Question about Samsung CLP320 AllInOne Laser Printer
Reset printer 325
Resent toner
    New Friend:
Where abouts can i locate the waste toner bottle on this model i open the front and there is only room for the cartridges from what i can see. please help this simpleton
Posted on Nov 05, 2013
How to resent toner counter of Brother HL-2040 printer
These instructions show two ways to reset the toner count ( to install a used toner in printer or get more life out of a cartridge the printer says is empty)
please note that using refilled toner cartridges, non genuine toners and using the 'extra' 10% all have been shown to reduce drum life and prematurely degrade print quality.
you may need these techniques though if you have tried a new toner in a machine to diagnose and then want to install it in another machine.
The first method is to reset the mechanical flag on the left hand end of the toner cartridge. when you first install a toner the printer turns the toner drive gear which moves this flag from the back to the forward position (towards the toner roller).
the flag is the white rectangular bit pointed out by the yellow arrow in the photo
In this photo the position of the flag shows that this cartridge has been previously installed in a printer.
you can undo three screws (red arrows in photo) and reposition the flag in the start position.
be careful to observe the way the gears are installed.
one technician I know just used a flat blade screwdriver to force the flag back to its home position ( to the right) without undoing the screws. seemed to work for him.
the second method is to
1. open the toner door
2. turn printer off
3. hold down go button
4. turn on power while holding go
5. hold down go button for 4-5 seconds untill all lights come on and one goes out
6. press go twice then wait 2 seconds
press go 5 times
printer should power cycle and show itself as ready
Oct 09, 2014 | Brother HL-2040 Laser Printer
49.1643 Service error
Go to hp webite and download resent firmware and that should fix it. Just for kicks, change the toner cartridge out. I saw one causing 49 errors because the gears were locked up, causing gears no to turn. Good luck
Dec 17, 2012 | HP LaserJet 4350 Printer
How to reset clp325 chip
Hello Sal Virani!Here is reset chip for clp 325 printer.Regards!
Dec 14, 2012 | Samsung Office Equipment & Supplies
Lanier 5227 add toner message
I take it you have installed a new toner???? Do oyu know the last time the drum & developer unit was replaced?? It is sold as a unit with the developer in the unit. It is a customer part to replace. If these parts were replaced resently, the problem could be in the toner holding unit that you put the toner bottle into... There has been some up dates to that unit > they improved the fin's that moves the toner into the developer unit... Good Luck
Feb 23, 2012 | Ricoh Aficio 250 Copier
I have a Dell 3010cn laser printer. The screen says to reset the drum. How is this done?
the drum is the toner cartridge
you can resent by first buying a new on from your nearest retail computer shop
then you open the cover of you printer
pull out the old one
then install the new one
Dec 03, 2010 | Office Equipment & Supplies
"AP" error code......what is this?
Have you installed a new toner resently???? I would try that first, install a new toner. The older model had a software problem.. Good Luck
Sep 18, 2010 | Copystar CS-1510 Copier
Hi There, Our copier is making a horrible
Have you resently added toner? If so, try to reinstall the toner. Odds are that you will need the fuser rachet driver gear. Also, on the toner cartride, did you remove the cover for the waste toner??? You may have a packed waste toner feed screw... Good Luck
Feb 02, 2010 | Sharp AL 1631 Copier
Toner exhausted
open the back cover and locate the chip numbered 93c66,its above the USB port on the mainboard.short the top-left and bottom left pins and turn the printer on for 5-10 secs...that resets the page count to 0... also either remove the chip on the toner or cover it with a cellotape
Sep 01, 2009 | Samsung SCX-4300 Monochrome Laser...
In minolta 1054 there is a sign like box and asmall arraw becid i want fix the broblem if u please
Have you adde toner resently??? It is one or two things either add toner or empty out the waste toner...
Feb 26, 2009 | Minolta Office Equipment & Supplies
OKI C8600 Printer Toner Sensor Reset
I've had two toners that have done this, they register as used as soon as you turn the dial to open the toner compartment. So if they don't work properly, as soon as you remove them.. you can no longer use them. (they empty contents into the drum).
I got in contact with my supplier and sent them back as faulty cartridges.
Sep 30, 2008 | Office Equipment & Supplies
Samsung CLP320 AllInOne Laser Printer Logo
54 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
