Question about Frigidaire Dishwashers
ER code, flashing touch pad selections.
RESET CIRCUIT BREAKER SEVERAL TIMES. WASH STOPS MIDWAY PROVIDING ER CODE FLASHING ALONG WITH SEVERAL TOUCH PAD SELECTIONS.
  • Frigidaire Master
  • 3,247 Answers
It is most likely a fault with the keypad mebrane on the dishwasher control panel. Need model number of dishwasher to make a more detailed conclusion.
Posted on Jan 05, 2013
  • Guy Callari Jan 05, 2013
    thanks Sam. The model number is FDBB4365FC3,
  • Sam Jan 06, 2013
    the keypad is part of the console assembly available fromhttp://www.searspartsdirect.com/partsdir... Also see this site for fault code explanation.http://www.applianceaid.com/frigidaire-d...
marked
  • 6487 Answers
SOURCE: MDB 8750 Dish Washer Doesn't start the Wash Cycle.
Yes this can be a touch pad failure that may need to be replace again , because with this type of device usually the touch pad is easy to get bad...
Good luck........
Posted on Aug 19, 2008
  • 409 Answers
SOURCE: Error flashing and won't reset.
hi there,
PF stands for power failure. the first you should do is check your house breaker and make sure that you did not trip the fuse.
Does anything run? Can you hear the motor running? If not, you have no power coming into the machine. In this case it's the main control board that needs to be replaced.
If the motor hums, it means you have power to the d/w, in that case you need to replace the touchpad.
thanks
Posted on Oct 02, 2008
RepairClinic
  • 32 Answers
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
SOURCE: Touchpad--No Response
See the notes about cycles taking forever. The relay that controls the heating element commonly gets warm enough to melt the solder around the connection, and the internal water heater stops heating. The "2H" indicates how much time the onboard computer thinks it will take to wash the load, based on previous loads, but if the last cycle was longer than 99 minutes, it shows 2 Hours. Repairing the controller board (or replacing it) should solve the problem. This is such a common problem, Bosch should have had a recall, but didn't.
Posted on Aug 05, 2009
SOURCE: Most of buttons on touch pad are not working.
This was posted in another maytag qs300 thread there are 2 ways to fix the front panels on these dishwashers. My advice fix it as cheaply as possible and save some cash to get a better dish washer because these newer maytags are just plain awfull.
Quick fix for dishwasher from hell.
What I found was to turn off the breaker to the dishwasher, unscrew the inside panel ( about 12 Torx screws ), remove the black cover on the computer ( 1 hex head screw ) remove the ribbon cable coming from the front panel by easing down the plastic locking tab, then take a soft clean cloth and gently wipe the end of the ribbon cable (both sides) and reinstall. This keeps our machine working for another couple of month, when I go thru the same exercise again. I think it is condensation that makes the ribbon cable connection bad or short across two of the lands.
Permanent fix for dishwasher from hell.
The flex cable shown in the pictures above was bad on my unit also. It looks to me like they are pulling too much current through this cable to run all the LED's on the front panel. Mine died the instant death so I removed the touch pad and traced out the wiring.
The start/cancel switch is a connection between pin 6 and pin 10 on the ribbon cable. There is a 10K resistor in series with the switch to limit the current.
I tried to order the part from my local parts house and was told it was a special order only and would take about 4 weeks to get. Later I found you could purchase it off the internet and not have to wait quite as long. Since the replacement part is the full plastic piece across the top of the door I decided to try a mod. The touch panel is just glued to the plastic piece so I removed it completely. That leaves some glue that will need to be cleaned up but I can do that later.
I found a C&K momentary push button switch that fit in a 1/4 inch hole. I drilled the front panel in the center to accept the switch. If you moved it to one side it might not conflict with the latch switches quite as much but I made it fit.
I then looked in my junk box and found two pieces of 18 gauge wire and one 10K resistor. I put the resistor on the normally open pin on the switch and then connected a wire to that. The other wire went to the common pin on the switch.
When you look at the control board the pins are labeled as 2 on one end and 18 on the other. You only see every other pin as there is another row that is buried. You need pins 6 and 10 so they are on the visible row. Use a small soldering iron and connect the two wires up to those pins. It does not matter which one goes where.
Put it all back together and push the button. You do not have all the flashing lights or options but I am now washing my first load of dishes in several weeks.
These are copied word for word from the other maytag thread found here
http://www.fixya.com/support/t387192-maytag_quiet_series_300_no_power_touch
Posted on Mar 26, 2010
Whirlpool WFE381LVB gets F1 error code
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Feb 27, 2012 | Whirlpool Electric Range
F-7 code has been flashing, along with constant beeping. This has happened about 5 times over the past 2 months. Eventually it stops but now we resort to flipping the fuse off to get rid of the noise. ...
