Question about Michley Lil Sew Mechanical Sewing Machine
Needle won't remain threaded
After threading the machine, when I begin to sew, the threads don't form a stitch and then the thread comes out of the needle altogether.
  • Michley Master
  • 7,365 Answers
Make sure the thread has long thread tails of 4 to 6 inches long
and have the thread tails pulled behind the needle before starting
to sew.
Posted on Jan 05, 2013
The thread on my Elnita sewing machine keeps coming out of the needle and won't sew. How can I fix this?
Make sure to pull at least 4-5 inches of thread through the needle eye before beginning to stitch. It will help to also hold the thread tails in your left hand while slowly taking the first few stitches. Another help is to raise the needle to its highest when starting to stitch.
Nov 17, 2017 | Sewing Machines
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
Husky 910 overlocker..left needle will not sew stitches...does not unthread just won't form stitches
Be sure to install a brand new needle. Verify it is the correct needle for your machine and it is installed facing the correct direction.
Remove all the thread from your machine. (Clip the threads below the thread spools, RAISE the presser foot, and gently pull all the threads DOWN through the needle--NEVER up!)
ALWAYS RAISE the presser foot and rethread from the beginning. Verify that you are threading each thread in the order specified in the manual--failure to do so will cause your machine to malfunction.
When threading, give each thread an extra little tug when going through the tension disk.
Set all the tensions to the midway point for a 3 or 4 thread overlock.
Test your machine.
If the left needle still fails to stitch, then your machine may need a timing adjustment.
Apr 24, 2017 | Sewing Machines
How do I get my Elna 7000 to sew as when I thread the needle and start sewing - the thread is somehow pulled out of the needle?
If you haven't already, install a brand new needle. Be sure to use good quality thread--no old stuff or bargain bin variety.
Remove all the thread from the machine.
Raise the needle until it is at the highest point it will reach before it begins to lower.
RAISE the presser foot and rethread from the beginning--verify the thread path is correct. Pull at least 5 inches of thread tail through the needle.
Check that the bobbin is installed correctly.
Set the upper tension to somewhere around the midway point between high & low number.
Pull the bobbin thread to the top of the fabric:
How and Why to Bring up the Bobbin Thread
When you begin to stitch, gently hold both thread tails with your left hand and begin stitching slowly to start.
Why does my thread keep pulling out of needle
Tilly and the Buttons Five Common Sewing Machine Mistakes How to Fix Them
Aug 17, 2016 | Elna Sewing Machines
I have a elna lotus sp, it keeps bunching up underneith, ive had it working. I've changed the needle , it's starts sewing then stops due to it getting tangled ,
try another needle-- one for the fabric being sewed
make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
make sure the bobbin is inserted into the bobbin case correctly
make sure the bobbin is turned the correct way in the bobbin case
Mar 09, 2016 | Elna Sewing Machines
Top thread keeps coming out of needle. How do I thread top thread?
Be sure to pull at least 4 to 6 inches of thread through the needle's eye before beginning to sew. Pull the bobbin thread up to the top of the fabric BEFORE beginning to sew.
How and Why to Bring up the Bobbin Thread (This works for regular everyday straight stitching too not just design stitches.)
Then, BEFORE taking the first stitch, hold both thread tails with the left hand and then slowly begin stitching. After a couple of stitches, let go of the thread tails and continue to sew.
If you need instructions on how to thread your machine, search the internet for a manual:
Make + Model + the word "Manual"
or look for videos on YouTube to help with the threading process.
Jan 30, 2016 | Sewing Machines
Singer 9030 runs but don't sew
try changing the needle--make sure the needle is the correct one
for the fabric being sewed.
also make sure the needle is turned the correct way in the needle
holder and pushed all the way up into the needle holder.
Nov 08, 2012 | Singer Sewing Machines
Bobbin case jumps out of place when free-motion quilting
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
bird nesting problems
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Sep 12, 2012 | Sewing Machines
Singer 4220
rethread the machine top & bobbin
check to see if the thread has come off the thread take up lever
clean under the needle plate & in the bobbin area for lint & thread
May 02, 2012 | Singer Inspiration 4220 Mechanical Sewing...
How do i thread my needle with the singer handy stitch?
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
Michley Lil Sew Mechanical Sewing Machine Logo
149 people viewed this question
Top Michley Sewing Machines Experts
erebooni
Level 1 Expert
Robin Hill
Robin Hill
Are you a Michley Sewing Machine Expert? Answer questions, earn points and help others
