Question about Homelite Garden
Homelite chainsaw 360 10501a
Boot under carbonater
5 Suggested Answers
slohry
  • 87 Answers
SOURCE: homelite cs3314 chainsaw
Here is a link to get you your parts list. Make sure you have your UT#
http://odref.com/homelite/chainsaw/index.html
Posted on Apr 09, 2009
  • 15 Answers
SOURCE: I need the rubber boot located between the carb
Give Sam a call at Hawkins and Milnor in Shelbina Missouri. THey specialize in older homelite parts and they have the intake boots made to factory specs. The material is of better quality and is not old, rotten NOS parts that have been on the shelf for years. They are a pain to change in the first place. Might as well put a good one in and do it once.
Posted on Nov 10, 2009
dontbother10
  • 2220 Answers
SOURCE: set carb homelite chainsaw mod ut 10939
No response to CR.
Posted on Mar 13, 2010
  • 4088 Answers
SOURCE: Homelite 10540 chainsaw 35CC chainsaw won't start when hot
Go to: http://www.drystacked com for a 12 page article on Walbro carburetor theory and troubleshooting. Check particularly, the position of the gasket in the lower chamber. Check the spark plug for blue, snappy spark when the engine is hot. If ok, place a small amount of fuel mix in the cylinder and try for start. If it pops several times, look to the fuel system. Check the fuel filter, air filter, and muffler for plugging. Does the primer bulb fill with fuel after several pumps? Check the fuel lines for decay or other damage. When the engine is hot, try not using the choke, but set the fast idle. Hope some of this helps!
Posted on Jul 14, 2010
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
What is the gas /oil mix ratio for a homelite bandit lx 30 chainsaw
40:1...
(Remember, it's always better to he over than under...also, GET Alco no smoke...it's the best and cleanest oil mix out... it covers EVERY ratio as well, takes out the guesswork)
Oct 30, 2015 | Homelite Garden
Need a exsploded view of a oilpump assembly on a 1955 ford customline 272 engine
Your question may have been mis-categorized under Homelite chainsaws. It maybe should be under engines.
Sep 15, 2014 | Homelite 240, 245 Oil Pump Cover
Brushes sparking too much
Homelite Chainsaws have no brushes that I know of. Maybe it is not that. It could be a short in the magneto coil wire that goes to the switch.
Check to see if anything is shorting out under the flywheel cover.All the way back to the switch.
Feb 27, 2014 | Homelite Consumer Products 9.0 Amp, 14 In....
I would like to know where I can buy or order an inlet manifold boot for Homelite 330 Chainsaw. I am having difficulty finding this part.
hi photobil
pauly46 here
here is web site for parts
http://www.odref.com/homelite/chainsaw/ut-10540.pdf
go to page 9
part ref # 26 number 93838b boot connector
save a copy of this file
here is another web site
http://store.chainsawr.com/collections/homelite-1?page=11
he has had them but o/s at present but order 1 anyway
check out www.chainsawr.com , go to parts by brand homelite ,
cheers hope it helps
pauly46
May 29, 2011 | Homelite Zama Rb3 Carb Kit 330 Chainsaw...
I need the rubber boot located between the carb and block on a homelite 360 chainsaw
Afternoon Joan;
An IPL (exploded parts list) for yor saw can be found here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches.
These are harder to use than most , blame the blue boxes. Please complain a little to Homelite. HTH
Lou
Nov 04, 2009 | Homelite ZR10926 16" Chain Saw
Need Manual
Go to jackssmallengines.com/searchdb2.cfm Click parts look up, click parts look up again, choose homelite under select OEM, click homelite, click chain saws, follow down list to model no. and click on it.
Apr 09, 2009 | Homelite Garden
Homelite 330 has no spark
Hi
First check if the plug wires is conected with the terminal from the rubber boot,pull the terminal out of the boot,crimp it with pliers and slide it back into the boot(has to fit snugly on the plug.Let me know
please.
regards savumihai71
Dec 10, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite runs wide open all the time
intake boot under carb is probably bad, mine did the same thing and this was the problem. about a 6 or 7 dollar fix
Nov 13, 2008 | Homelite Garden
Garden Logo
63 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
