I have a Bosch WET2820 washer dryer which doesn't seem to be working. When you press Start, it simply cycles through the different stages of the wash, and then stops on final rinse, with the machine not actually doing anything through this process. What exactly is the fault?
  • 15,935 Answers
It appears your main controller board/timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Bosch Axxis WFL 2060 Front Load Washer - DRUM DOESN'T CYCLE
This seems to be a fault with the program controller unit or the water level sensor. The program does not advance further after the inlet is filled but operates the drain to exit water. Now the water level sensor must be checked as if this is not working in the stipulated time it will drain out. Also unless the water level sensor contacts on reaching of set level the motor must start.http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 14, 2012 | Washing Machines
Hi. I have a Bosch WET2820GB/13 washing machine/dryer Yesterday, it stopped part way through a cycle and I have tested it several times since in different cycles and the same thing happens. The water...
This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 06, 2011 | Bosch Washing Machines
I have a Bosch WET2820 washer/dryer and if I am away from home for a week, water starts to assemble in the interior of the machine and the moisture starts to smell badly. I select the drain programme, but...
the water inlet valve is letting the water by, you will need to fit a new one. to get the correct part number you will need the model number which u already have and the "FD" number to get the specific model as there are a couple of varients. you should find the fd number on the silver rating plate inside the door
Nov 19, 2010 | Bosch WET 2820 Front Load Washer / Dryer
Hello, I need a manual for a washer/dryer - bosch wet2820. Thank you.
you'll get it on the net but you'll need to pay for it that's why i didn't got it sorry
Aug 26, 2010 | Washing Machines
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
BOSCH washing Machine WFE 2021
perhaps it is waiting for user to add fabric softener? how it got in this mode?
May 28, 2007 | Bosch WFE 2021 Front Load All-in-One...
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