Hello Marylou,
The F7 code means the same thing on all domestic (USA) brand ovens.What is means is that a button on the touch pad is shorted (welded together) out. Since you did not include brand or model#
i will give you the following advice, if your touch pad is a seperate part that plugs in clock (also called the oven control,or eoc..electronic oven control) then just the touch pad can be replaced,on certain brands or even some models within a brand the touch pad is integrated into the clock/oven control or eoc in that case the complete touch pad/control asm. is what needs to be replaced
Hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Ovens
My oven keeps randomly beeping and flashing F-1 recently. When I push cancel it stops, sometimes for an hour and sometimes for a week. I have tried to reset by turing circuit on and off, but problem does...
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
May 11, 2011 | Maytag Ovens
The lights on the front panel are flashing
Try flipping the breaker off for several minutes. This may reset the electronic glitch the dishwasher is having. If that does not work you can try to remove the ribbon cable from the touch pad and clean it with an eraser. Often times this will fix this type of issue. If that does not work, the touch pad would probably need to be replaced.
Appliance & Refrigerator Repair
Mar 22, 2011 | Dishwashers
F1 error code and beeping on a ge doubleoven
Hello there:
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Error code of "Er s" appears on the display and inside the light remains on at RINSE Low. HELP!
Many modern appliances have error code build in to the control programing to help with the diagnosis of a failure. Frigidaire dishwashers with display s will flash Er then a two letter error code.
Er i s a Switch error (Replace Console Pn# 154639207)
CE is a Configuration error (Replace Control Pn#154543602)
UO is a Vent that will not close. (Replace Vent Pn#154682301) or remove blockage
uF is a Vent fan Not running (Replace Vent Pn#154682301) or remove blockage
Other codes you my see in the display that are not errors
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
01-24 hours of delay
Service Test
To enter service test you must turn off the power and PF will be displayed. While in PF press and hold Pad # 1 and Pad # 7 at which time an “rt” will appear in the display. To get it out of service test Press Pad # 1 and the Pad # 7 this will return you to PF mode.
[ (#1)(#2)(#3)(#4)(#5)(#6)(#7) (#8)(#9)(10)(11) ]
Press pad # 1 Active water valve Ultimate Scrub Maxx Clean Valve on =FL Valve off =rt
Press pad # 2 Test Speed motor (1 Time) motor @ 2800 rpms Speed Wash pad ”28′ First two digits motor speed
Press pad # 2 Test Speed motor (2 Times) wash motor @2950 rpms Speed Wash pad “29′ in display
Press pad # 2 Test Speed motor (3 Times) wash motor @3150 rpms Speed Wash pad “31′ in display
Press pad # 2 Test Speed motor (4 Times) wash motor @3450 rpms Speed Wash pad “34′ in display
Press pad # 2 Test Speed motor (5 Times) turns off wash motor No light on ”rt” in display
Press pad # 3 Test Dispenser dispenser powered Normal Wash on = “Sd” off = “rt”
Press pad # 4 Test Drain pump on/off China Crystal or Party glasses on = dP off = “rt”
Press pad # 5 Test Fan dry Active vent on/off Top Rack,Eco Wash Glasses on = Fan speed off = “rt”
Press pad # 7 Test Rinse aid level none Rinse only low = RE full = RF off = “rt”
Press pad # 8 Test Soil Sensor none Wash Silencer or Wash pressure on = sensor voltage reading off = “rt”
Press pad # 9 Test Thermistor none Wash Temperature on = Temperature in °F off = “rt”
Press pad #10 Test Heater on/off Heater on/off No Heat Dry on = HO off = “rt”
Let me know how this works out for you.
Benjamin
Dec 23, 2009 | Dishwashers
Touch pad
Update - Turned the Circuit Breaker off to stove and turned back on. The second time I did this, it "fixed" the touchpad. Clock resumed flashing the time and all buttons work. Thank goodness no service call this time!
Feb 10, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Beeping, flashing, oven door locked, display shows F-1
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) BUT you also need to check the Oven Temperature Sensors The Oven Temperature Sensors should read room temperature, 70°F, the resistance is 1000-1200 ohms. make sure you pull off the wires to measure the sensor's resistance and it reads open it is bad. and you will have to replace it too. hope this helps.
Sep 05, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Error code F1
Error code F1 is for a defective touch pad or membrane (usually the touch pad). In this case you will need replace touch pad or membrane. It seems that water entered the touch pad during the self cleaning process, remove the touch pad and try to dry it. Good luck !!
Jun 08, 2006 | Maytag MER5530 Electric Kitchen Range
Dishwashers Logo
504 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
