Question about Convair Millenia 1000 Air Cooler Fan
Need replacement wheels for my convair miv1000
I would love to get a owners manual for this also
Where can i buy the Ducting hose and the window fittings for Convair Model CM10W
Home Depot will have most common sizes of ducting. If it's a special size, look up Ferguson supply and they will carry what you need
Aug 16, 2016 | Convair Heating & Cooling
Need instruction manual
Hi dgresham28,
Plz try this link..hope it works if not kindly revert with your specific product model no.:
http://www.convair.net.au/convairnew/Convair_Brochure_lo_res_09.pdf
Thanx
Aug 24, 2011 | Convair Portable Air Conditioner
I do not have a user manual for my Convair Millenia Model MI Ul Prod. No. 009100 evaporative room cooler. Where can I go to download one? Not having any luck at the usual sources. Thanks!
I have an Owner's Manual for the Millenia Convair MI that I would be willing to scan and email to thesmiler (problem at the top of the page). Is that possible?
May 13, 2011 | Convair Heating & Cooling
I purchased my convair aircon in 04/08. It has been in storage and I have only just started using it. When cooling it starts to cool then starts beeping and has E1 on the display. this can only be...
E-1 Indoor blower motor mechanism locked or Indoor sensor problem. Rotate blower wheel manually. If not rotate, replace bearing. If motor good, replace sensor.
Jan 03, 2011 | Convair Heating & Cooling
What do i need to do for a convair classic portable cooler, to care for/service it? (as it is smelling at the moment!) Convair Classic M800CAUS; Product no. 007410
we always used 1 baby bottle steralising tablet to sterlise them , best to do this outside to avoid the chlorine /swimming pool smell in the house
then flush all the solution away and replace with fresh water ( the solution is quite corrosive and cause rust ) , also check your pads for dust/limescale , you may well need to replace these
Nov 13, 2009 | Heating & Cooling
Looking for a manual for solid fuel heater
Since the unit is only a few years older than I, I'm going to give you the contact info for the states. They might be able to pull up a manual on some micro fisch somewhere. I wish you all the luck on this one. This is the name of the Convair brand company here in the states.
Seeley International (Americas) Corporation Head Office and Pacific Coast/
Southern/Central American Sales
1202 North 54th Avenue,
Building 2, Suite 117
Phoenix AZ 85043
USA
Ph: (602) 353 8066
Fax: (602) 353 8070
E: americasales@seeleyinternational.com
Mar 22, 2009 | Convair Arctic Breeze 1500 Air Conditioner
Convair Millenia 1000 Air Cooler Fan Logo
16 people viewed this question
Top Convair Dryers Experts
Dan Webster
Dan Webster
Are you a Convair Dryer Expert? Answer questions, earn points and help others
