Question about Lasko 5141 Ceramic Electric Heater
How to set temperature in a lasko portable heater
4 Suggested Answers
farfield
  • 462 Answers
SOURCE: Cannot get the heating element to turn off properly on Lasko 5620
From whatI have seen on base board heaters if I recall correctly, the thermostat may be sepperate. Usually thermostats on these have a round knob. 1 line goes to this and the other side of the thermostat goes to 1 end of th element and the othe line attaches to the other side of the element. Its possible you have the element wired in directky if it came without a thermostat and without instructions it may till be connected directly. You should have an L1 and L2 connection and hope there is a wire diagram on the cover.
THE reason these basebord heaters used to come without a thermostat is because they are (OR WERE)set up to add on additional heaters comming right on down the wall. At the last one you could tie in and get a correct rated thermostat installed in the center of the series.
Return to LOWES and ask them to remove the instructions and copy them for you from another like model. Or have them contact the manufacturer and request they fax a copy of instructions with a diagram. Also ask if the heater comes with a thermostat. It may stoill be sepperate in another kit.
Posted on Mar 04, 2009
markfreedman
  • 312 Answers
SOURCE: My Lasko 5805 heater worked
Hi, I looked through the manual for the information to change the thermostat display from reading Celsius to Fahrenheit. Couldn't find anything. I did find a number to call for customer service
800-233-0268
Also, Here is the link to the manual.
http://www.laskoproducts.com/instructions/5800Ins5800ESa.pdf
Hope this Helps,
Happy New Year,
Mark
Posted on Jan 02, 2011
  • 12 Answers
SOURCE: how do i prevent my lasko heater to keep raising the temperature? i can't seem to set it to stay on one!
If its a central heating unit you should make sure the batteries in the thermostat are good and the fan switch is on auto. then you can open the cover to the heater and tap on the relay. that will usually shut it off if its just sticking. It could be a black box by itself or a box on the circuit board depending on the model
Posted on Nov 29, 2012
How do you set thermostst
Open the units door, set temperature 5 degrees above the room temperature or OAT.
Oct 04, 2014 | Lasko Products 760000 Ceramic heater w...
How do I regulate temp on my lasko heater
My experience with Lasko heaters is with the small portable ceramic types. On mine there are two knobs. One is the "Power"; the fan symbol is for fan only, then (I) Low Power and (II) High Power 1500 watts. The other know is the thermostat from (-) to (+). Set the thermostat towards (+) until the temp in the room is the way you want it. Then turn the thermostat know towards (-) until the unit shuts off. This is now the temperature setting and the heater will cycle on and off to this setting. Hope this helps.
Jan 05, 2014 | Lasko Ceramic Heater
Schematic plf504d thermalinc
Dec 13, 2013 | Lasko 5610 Baseboard Heater
How do i prevent my lasko heater to keep raising the temperature? i can't seem to set it to stay on one!
Nov 29, 2012 | Lasko Heating & Cooling
Lasko 5141 - I set the temp to hold @ 68 degrees at night but it seems to ignore the setting and gets into the high 70's. This is with the rotation switch on if that makes a difference. Any Help ? Thanks
Remember it is always colder at the floor level, the heater is pretty close to temp when it is above 40 degrees outside, but as the temperature gets colder outside so does the temperature at the floor level in your house because heat rises.
I use my house furnace thermostat mounted half way up the wall as a guide, When the temp outside is in the teens, I have seen as much difference between the floor temp on the heater and the wall to be 4-6 degrees different. So this means as the tempurature outside drops you need to regulate the thermostat on the heater downward to compensate for the colder floor temperatures.
Jan 10, 2011 | Lasko 5141 Ceramic Electric Heater
Heater shows red ready button, but won't turn on. Any ideas? I've already unplugged, tried multiple outlets and vacuumed the heating elements.... ???? What next ????
Turn temperature setting all the way up.
If that does not fix, turn temperature setting all the way down, turn heater off, unplug for at least 10 minutes.
Oct 05, 2010 | Lasko 5365 Ceramic Compact Heater
Our Lasko 5620 has a digital control, but we can't set the temperature. It says at 76 degrees, no matter what we do. Hitting the control buttons does not work.
Based from your comments, it seems that you have a
defective digital control. Have a check up for this item.
It may need to be replaced. Hope this will help you.
Jan 10, 2010 | Lasko 5610 Baseboard Heater
Mar 04, 2009 | Lasko 5610 Baseboard Heater
Model 5800
In page three in the manual it shows you how to set your temperature settings.eb6548e.jpg
Oct 30, 2008 | Lasko Ceramic Heater
Won't shut off when reaching preset temp
The heater shuts off when it reaches two degrees above the set temperature and turns back on when it is two degrees below.
Dec 13, 2007 | Lasko 5365 Ceramic Compact Heater
Lasko 5141 Ceramic Electric Heater Logo
91 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Mack Baxter
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
