Question about Fender Ford Tractor Suport Late Models D8nn16312ab
Pto shaft will not work in my ford 8210 tractor
The pto shaft stopped working when i was cutting hay the lift arms wont rise up and the tractor wont move when put in foreward gear
2 Suggested Answers
  • 3600 Answers
SOURCE: Hi, I have problem with tractor Ford 8210, it is
check the fluid if it'd whhite then change the filters you hsve water in the oil.
Posted on Mar 23, 2010
Testimonial: "Thanks, I understand, i will check all this positions"
Were is the safety switch for the pto on craftsman riding lawn mower
well there's three, there's the seat switch which can be found under the seat of course, there's the reverse switch which will not let you cut in reverse (just unplug it to be able to cut in reverse it you wanted but be careful of the little ones) which is usually near the gear shifter and then there's the break switch located under the mower (look along the break arm just follow the break under the mower and then you'll see a bracket that's flat and when the breaks pushed down the flat piece hit the button switch... why are you concerned? did it stop working here's a tip that most shops wont tell you just replace the main pto button first its cheap and 60% of the time its the main cause of the pto not working, but they wont hesitate to tell you that you need a 400.00 or so new pto. hope this helps
May 16, 2015 | Craftsman Garden
Jd6910pto not working
this is a nice machine it's even got an airbraking system for them pesky hay trailers , try using the front pto , you select it with black lever just behind the shift lever , have someone look to see if it turns , if so you may have broken the output shaft for the rear pto (happens!!) this things dash is fully automated if there was any fault in the transmission then it would show something on the dash panel to alert you of trouble
Mar 06, 2015 | Garden
Does the pto have anything to do with the lift on a tractor?
Sometime around 1950 Ford tractors started using "live PTO". Prior to that the power lift for equipment required that the PTO be on and running (turned on by a lever on left side of chassis below the driver's seat). So 'yes' the older tractors (many in use today) require the PTO to be running in order for the lift arms to lift equipment. I find this very annoying when trying to run a mower, especially when the hydraulics don't hold very well.
Jun 27, 2014 | Ford 8N Tractor
Hydraulic failure
Check out your Ferguson Tractors Information Headquarters, sponsored by Ferguson Enthusiasts of North America (FENA) at www.fergusontractors.org
Feb 15, 2014 | RTO Massey-Ferguson Tractor TE20, TO20,...
Is there a way to operiate the hydro to raise and lower with out the PTO spinning
If your tractor does not have "live pto", then neither the pto shaft, nor lift arms when the clutch is depressed.
I don't think any 2n's, 9n's, or 8n's came equipped with a live pto.
Hope this helped.
Jan 23, 2011 | Ford 8N Tractor
My ford 8210 will not move when gear is selected and the oil light is warning even although there is enough oil on dip stick. also link arms will not lift
there is a dip stick on the back end up top on the left side. It is probably low on oil.The filler cap is on the right. Use 10w 30 oil and that should sort you out. Otherwise it sounds like the hydrulic pump could be at fault.
Jan 10, 2011 | Fender Ford Tractor Suport Late Models...
Lift system isnt working and pto shaft dusnt rotate when activated
The pump may be bad or need bleeding out.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 17, 2010 | Ford Tractor Grill 2600 3600 4600 5600...
Fender Ford Tractor  Suport Late Models D8nn16312ab Logo
101 people viewed this question
Top Fender Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Fender Garden Expert? Answer questions, earn points and help others
