Question about D-Link Xtreme N DIR-655 Wireless Router
Avaya VPN phone behind a DIR-655
Phone will not connect to VPN tunnel behind the router. It will when connected to the Cable Modem directly.
Suggestions?
  • Anonymous Feb 20, 2009
    Avaya IP Hardphone doesn't work behind Dlink DIR 655
  • sdean001 Mar 23, 2009
    On modem cable works fine but when coneccted to the DIR-655 the VPN tunnel is not closed.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 167 Answers
- Logon to the configuration page of the router
- Go to Advanced tab
- Select Firewall Settings at the left side
- Uncheck the boxes under Application Gateway Level at the bottom part
- And Click on Save Settings at the top.
Posted on Mar 09, 2009
I used to connect VPN but suddenly DIR-655 is having probelm connecting to my office VPN. I can connect of any other web sites except VPN connection
Using VPN proxy http://www.bestcheapvpnservice.com/cheap-vpn-proxy/ will enable you to unblock websites and bypass blocking easly with simple software just pressing connect to open blocking and disconnect to block sites again
Jan 10, 2011 | D-Link Xtreme N DIR-655 Wireless Router
HN9000 won't pass remote services
On the Router check if you have UPnP enabled, if yes then Disabel it that should fix the NAT issue and then you need to open the port number 1723,3389. Once these ports are opened then you will be able to access it on the VPN and Remote Desktop Provided you have a WAN IP Address from your ISP. also check the Firmware of the router if its updated or not.
Mar 26, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Problem connecting to VPN (PPtP) via DIR-655
pimrakers
Since it work when directly connected to your modem then most likely it is an IP issue. With VPN you router can not be in the same subnet as the one you are connecting too. So alot of places do not change the IP's the equipment unless they have to you just got lucky and a router with the same default settings. If you change the IP address then you should be able to connect. Note you should only have to worry about the last 2 number sets. Example if your routers IP is 192.168.1.1 then I would change it to 192.168.5.1. Just remember what you changed it to. Also you can use any number between 1 and 254.
Let me know if you have any more problems or questions.
Issken
Jan 15, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Computer will not connect to internet through router
check the connections between the router and the modem either cable or dsl or whichever
and change the setting in the router interface so you know what the ssid is being broadcasted and the network key
Jul 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
VPN drops when using a D-Link Dir655 router
Hi! Try to logon to the configuration page of your router. then go to Advanced tab and click on Firewall settings on your left side.
At the bottom part you could see the Application Gateway Level section, Uncheck all the boxes under that and click on Save Settings at the top.
Mar 06, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Want to make a network connection between two office 800 meters.
Buy 2 DIR 130 VPN routers and connect the two office networks via LAN-LAN VPN tunnels.
If you have the time and skills you can build two IPCOP firewall routers and connect via VPN tunnels (http://sourceforge.net/apps/trac/ipcop/wiki)
Mar 03, 2009 | D-Link (DIR-130) Router
Dir 655 will not install
You should not need to enter any of that information.
The router will find the internet on it's own, once the ethernet cable is connected and the router is turned on.
Press the reset button at the back of the modem for 20-30 seconds, this resets the router to square 1. Power down, wait 30 seconds, then power back up. You should have internet connection to the router, which can be tested by connecting another ethernet cable from the router to the ethernet connector on your computer.
Reply back what your objective is in getting to the routers setup page.
Feb 04, 2009 | D-Link Xtreme N DIR-655 Wireless Router
IP Phone available for IP office?
Hi TexasTom,
I'm not quite clear on your problem. But I think what your describing would be difficult to archive. That's if I understand you correctly!
Perhaps what you might want to consider is this sort of device. It allows to normal (PSTN) telephones to be used as either SIP (VoIP) or as normal PSTN telephones. It does not require a PC once it's been set-up.
Hope this helps.
Kind regards,
Spare head 2.
Jan 04, 2008 | Avaya 5610 IP Phone
D-Link Xtreme N  DIR-655 Wireless Router Logo
1,067 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
