Question about Whirlpool ED5FHEXVS Side by Side Refrigerator
I have a Whirlpool #ED5FHLEXNS with the Ultra Ease 2 Water Filtration System. The freezer is icing up and my refrigerator is barfely cold enough at the maximum. What could be causing this & how do I fix it?
2 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: Whirlpool ice maker will not
The temperature lower then 19*F ?
Posted on Nov 02, 2010
The duct that feeds cold air from the freezer to the refrigerator ices up and it has to be unplugged to let it thaw
IF the fan in the freezer is running, this is a automatic defroster problem. Replacing fan is not hard. The defrost system is not for the average person to repair.
Sep 02, 2013 | Whirlpool Gold GX5FHTXV 24.8 cu. ft....
I have two problems with the Kenmore Ultra side-by-side refrigerator I inherited with my new house. 1) Water and Ice Dispenser do not dispense. Ice is being made but doesn't come out and water...
check the switches inside the panel where water and ice come out. that front panel comes off. this happened to me those switches are mounted on plastic mine broke and I used zip ties to put them back in place. The switches were just dangling there.
Aug 04, 2011 | Kenmore 53642 / 53644 Side by Side...
ICE MAKER NOT WORKING WHIRLPOOL ULTRA EASE II
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
' 8798yuiy
Jun 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My icemaker quit making ice its a whirlpool ref. imperial series with an ultra ease water filtration system
i could bet my left leg that your solenoid coil has died. im guessing its still pumping water and getting cold.
Nov 10, 2009 | Whirlpool Freezers
I have a Whirlpool Model EC3JHAXRL00. The ice
Is the ice maker wire shutoff arm or switch (depending on
models) in the OFF position?
 Is the water line shutoff valve to the refrigerator turned on?
 Has the ice maker just been installed? Is the freezer
temperature cold enough to produce ice? Wait 24 hours
after ice maker hookup for ice production to begin. Allow
3 days after ice production begins to completely fill ice
container.
 Does the ice maker mold have water in it or has no ice
been produced? Make sure your refrigerator has been
connected to a water supply and the supply shutoff valve is
turned on.
 Has a large amount of ice just been removed? Allow
24 hours for ice maker to produce more ice.
 Is there a water filter installed on the refrigerator? The filter
may be clogged or installed incorrectly.
 Is an ice cube jammed in the ice maker ejector arm?
For models with an interior ice bin, remove the ice from the
ejector arm with a plastic utensil.
 Is a reverse osmosis water filtration system connected to
your cold water supply? Make sue your connections are secure.
Feb 19, 2009 | Refrigerators
Ice maker stopped working
Hello pryorjonw. You may need a new dual water valve, because the part going to the icemaker may be bad, the ice sensing arm may be in the up/off position, the ice bucket may not be positioned properly not triggering the icebucket sensing switch, the condenser coil might be dirty, or the freezer may not be freezing enough to make ice while everything else seems to be staying frozen. To see if your freezer is cold enough, squeeze your icecream carton, as that is the first to thaw if there is a problem.
Nov 17, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Side by side refrigerator
The ice maker is not producing ice or not enough ice
production.
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ED5FHEXVS Side by Side Refrigerator Logo
19 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
