Question about Cyberhome CH-DVD 300 DVD Player
Not seeing anything but getting audio
I am getting audio but I am not seeing anything, I was checking the settings on the dvd a blue screen appeared with 3 columns with writing in it that seems to be codes and it seem to have lock me out, how shall I handle this problem, is there a button I have to press on the the remote to reset or do I have to take it to a Technician?
  • Anonymous Dec 22, 2008
    Thanks I had the same problem and came here looking for solutions, I tried the reset o factoryand it worked.
    Problem Solver:
  • 13 Answers
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds (some solutions say 20 seconds).
Posted on Oct 27, 2008
  • 40 Answers
Sir u havent said the company name or model no still do check the the cable to tv and then check if it is in pal mode or in ntsc mode
Posted on Jun 27, 2007
SOURCE:
Why can't I play VCR tapes anymore?
Blue screen usually appears when there is either bad or no data signa Possibly something is not connected or set up correctly. Has anything been changed since you last viewed your tapes?l
Jun 17, 2015 | Toshiba DVR620 DVD Recorder/VCR
How do i fix a blue screen on a polariod pmp180
The blue screen usually means the set is not seeing any signal--check to see if a DVD etc connected to one of the rear audio/video inputs works or not.
May 29, 2012 | Televison & Video
I am trying to install DVD player/recorder to my sony strdh510 reciever get the sound but no picture. I plug the dvd as per manural green/blue/red out to DVD in green/blue/red what am I doing wrong
It appears you are trying to connect via "component" video - green (Y), red (Pr), and blue (Pb). Make sure the settings on the Sony is set to component - NOT composite. You can try composite - the yellow to yellow jack (from the DVD to receiver or TV), to see if that works, but make sure your settings are for composite. The audio are red and white, right and left respectively and are used for both schemes above.
Feb 19, 2011 | Sony STRDH510
I have no sound with my lg blue ray player but my lg dvd player has sound throught and i am using a hdmi cable and i have set the blue ray audio settings with a lg tech anything will help thankyou
Some times the DVD player needs to be set to output digital audio through HDMI. If that is set, then do the same with the menu options on the TV/LCD/Plasma/Screen that you are using.
Jul 25, 2009 | Kenwood VR-716 6.1 Channels Receiver
I HAVE NO AUDIO, AND THE PICTURE KEEPS ON SCROLLING ACROSS THE SCREEN, ALSO THE COLOR ARE ORANGE AND GREEN
How is it connected? If you are using the RGB (Component cables) then you could have hooked up the Blue to green and vice versa On some sets the Blue and Green are so close that its easy to cross them form either the DVD player or the monitor.
As for the audio, if you can see the home screen, use the remote to navigate back ( left arrow all the way, then down to the audio set up screen) check to see what the audio default is set to. If you are using the standard analog stereo ( white and red) select this option and return to playback mode. Hope it helps.
May 10, 2009 | Sony BDP-S350 Blu-Ray Player
Have sound, no video
Pressing the I/E button on the remote control repeatedly until the DVD blue screen appeared fixed the problem.
Jan 03, 2009 | Televison & Video
HDMI out to Olevia 527 TV = Blue Screen
Hi beelzyboob.. try checking these.. since you are using the RCA (composite cables) and I assume you have them on the "DVD in" at the back, go to setup, go to input assignment and go to hdmi input. here, make sure dvd is set to" ----". Next, hit return and go down to component input and also check if dvd is set to "-----". With these settings, you should get video. This is because you are not using either an HDMI or component cable. hope this helps.. ^_^
Sep 09, 2008 | Onkyo TX-SR606 Receiver
Toshiba Model 42HM66 DLP Projection TV
I strongly doubt it's the lamp assy since you can actually see the blue screen. If the lamp failed, you would not see anything on the screen. This blue screen indicates to me that either the tuner is no longer decoding the signal, in improper input has been selected (ie: input 1 is selected while actual signal is on composite 1), or something of that nature. If you are getting audio then the input is selected properly but the video decoder has failed.
If your cable signal is going through a VCR or DVD, disconnect it from there and go directly to the TV (ie: bypass the VCR/DVD). If your picture comes back, there's some kind of problem with your VCR/DVD player.
If you have multiple inputs, try connecting an input signal to another input (ie: video 1, or aux from a dvd player) and see if you get a picture there. If you do get a picture, the whatever input you're currently using has malfunctioned.
Mar 08, 2008 | Televison & Video
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
Dvd will not play movies
Are you trying to play a DVD-ROM? Some sets won't play anything but conventional movies, leaving you to put the disc in a computer to watch it...accordianman
Oct 20, 2007 | Disney 13" TV
Cyberhome CH-DVD 300 DVD Player Logo
331 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
