Question about Westinghouse LCM-22w2 Television
Westinghouse LCM22w2 monitor need cord to pc
What cord do I need to go from the monitor to the pc, I got it used and it only has the power cord.
  • 13 Answers
You need either a standard VGA cable or a DVI cable, depending on the type of video card you have.
http://www.ctcco.com for professional hosting solutions
Posted on Apr 09, 2009
I have a Westinghouse LCM 19v7 monitor that stays on for a few seconds and picture goes off. I know about the capasitor replacement but there is another conponent that I need to replace. It is the pow
That is the correct value. That resistor just gets very hot and discolors the PC board around where it is soldered. You should be able to remove all of the old solder and scrape the resistor leg to get it bright, resolder the leg to the copper pad and you should be good to go.
Oct 09, 2012 | Westinghouse LCM-19v1 Monitor
Westinghouse Model: LCM-17v2 SL DC Input : 19V === 2.6A S/N: W17C I need a power cord. Westinghouse Monitor Model:LCM-17v2 SL DC INPUT : 19V === ...
Hello Mike, you can order the adapter by calling the Westinghouse parts department at the toll free number 1800-701-0680 and selecting option 2 for parts. You can also send me a request for the part to westytech@westinghousedigital.com.
Aug 21, 2010 | Westinghouse Electric LCM-17v2 17"...
Power cord issue? Black Screen with image issue?
The powere cord you are using is fine (the cord is made to handle the 10A load, you are only drawing 1.5A). The monitor uses switching mode power supply that can handle any voltage INPUT between 100v up to 240v. More likely to be bad caps in the power supply. See example of failed Westinghouse due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 01, 2010 | Westinghouse LCM-19v5 Monitor
Need power cable for a westinghouse LCM-19v1 SL monitor
We carry the power cords for this model at our web site at:
www.ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Oct 17, 2009 | Westinghouse LCM-19v1 Monitor
NEED NEW POWER CORD FOR WESTINGHOUSE COMPUTER SCREEN MODEL LCM-17v2 SL. WHERE CAN i GET ONE?
Usually monitor cables are standard, and are the same as your PC. You may want to try the one from your PC see if that works fine, then you know exactly what to get.
Sep 30, 2009 | Westinghouse Electric LCM-17v2 17"...
No picture although there is power to the monitor (green light goes on)
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 02, 2009 | Televison & Video
Need to purchase a power cord
I could not find one on line but check with TigerDirect.com.  1-866-921-PART (7278)
May 29, 2009 | Westinghouse W33001 30 in. HD-Ready LCD...
I need a replacement power cord
Found one here:
http://acebargains.stores.yahoo.net/acpoadforwel.html
and ebay looks to have a few as well:
http://cgi.ebay.com/AC-power-adapter-Westinghouse-LCM-17V2-sl--LCD-monitor_W0QQitemZ360118562836QQcmdZViewItem
Hope this helps. You are right this far from a typical power supply cord. Most just need to the cord with a 3 hole female end that plugs straight in the monitor.
Mar 02, 2009 | Westinghouse Computers & Internet
Can't find correct setting for westinghouse lcm22w2 monitor
I don't know if this actually will fix your problem, but all LCM 22w2's are plagued with the 'white screen of death' and eventual power shutoff, including garbage characters and faulty menu, video output, etc. Here's how I fixed it.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supplyboard. This is a common problem plaguing motherboards and LCDflatpanels that use capacitors from Taiwan. If you know how to solder,or know somebody that can, it's actually a pretty easy fix. Take outthe yellow circuit board on the inside, write down the specificationsfor each of the capacitors (the cylindrical things) go to theelectronics supply store and get the replacement capacitors. You can goover the voltage specification (not under), but keep the capacitancevalue matching. Replace one at a time. Go to www.badcaps.net foradvice, tutorials and training on doing this. *You really shouldreplace all the capacitors*, but the very large one next to the powerplug I did leave on the board because I couldn't find a match. To mydelight, the white screen of death went away and it was working as new!
I saved a ton of money fixing this, it's definitely worth learning how to solder to do this.
Jan 07, 2009 | Westinghouse LCM-22w2 Television
Westinghouse LCM22w2 Monitor
I'll buy it from you. I just need a non-cracked LCD from this monitor. It doesn't even need to turn on. You can e-mail me at rallis@gmail.com
Jan 30, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Westinghouse LCM-22w2 Television Logo
120 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
