer's exhaust port and sliding the vent off of the port.
    • 2 Remove the hex nuts holding the dryer's rear panel in place. Slide the panel off to the side of the dryer. Locate the thermal fuse on the heating element housing on the right side of the dryer. The fuse is an oval-shaped part located near the top of the housing.
    • 3 Slide the thermal fuse wires off of the contact terminals on the fuse. Remove the hex nut holding the fuse in place and remove the old fuse.
    • 4 Place a new fuse on the housing and replace the hex nut. Reconnect the thermal fuse wires. Replace the dryer's rear panel and plug the dryer back into the electrical outlet.
Jun 12, 2011 | Whirlpool LER8648P Electric Dryer
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    MAYTAG ADMIRAL DRYER MODEL LNC7764A71 STOPPED RUNNING ABRUPTLY DURING A CYCLE AND WILL NOT START IT HAS POWER AND THE THERMAL FUSE HAS BEEN REPLACED STILL NOTHING
    There can be many reasons why your dryer will not start or turn...
    The most common causes are the belt breaking or jumping off, or the motor going bad...
    Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
    Dryer Repair - The Dryer is not Turning
    Dryer Repair - The dryer will not start
    heatman101
    Jan 01, 2011 | Whirlpool LER5636P Electric Dryer
    I have an Admiral ADE7005AYW that will not start. We have checked the plug and it is fine but the dryer will not turn on or light up. What could be the problem?
    I f the cord is ok where it connects inside the dryer then There are several other things that could cause this.
    A couple of the more common things to check are:
    1. You could have a defective door switch. you can check the switch with an ohm meter for continuity.
    2. You could also have a bad thermal fuse.Also check this thermal fuse for continuity. this fuse shuts the dryer down if it over heated. if the thermal fuse is bad check your venting for blockage or crimping.
    http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5176934
    Jul 11, 2010 | Whirlpool LER5636P Electric Dryer
    Dryers Logo
    Top Dryers Experts
