Question about Dacor Ovens
Dacor Oven Thermostate problem
I have a Dacor Model# ER48DSCHNG range (I think, can't find the ser.# but this model looks identical to mine). The main oven will heat up to temp. but won't maintain the desired temp, leaving me to believe the temp. sensor is bad. I pulled it but cannot get the plug thru the hole inside the oven so I can just plug the new one in. Can I cut the wires on both & hard wire with wire connectors the old wires to the new sensor wires? This thing is big! And hard to move out? UPDATE: I moved it out today the new temp sensor came in, when I got to the back the old one was hard wired anyway, so I cut the plug & hard wired it back. I replaced the temp. sensor today, now it goes up 5 degs. each second until it reaches desired temp. (witch actually is much lower) then turns off the gas with desired temp reading staying the same on front panel until I turn it off, then back on, then it will show actual temp. (I verified with a thermometer) light up again, then as soon as the gas lights, it starts going up 5 degs. every second again until reaching wrong temp. again, it won't relight to maintain temp. until I turn it off, then this process starts all over again. Thanks for any help you could give!
    Top Expert:
  • Dacor Master
  • 40,500 Answers
The replacement temp sensor could be defective.
Posted on Mar 03, 2017
  • 5 Answers
SOURCE: Trying to replace heating element - can't retrieve wire
You will have to take the oven out ,Turn off the power and check if the wires are tied behind the oven,
Posted on Oct 04, 2008
  • 25 Answers
SOURCE: I have new HBN 73155 1A Bosch oven. I'm having
if it is a new one must be looked at under wantey
Posted on Aug 25, 2009
  • 2605 Answers
SOURCE: Oven does not reach set temp
What are using to measure temp ? Are you using a grocery store bi-metal or professional thermal probe ? and further to that, how long are you waiting to check temp. after range "beeps" or announces preheat complete ? The bi-metal type thermometers do take several minutes longer to reach actual temp as opposed to the ranges temp. probe. Does this unit have the "hidden" bake element ? That sounds like a huge temp difference. These units do require an additional 10mins of wait time after announcing ("BEEP") the preheat is complete (check your manual, it should confirm this) Elements don't go "bad" it either comes on (amp draw) or it doesn't.
hope this helps.
good luck
Posted on Sep 26, 2009
  • 3463 Answers
SOURCE: oven burns things, very hot on bottom
The temp indicator light goes on and off according to the temp selected.
The sensor referred to is part and parcel of the the thermostat, or temp selector
the fact the light goes on and off, shows that the thermostatt is working, but neccesserily at the correct temp.I maintain that the thermostat that controls the temp is faulty, and needs to be replaced.
Posted on Dec 21, 2009
  • 1340 Answers
SOURCE: I am working on a
So are you saying that the oven does not start at all?The 350 just appears on the display and then pressing enter it disappears?Does it warm at all?If it warms,it is most likely the thermocouple or ASM,both are the same,just varies between makers.If it does not heat at all,it sounds like somehow the temperature setting got switched from F to C somehow,which can happen completely not done by you.Let me know which situation you have and I'll figure it out.Greg
Posted on Nov 24, 2010
My Dacor oven keeps beeping and flashing PRB. How do I stop the beeping?
Most unwanted beeping on Dacor products are due to a bad touchpad... Use your model # and start looking for a replacement , by touchpad I mean a part something like this one: Dacor Touchpad 62678B
Jul 12, 2016 | Dacor Epicure 30" Double Wall Oven,...
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
Dacor Preference RSD30 Gas Range My wife put the
I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
Oct 17, 2011 | Dacor Ovens
How to turn fan to oven
First of all, here is the main DACOR ONLINE SUPPORT page for your model:
And here is a direct link to the ONLINE USER'S MANUAL for that model:
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 10 of the manual for detailed instructions on how to use the various cooking modes of your oven including the convection fan feature.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Jun 13, 2011 | Dacor DO130S Oven
My dacor oven light won't go off & the error message says close the door but the oven door is already closed. this is occurring only in the top oven.
Sorry to read about your problem, I hope this helps you out.
you have a defective door switch
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Dacor Ovens
I think my heating element for the Dacor 6 burner range went
Hi there.
You have faulty oven element. and nothing more serious than that.
Simply disconnect and remove the faulty element, and fit a new one.
Problem solved!!!.
Plz rate my solution.Thanks.
Dec 22, 2008 | Dacor ECS127 Epicure Stainless Steel...
Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
Ovens Logo
52 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
Are you a Dacor Oven Expert? Answer questions, earn points and help others
