Where do I plug in power for speakers?
I recently moved my computer. Before I moved it, the speakers were working fine. After I moved, I have a power cord that I'm sure goes to the speakers but can't figure out where to plug it in. I feel rather silly for not figuring this out myself because this is not the first time I've had to move this computer. The speakers are the old style that could be attached to the side of the older monitors. The only name on them is Polk Audio (no model number)
so I don't even remember which computer they came with.
  • 2 more comments
  • skh12345 Jan 19, 2009
    No, there is no hole on the back that the power cord would go into. I pulled the cover off the front and underneath it says CE N279. Any help would be appreciated. Thanks.
    They are about 10" tall.
  • Juanita Vega
    Juanita Vega May 11, 2010
    are they the small ones or the tall ones?
  • Juanita Vega
    look on the back of the speaker is there a hole that the power cord should go in?i'm not sure of the speakers you have if you can find the model number that would help alot
  • 685 Answers
Where do I plug in power for speakers? - 3n53k33o11231g013491j56a03f8163aa14ce.jpg are these it?
Posted on Jan 19, 2009
  • Juanita Vega
    Juanita Vega Jan 19, 2009
    ok i'm looking at a set the only thing you have to plug in are the 2 wires going to the speakers and then into the computer there is no power cord
    there should be a hole on each one and on the computer tower there is a place to plug them in and it normaly shows the speakers what kind of computer is it?
Power light is on but no sound from the speakers
Have u hooked them up correctly ? I did that once n the left n right were wrong way around
Oct 29, 2012 | Altec Lansing VS4121 Speaker
Everything is plugged in turned on but no sound. I recently moved my computer system to a new location and have not been able to get the speakers to work help
I assume this is a powered unit, so first off make sure the power cord is plugged into the wall and the speakers. then make sure you are plugged into the correct jack on the PC. It is usually green in color. Finally, make sure the volume on both the speakers and the PC are turned up. Report back wit hresults.
Jul 01, 2011 | Harman Kardon Audio Players & Recorders
I have just moved my speakers around in my room and they were working perfectly before. Now only one speaker is playing and when i swap the inputs the other speaker will work fine but they other one wont....
check the mass terminated cable connecting the controller to the base speaker. This connection becomes flacky generally requiring a good contact cleaner solution being needed to be applied to restore the connections.
Go to radio shack and ask for a plastics safe contact cleaner then after disconnecting the mass terminated cable spray it liberly. Then reinsert while still wet then work in and out a few times. You can do this for all the cables connecting to the pc as well. This should restore your dead channel....hop it works :-)
Feb 23, 2011 | Logitech Z-2300 Computer Speakers
Speaker buzzing at random
It sounds like the socket on your computer is becoming worn or has a loose solder joint.
If you feel comfortable with a fine tipped soldering iron and stripping your computer down I would take a look there first.
Also check the power supply for the speakers to make sure it is not getting too hot.
Sep 09, 2009 | Logitech Z-2300 Computer Speakers
Sound problems
your speaker connections are plugged in incorrectly or the speakers are not plugged in and powered on.
check the back of the computer where your speakers are plugged in and make sure you speakers are plugged into the right colors
May 31, 2009 | Computers & Internet
Logitech Z-5500 DON'T POWER ON. HELP!!!
check its power supply if its working, first.check the outlets(electrical sockets)just to be sure of proper fit.
May 31, 2009 | Logitech Z-5500 Computer Speakers
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
I moved, and now my speakers won't work
check for the power button is on behind the woofer or speaker,if ur speakers does not have switch hten select the volume control optin and click the properties and check the sounds by clicking the speaker images in that window.if u have problem again,askme through fixya again.
Aug 16, 2008 | AOpen MS-810 Computer Speakers
No sound
be sure they are plugged into the right jack on back of sound card. Also, plug speakers into a second different PC with good working sound. This will verify that the spaekers are still ok. If speakers are ok, then check in control panel under Sounds, see if a sound cscheme is selected. If No Scheme selected, select one, then respond NO if prompted to keep scheme.
Apr 18, 2008 | Logitech Z-2300 Computer Speakers
Only getting half the volume
The first things I would check would be the volume control within your operating system. If I assume you have Windows XP, you would go to Start-->All Program-->Accessories-->Entertainment and click "Volume Control". Make sure all of the sliders are at least 1/2 way up. You might also want to check to make sure the cable from the speakers to the computer is plugged into the proper jack (usually the green one), as sometimes computers have jacks for rear speakers, which might make them sound quieter.
Mar 04, 2008 | Logitech Z-2300 Computer Speakers
207 people viewed this question
