Question about Hoveround MPV5 Electric Wheelchair - Used Power Chairs
Where is the circut breaker on a mpv5 hoverround
  • matthewskatr
    matthewskatr Jan 04, 2013
    my hoverround will not trn on think it msy hsve tripped the breaker
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 53 Answers
Check the fuse on the wiring harness on each battery.
Posted on Sep 14, 2014
My hoverround barely turns left and makes weird noises when it goes
This is almost certainly either bad motor brushes on the right motor, a bad right motor connection, or a bad right motor itself. Check the motor brushes, if the look good(good springs, no discoloring, etc.) Then you need a multimeter to check the motor connections to isolate the problem.
Mar 23, 2013 | Hoveround MPV5 Electric Wheelchair - Used...
14 in. saw with leeson motor
To start with what size circut are you trying to run the saw on? What ever the amperage is on the saw will draw almost 3 Xs the amperage rating of the saw on start up. If the circut is a 20 amp the breaker should hold long enough to start the saw. Also the saw should be the only thing running on the circut at the time. A 1-1/2 hp motor is a good size one aproximately 15.2 amps If you circut breaker is twenty amps and you still pop the breaker you may want to convert the motor to run on 220 volts as that will drop the load to approx. 7.6 amps Youcan run the saw on a 20 amp. 220 volt circut with no problem unless there is a problem with the motor. If the outlet is the only outlet on the circut it is an easy change to convert the circut.
Mar 02, 2013 | Target Portable Masonry Saw PS1411S...
When the air conditioner runs after a while it flips the breaker even if its on its own breaker.
Hello
Either the circut breaker is too small or there are too many other things on the same circut as the a/c.
Another possible solution is the breaker itself may be bad.Or the compressor in the a/c unit is going bad.
Usually a 20 amp breaker will be good for a window a/c unit under 16000 btu.
Jul 21, 2011 | Heating & Cooling
It works only 10 min and then stops the energy in the house. whats the problem?
Hello
Either the circut breaker for that receptacle is too small,or you need to unplug somthing in the washine machine circut,lamp,iron, what ever.
If it continues you may need to upgrade your circut breaker to a 2o amp.
Apr 04, 2011 | Washing Machines
Compressor will not start without tripping breaker?
Circut breakers trip due to a short circut or an overload. In this case the likely cause is an overload. If your compressor is drawing more amperage than the breaker is designed to allow, the breaker trips for safety. Possible solutions. Try using a different outlet with fewer appliances or tools on that circut. If the outlet you are using is on a circut that also has lighting, appliances etc, each item is drawing amps, the addition of the compressor to the circut is pushing the amp limit over the top. You can also try a heavier duty extension cord. If you are using an extension that is rated too low for the required amperage your breaker will trip. If you are not using an extiension cord you may need to talk to an electrician about adding another circut to service your tool and garage needs.
Another possiblity is that your service is not upgraded enough. If you have a 60amp service for the house you might want to talk to an electrician about upgrading to 100amp or more.
Jan 04, 2011 | Garden
How can I get a manual for the Hoverround MPV5?
If the power chair was stored for a while, the batteries may have gone bad. There is a gel inside them that needs to be put on a current regularly or it will solidify. When you connect the charger, you get a green light because it senses the batteries are full; unfortunately they are full of crud, not power. Try replacing the batteries to see if that solves the issue. You can probably take them to an auto parts store or Interstate Batteries to have them volt tested. The type of battery you need is a U1, 12volt, 33amp and you will need 2 of them.
Apr 29, 2010 | NRS Hoveround MPV 5 - Used Power...
I have a Homeline Load Center circut breaker Catolog # HOM48l125GRB, which was installed for my spa. Each summer the spa is drained and the circut turned off. I turn it back on in the fall. However, this...
You have 1 of 2 problems #1 the breaker overload element is bad=replace breaker, #2 You have a shot somewhere in your line feeding your spa, make sure you have power to the line side of your panel/breaker. hope this helps you...
Oct 03, 2009 | Square Homeline Circuit Breaker
Have hoverround been in storage and tyring to charge
When the batteries sit for more than one month without being used they die. You need new batteries. The batteries are a 12 volt deep cell. U-1
Jul 21, 2009 | Health & Beauty
Hoveround MPV5 Electric Wheelchair - Used Power Chairs Logo
156 people viewed this question
Top Hoveround Health & Beauty Experts
Lawrence Oravetz
Robin Hill
Robin Hill
Colin Taylor
Are you a Hoveround Health and Beauty Expert? Answer questions, earn points and help others
