Question about Nintendo 64 Console
N64 powers up but no sound or video
Red light nothing else
  • Nintendo Master
  • 429 Answers
Nintendo 64 - Blank Screen Troubleshooting
Quick Tip:
If your system is connected using AV cables and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
Make sure the system has power. If you don't see the red power light when you turn your system on, go to the No Power Light instructions.
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position. (Inserting the game with the Power ON will result in a blank screen.)
Check under the Memory Expansion door (on the top of the Control Deck) to verify that the Jumper Pak or Expansion Pak is still inserted. If one is not inserted, slide the Power Switch to the OFF position, insert the Jumper Pak or Expansion Pak and slide the Power Switch to the ON position. Simply pressing reset will not solve the problem. You must turn the power off and then back on.
If the above steps do not resolve the problem you are experiencing, there may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (how to buy replacement parts). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If this does not resolve the problem you are experiencing with your system, your system may need to be replaced. For more information on what options are available, please click here.
Posted on Jan 10, 2013
meeknotweak
  • 341 Answers
SOURCE: n64 red light
Try blowing out the Game slot on the console, and then blow out the large metal prong on the bottom of the game. Also try waiting a little bit, your nintendo might need to cool down.
After a long time n64 games fail to start up on most attempts, so keep trying, it will start up eventually.
Posted on Nov 24, 2009
  • 12 Answers
SOURCE: My N64 does not play games... red ight... help plz...
your chords are not hook up.
Posted on Dec 20, 2009
SOURCE: N64 will not play on new TV and Stereo Reciever
Ok well, I don't guarantee this will work but its worth giving a shot. You know the controls like V1 2,3,4,and 5? That might be a clue because all that stuff works the stuff that's plugged into the back of the TV. They have extra cable outlets or whatever you'd like to call them in the back of the TV. So plug the n64 into the back of the TV. Then it should work someway. You might be able to figure out it from there if it still doesn't work. So don't plug it into the cable box or VCR anymore. Hope that helps.
Let me know if it works after that.
P.S. I have a n64 too, and I just got a new HDTV also. I tried to see if my n64 works on it but it doesn't so I think I might do the samething that I was just explaining
Posted on Feb 03, 2009
  • 13 Answers
SOURCE: hooking up my n64, sound works, no video
make sure the yellow video wire is plugged into the correct port
Posted on Nov 02, 2009
  • 32 Answers
SOURCE: The red light comes on for my n64 but nothing happens
Hi there, At a guess Id say the contacts on the Game Cartridge are dirty, you could try a couple of things:
  1. Blow on the contacts on the Cartridge and then push firmly into the N64 - Test game, if doesn't work move to next step
  2. Get some rubbing alcohol solution and a cotton bud and gently clean the contacts on the cartridge - Test game, if doesn't work move to next step
  3. Get some rubbing alcohol solution and a cotton bud and gently clean contacts in the N64 console cartridge slot - Test game
Cheers
Posted on Apr 03, 2010
My n64 red light will not turn on every single time i go to turn it on nothing happens its just blank and nothing shows uup. does anybody know how to help plzzz help me??????????????????!!!!!!!!!!!!
you better check the power supply of your unit... i think your power supply burnt out so the red light (indicator light) wont turn on....
Jun 05, 2011 | Nintendo 64 Console
N64 power light comes on, but nothing comes on the screen.
It appears that your power supply is fine (you still get a power light) however your internal game board has a problem. I realize you said that you have eliminated all the other components (very smart process of elimination) so the only thing that has not been swapped is the console itself. I think you've already come to the conclusion that the N64 needs to be repaired, and you just need to hear it from someone else. Unfortunately, the console needs to be repaired. Again, you did a great job isolating the problem, so you've done all the hard work.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jul 07, 2017 | Nintendo 64 Console
Cheers
Apr 03, 2010 | Nintendo 64 Console
N64 red light
Nov 24, 2009 | Nintendo 64 Console
maybe it's just the T.V I mean the N64 is like 10+ years old and you're trying to get it to work in a new T.V! I reckon that your best bet is to buy an older T.V to play it with or get an emulator e.g PJ64 on your computer and then you can still play your games
May 31, 2009 | Nintendo 64 Console
N64 light comes on, but nothing comes on screen
Make sure that the game you are trying to play is free of dust and other obstructions.  I know that the label on the back of the game says that you should never blow on the edge connector, but it doesn't harm the game. (Trust me I've been cleaning the connectors for years now, and it hasn't been damaged.  After you throughly rid the game of dust, do the same with the edge connector on the N64.  Simply hold the opening open and blow the dust out.  This should work.   Please give feedback!! Hope this helps!!
Apr 16, 2009 | Nintendo 64 Console
Is my n64 broken?
You might have a dead N64 bro. Alot of quality games on that system too.
You can usually find them on Ebay for fairly cheap
Feb 07, 2009 | Nintendo 64 Console
N 64 does nothing
Well its a power supply failure symptom for this to happen now.
Apr 26, 2008 | Nintendo 64 Console
Nintendo 64 Console Logo
41 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
