Question about GE GTS22WCP Top Freezer Refrigerator
Water in freezer and on top shelf of frig and under veggie bins
jumptrout51
  • 3361 Answers
SOURCE: I HAVE A GE PROFILE REFRIGERATOR TOP FREEZER,
Two separate problems here.
One; remove the ice maker, then remove the back panel from the freezer. The defrost drain is probably frozen . It will have to be thawed. Then run a 1/4 cup of bleach through it.
Two. Water on the shelves sometimes is caused by the frozen drain line referred above.
But can be from a poor door seal on the fresh food compartment.
Check the sides and bottom of the door seal. It may have pulled loose from the plastic liner.
If it is warped and damaged it must be replaced.
Posted on Feb 23, 2009
  • 531 Answers
SOURCE: bottom of freezeer and fridge are cold, but top areas aren't?
you have defrost problem or check see if condenser fan working
Posted on Apr 07, 2009
SOURCE: Water leaking along back interior to bottom under & over veggie bins
Sounds like the drain to the drip pan is clogged -- maybe with ice.
Defrost water runs down to a drain in the bottom of the fridge and into a pan underneath where it evaporates.
Sounds like the defrost water is not reaching its final destination.
Here's the way the same problem was solved earlier today:
For those who have this problem with this model: The drip pan is in an open space on the back side of the refrigerator. There is a rubber spout that empties into it. But to clear clogs...you must take out the shelves from the freezer, unscrew and remove the back panel on the inside of the freezer. There you will see the water exit. Boiling water cleared it out.
Posted on May 29, 2009
aasc
  • 1606 Answers
SOURCE: GE REFRIGERATOR SPILLS OUT WATER COLLECTED BELOW
Remove the food from the freezer . Remove the rear freezer panel , inside the freezer . At the base in the rear , use a hair dryer and defrost (you'll see a drain hole possibly in the middle of the drain ) . Defrost drain hole until hot water can be poured and go thru the hole . I use a small hose to blow thru the drain hole to remove any debris which could have accumulated inside the drain line .
Posted on Aug 02, 2009
  • 100 Answers
SOURCE: Ice Melting
ok check the door gaskets they must be toushing forming a compleate seal nothing else is acceptible also there is a possibilty that your ice maker heater is stuck in the on position.also these units are known for a having a bad control boared in the back
Posted on Aug 09, 2009
Having problems with defrost, water in veg. bins
Sounds like a blocked drain and a thermostat faulty or faulty sensor.Sensor will have to be replaced and drain unblocked.
Aug 19, 2015 | Refrigerators
Have whirlpool ET18NK/ET18NM refrigerator-food freeze in the center of frig and veggie bins--water collects in bottom of frig to overflowing if I don't keep a container in middle of top shelf to catch ...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 27, 2011 | Refrigerators
Water is pooling under the veggie bins- watere even came down via freezer door gasket to the floor. I have been noticing water in the right meat bin and in veggie bin, and under them for 2 weeks. most of...
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 12, 2009 | Liebherr European Right Hinge Fully...
Lots of water pooling on top shelf of refrigerator, toward the back. It is not condensation. Water is apparently dripping down the inside back, as I noticed it has pooled under the veggie bins as well. ...
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike
Jul 23, 2009 | Whirlpool Refrigerators
Water leaking into the bottom of frig. going under veggy crispers
Look for the drain trough on the bottom of the freezer and pour a mixture of baking soda and warm water down.
May 07, 2009 | Refrigerators
Water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool refrigerator top freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Apr 07, 2008 | Refrigerators
Refrigerator/ water collecting under veggie bins
sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under unit.so you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Mar 21, 2008 | Refrigerators
Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Sep 11, 2007 | GE Profile PSI23NCR Side by Side...
GE GTS22WCP Top Freezer Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
