Question about Microwave Ovens
Walls too damaged to paint
I removed several layers of wallpaper from my bathroom and in doing so ripped up the drywall. There is also damage to the walls that the previous owner covered up with the paper. I've been able to fix it some but it's still too messed up to paint without seeing all the damage underneath. Is there a way to smooth out the walls or lightly texture them where the tears and repairs won't show through a paint job without replacing the dry wall? A friend said she used stucco but it's hard to clean her bathroom walls now and it's really rough to the touch.
  • 787 Answers
Use drywall mudd. Its cheap, easy to apply and sands to a smooth surface.
https://www.thisoldhouse.com/how-to/how-to-finish-drywall
Posted on Apr 20, 2017
3 Suggested Answers
  • 11800 Answers
SOURCE: While using microwave/convection oven in
The aluminium foil has created a short on the magnetron - the device that generates the microwaves . The magnetron failed and in turn has shorted the power source's transformer - the sizzle you hear is the secondary high tension coil burning away when the unit is powered. This of course triggers the fuse every time you try it.
There is nothing more than can be done to save this oven , the damage is too extensive. Just junk it and get a new one.
Posted on Oct 15, 2010
SOURCE: do the walls of a
You do not hve 2 attempt that, those surfaces are specialy designed to stand the high heat n humid environment n most paints wont stand that. It is either the paint wil burn or come off.
Posted on May 05, 2011
Need to paint the inside of my 2001/240 v. Ge advanium what do you recommed
I wouldn't recommend painting it. The inside of the microwave is a box that allows microwaves to bounce around off those walls. If you paint the inside of your box you could have a serious fire hazard. I would send and e-mail to GE and see if they recommend anything that is microwave safe.
Mar 26, 2015 | GE Microwave Ovens
I have a Sharp Carousel Microwave R-1460A. The disk on the ceiling, opposite the warming plate and about the same size, has severe burn marks (probably from food splatters). Any idea what that part is
see this indication and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity pain
Nov 08, 2013 | Sharp R-1460 Microwave Oven
Panasonic genius sensor 1250w
follow this test and fix it. God bless you
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint.
Oct 27, 2013 | Microwave Ovens
Arcing sharp carosel microwave when i put orville redenbacher mini popcorn bags in i found oil on outside of bag
Arcing will occur if you have any metal inside the microwave, or if the powder paint on the inside has been damaged. If the paint is damaged dispose of the microwave
Oct 24, 2013 | Sharp Microwave Ovens
Lg combi multiwave
see the troubleshooting section and follow the steps and fix it.
God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Sep 30, 2013 | Microwave Ovens
Sparking in microwave (aftron make)
test this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#10#ixzz2aaus0Uj3
Jul 30, 2013 | Microwave Ovens
Oven aftron
follow this steps and fix it. God bless you
Brown spots on window of microwave
see this steps and fix it.God bless you
  • Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  • Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  • Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#10#ixzz2aSjW5F9U
    Jul 29, 2013 | Microwave Ovens
    Rust or brown spots on window of microwave
    Microwave when turn on making a noise and sparks comin from fan area?
    Waveguide Cover
    Rack Support
    Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
    Microwave Ovens Logo
    48 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
