Question about Rheem Tankless Water Heater Main Remote Control
2 yr old ecco sense UMC 117 unit flashes 38 beeps and wont give hot water
Have to shut unit off, unplug wait 5 minutes then plug back in turn unit on and it will work for a while before it hiccups again and no hot water...what is problem?
  • Rheem Master
  • 5,089 Answers
1) Copy following link for Rheem tankless troubleshoot, including ecosense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Probably needs new circuit board.
3) Product manual usually give list of required yearly maintenance.
Perform the maintenance, just like changing oil on car, and then service technician is familiar with your water heater and can count on your money each year around Christmas.
4) For independence, reliability, cost, and convenience, don't buy tankless water heater, or any other expensive/complicated water heater that requires yearly maintenance, and generally cannot be repaired by homeowner.
Posted on Jan 05, 2013
  • 244 Answers
SOURCE: My Rheem Pronto model#RTG-74PNV-1 has powered off
Remove power source from the unit. If remote control2.gif is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support2.gif.
If this helps, please indicate so.
Mike//jzklipper@aol.com
Posted on Nov 11, 2009
mrhotandcold
  • 248 Answers
SOURCE: The UMC-117 shuts off during water heat up. What
overheat stat first then check fan best of luck
Posted on Oct 24, 2009
  • 145 Answers
SOURCE: No Hot Water
you can call Rheem
Posted on Jan 10, 2010
  • 244 Answers
SOURCE: model PTG-42PVN
According to the symtoms...sounds like you have a problem with the flow control valve. If less than 3 yrs old, contact Rheem Customer Support at (800-432-8373) and they can an authorized tech in your area to service the unit.
If the unit is out of warranty, I reccommend you still call customer support to find a local technician. Unless you're highly technical/mechanical, this is not a problem you should attempt yourself.
Thanks for trying Fixya.com
Mike...
Posted on Feb 07, 2010
SOURCE: My Rheem UMC-117 flashes 76.
New remote control costs $99/ June 2011
Error 76 is communication problem between remote and water heater.
Open following link for step-by-step troubleshoot, and Rheem tankless resources.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Posted on Jun 25, 2011
Remote is flashing C8 and 76, alternating. I turn the unit off, then back on, and I get hot water for about 10 seconds, then it goes cold and the same error message occurs. Unit is Rheem Main Remote...
Before calling service technician, open following links for Rheem tankless resources including error codes and Rheem chat.
Disconnect wires from remote to see if system stabilizes. Unit will heat to default temperature without remote.
Error codes are considered start-point for troubleshooting.
C8 76 can mean PC board failure.
76 can mean communication failure with remote control
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Jul 31, 2011 | Rheem Tankless Water Heater Main Remote...
I have a problem with my Rinnai hot water heater giving me intermitant hot and cold. The water gets hot and I get in the shower. A few minutes later the hot water stops and I have to shut of the hot water...
We had the same problem - the hot water would only be hot for 3 -5 minutes and shut off, then we had to turn the water off, wait a few minutes, and do it again. VERY FRUSTRATING.
Solution: The Rinnai serviceman showed me the heat-exchanger blower/fan: It was clogged with dust and moths.
Another clue: Our Rinnai was extremely noisy when the heat came on. After the fan was cleaned and replaced, it is nearly silent.
If you are reasonably mechanically inclined:
TURN THE BREAKER / POWER OFF to the unit.
The blower-fan is located in the lower central area of the unit (at least on our unit). If you draw imaginary north-south, east-west lines through the center of the unit, the fan is in the lower-left quadrant. There is a spring clamp securing the black rubber accordian-like tube to the fan. There are two screws that secure the fan to the unit. there are two plugs that connect to the fan, as well as a third air-flow sensor that should be removed. then you can look at the fan unit, as well as the grill on the underside of the heat-exchanger that should be cleaned.
My thought was to go out and get a simple bug-screen, and place it over the air-input outlet vent going outside, but the repair guy said that although it may sound good, if that screen ever gets clogged, or reduces airflow to the Rinnai, then the unit will work harder, or even shut off, giving the same problem.
May 24, 2010 | Rinnai Webstone The isolator EXP tankless...
Oct 10, 2009 | Rheem Tankless Hot Water Heater...
My Rheem Pronto model#RTG-74PNV-1 has powered off for some reason unknown, I turned the unit back on and it supplied hot water for approx. 10 minutes before it started flashing a code [C7]on the remote...
Oct 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rheem tankless shuts down on it's own.
Check to make sure wire is solid copper thermostat wire and not stranded
Aug 15, 2009 | Rheem Tankless Hot Water Heater...
I painted the floor & my hot water heater (Reehm
The water heater is locked out. The following process should reset it.
1. Reapply power to the water heater and wait for 3 seconds for the system self-diagnostic check.
2. Within the first 30 seconds, the temperature dial must be rotated back and forth crossing the 120
degree mark at least six (6) times. This will reset the control and display a normal flash code
(slow blinking).
Mar 22, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem Tankless Water Heater Main Remote Control   Logo
169 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
