Question about Sharp AR-207 Copier
ANYTIME I TRY TO MAKE A COPY USING THE RSPF ON MY AR207 I GET AN E7-04 ERROR. I CAN ONLY MAKE COPIER ON THE STAGE GLASS
  • 26 Answers
Hello
This ERROR means :
"Detection of white CCD".
Posted on Jan 20, 2009
My AR-168D is having doc feeder problems.If paper is loaded intpo the document feeder the light comes on that recognizes the paper is loaded.When i press copy nothing happens but the scanner moving over to...
Thats pretty easy to fix. Remove the glass. You lift the document feeder out and remove the 2 screws from the front and back of the glass.
Once the glass is removed, Take some rubbing alcohol, or good cleaner. Formula 409 , fantastic etc, dampen a cloth towell and clean the stainless steel shaft on the rear of the scanner that the lamp rides from left to right on.
I bet if you try and move the scann lamp carriage it is very hard to move.
Clean it a couple of times. Get e very light weight oil and put a light ammount on that shaft. Run the carriage back and forth a few times, clean and relubricate the shaft and you should resolve the problem.
Very common. I would say there is a 99 percent likelyhood that this will fix your problem.
Aug 09, 2010 | Sharp AR-168D Copier
MISFEED INDICATOR BLINKING
DEAR SIR WHERE YOU REMOVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEASE CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Sharp AL 800 Copier
Message CHECK SPF/RSPF and will stick on scan often.
In the Jaguar series, (ar-168d) you will need to get into the simulations; press in rapid succession: # * C * You will know when you did it fast enough when all the display lights go out except the number display, press 41 start/copy. then 6 start/copy. Let the copier do what it needs to.
The scanner will move, keep the lid down, it will let you know when it is done when it goes silent. Then press CA key to clear out and try copies again.
Dec 15, 2009 | Sharp Office Equipment & Supplies
Tryong to use top feeder, it keeps reading
SPF is normal document feder
RSPF is autoreverse document feder.
Select the your document feder instaling the copiers,remove any originals to the glass.
Oct 21, 2009 | Sharp AR-168D Black and White Copier
Sharp AL 1551 CS RSPF not feeding
This can be a fault of the controller of the direct current. Apply to service This fault can be not eliminated by you.
Mar 23, 2009 | Sharp AL-1551CS Copier
Problems with SPF message and black copies
The "Check SPF/RSPF" issue can be a couple of things
  1. If the scanner only moves from right to left then immediately moves back then the copier needs to be adjusted.
  2. If the scanner moves from right to left and tries to feed then displays message then the ADF needs to be cleaned.
Same for the dark issues
  1. If you lighten the exposure and the copies come out better then copier needs to be adjusted
  2. If you lighten the exposure and the copies come out the same then you may have a few problems check the following;
  • Open right side door and look at drum green/blue cylinder . If it is covered with toner (black film) then you might have a drum short.
  • Open right side door and look at drum, if it is not covered then you may have a board issue.
While making a copy off the glass listen to the right side of the copier and if you can hear a screeching sound then you could be having an electrical short that is causing your black copies.
Depending on your findings depends on the remedies.
Mar 16, 2009 | Sharp Office Equipment & Supplies
Light copies
NEVER, EVER touch the "green roller" (drum). Are copies worse than before you cleaned it. I wouldn't be surprised
Mar 13, 2009 | Sharp AR-207 Copier
Error Message: Check SPF/RSPF START to Resume
I just fixed this problem on my sharp all in one. The white rollers on the underside of the copier cover were not rolling well. I took an alcohol prep pad and started cleaning them, rolling as I went. A large piece of lint fell out. I put the documents in the document feeder and they fed through like a charm. Hope this helps.
Aug 06, 2008 | Sharp AL-1655CS Copier
Feeder problem..
I had the problem. The feeder didn't work but everything else was okay and the error code sounds familiar. The problem was cleared and fixed with the following codes entered from the panel
#*C*14CC
Where C means push the copy button.
Good luck
Nov 09, 2007 | Sharp AL-1655CS Laser Printer
Sharp AR-207 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
