Question about Ardisam Garden
Earthquake auger will not start - Ardisam Garden
What are the effects of earthquakes
Although probably the most important, direct shaking effects are not the only hazard associated with earthquakes, other effects such as landslides, liquefaction, and tsunamis have also played important part in destruction produced by earthquakes.
Earthquake Effects
eqseis.geosc.psu.edu/~cammon/HTML/Classes/IntroQuakes/.../earthquake_effects.html https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=What+are+the+effects+of+earthquakes
Dec 02, 2016 | Garden
Where do I get a carbuerator for a 8900 power drill
If this is an Ardisam Earthquake 8900 auger, their website describes the engine as a Tecumseh TC300. The part number appears to be 640347A. An aftermarket model is available from Amazon for $28.50 with free shipping. Sears also carries an OEM carb that is $67.57.
Oct 14, 2014 | Garden
Auger won't start unless ether is sprayed into carb,then it will run until you stopauger . to re-startspray more ether
Is there a primer bulb that you need to prime? is there a choke that you can fully close proir to attempting to start.try holding full choke and throttle on initial cold engine start.if none of these help then a weak diaphram fuel pump may be the issue
Sep 06, 2014 | Ardisam Earthquake Earth Auger...
Excavators boom
Is the machine leaking any fluid?
Jun 19, 2013 | BIT EA10F Earthquake Earth Auger Bit 10"...
Wont start
I would check your fuel first. Replace fresh fuel, check fuel filter if equipped, check fuel line to not be clogged. When trying to start make sure fuel is getting to carb. If after checking all the above, it still doesn't start, I would check the spark. Make sure you are getting a spark, clean and or replace spark plug. Best of luck.
Aug 07, 2012 | Ardisam Earthquake Earth Auger...
My machine in not excavating soil when we operate it augors are not working what do we do
Check at the top where the shaft from the motor goes into the auger shaft... there is a shear bolt...the pieces may still be there like normal but the bolt is broken inside...pull out one of the outside pieces and then find the rest and punch the broken pieces out... then replace the bolt with the proper hardness bolt to protect the equipment...
heatman101
Aug 31, 2010 | BIT EA10F Earthquake Earth Auger Bit 10"...
Need a user manual for Earthquake 3365PS tiller
I need a service manual for the earthquake 9800 auger with the 3.8 hp tecumseh.
May 12, 2010 | Ardisam 5.5 Hp Rear Tine Rototiller
Garden Logo
46 people viewed this question
Top Ardisam Garden Experts
Jay Finke
Jay Finke
lnbn1975
Wade Mobley
Wade Mobley
Are you an Ardisam Garden Expert? Answer questions, earn points and help others
