Question about Home
Mansfield jetted tub control light blinking
On/off light blinking
3 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: Kohler K1338 spa tub controls messing up
no it is not damaged. that is the way it is operated. it always resets to the bottom jets first.
Posted on Mar 04, 2009
SOURCE: I have a Mansfield, Swirl-way tub. Jets won't come
on mine water got behind the soft touch controll and corroded the connection see if there is green gunck on the phone like plug
Posted on Mar 12, 2010
Why controller light flashes but wont work
Flashing lights on a controller are showing you a trouble code. To find out what the code means, count the blinking LEDs.
Here's a link to Pride's troubleshooting guide for the Jet 3:
http://www.pridemobility.com/includes/download.php?f=troubleshooting/INFINFB2045_Jet_3_Ultra_Troubleshooting.pdf
Feb 05, 2015 | Jet 3 Ultra Power Chair
I have a Dream Maker X400 hot tub that wasn't used for a year or so, I replaced all of the jet heads and filled it - when I started it the light starting flashing on and off with a clicking sound coming...
Hello, and thanks for the question. Your error code is actually "SN" not "5N" but they are sometimes difficult to discern on the LCD topside display. The SN error code is for a Non-functional High temperature sensor which automatically kicks the heater off and trips the breaker. You can purchase new sensors for $75-$85 (it could be more, my pricing index is quite a few years out of date) I'm not sure where the sensor is located in that particular tub, although it is most likely in the heating canister. Make sure the power is off at the breaker before attempting any tub repair. if you have shut-off valves to the heating canister you may not have to drain the tub, remove the heating can and replace the sensor you will have to plug/unplug the sensors from the power pack/circuit board. I hope this helps =)
Oct 27, 2013 | Pool & Spa
Jets will not turn off
Sounds like your air switch is bad in the little box on top of the motor.
It is part # TBS-339
Rod
US Parts Center
888-521-6183
Apr 25, 2013 | Whirlpool 6060 DL Corner Pro-Fit Acrylic ...
My dream maker big eze hot tub the jet light on the upper control panel just keeps blinking what does that mean
Are the jets coming on when you press the button?
Try unplug the control from the board and plug it back in.
Dec 01, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have four blinking lights and it reads clean filter cartridges or call for service. First three lights blink jet one jet two and light and also heat light. All four blink and tub will not heat up. Keeps...
Is your pump actually moving water?
I think you should replace your cartridge filter or at the very least, do a thorough cleaning in accord with the manufacturer instruction.
There is a possibility you have pump impeller damage or there is other problem with the pump.
May 13, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
I have a Mansfield, Swirl-way tub. Jets won't come on. Lights are working, but no action from the jets.
Oct 04, 2009 | Whirlpool Home
My jets in my new tub will not turn on.
You could have a GFCI receptacle tripped or in test mode. look close to tub or in and around tub area for this. This receptacle has a test and reset button on it.
Aug 30, 2009 | Mansfield Plumbing Products Mansfield...
Whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Home Logo
130 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
