Question about Frigidaire Washing Machines
I need a replacement seal for frigidaire Affinity, ATF6000FS1
Drum to frame seal
4 Suggested Answers
Jahn27
  • 1554 Answers
SOURCE: I have a Affinity frigidaire front load washer and
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Posted on Nov 13, 2010
marka19
  • 1430 Answers
SOURCE: i need to replace my
Try this link it should help Door switch replacement
Posted on Mar 14, 2011
Jahn27
  • 1554 Answers
SOURCE: Hi, I need a replacement
You are referring to the door strike (item 14 in the diagram) shown below which is actually part number 134456600.
Frigidaire Affinity ATF6000FS1 Cabinet and Door Parts Diagram
Posted on Aug 25, 2011
What are the cubic feet for the affinity atf6000fs1
Hello Friend, this is Z. That's a great question!
I show that your Frigidaire Affinity washer (ATF6000FS1) has a total capacity of 3.5 cubic foot. Hope this helps! If there is anything else that I can help you with, please feel free to reconnect.
Jun 12, 2014 | Frigidaire Affinity ATF6000F Front Load...
How to change seal on atf6000fs1 washer
Good Afternoon Friend,
I understand you want to know how to replace the seal on your Frigidaire washer, model# ATF6000FS1. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance, and should be able to replace the seal with ease. Hope this is helpful.
-Best Regards-
WP
Jun 11, 2014 | Frigidaire ATF6000ES Front Load Washer
Atf6000fs1
Hello partridgemcl - From what you are describing the strike is the part that engages the door switch. It is mounted to the door. The part number is 134456600, MSRP: $6.12. The new seal that you are referring to is the bellows, boot. The part number is 134740900, MSPR: $125.37. You may purchase the part(s) directly from the manufacturer or through a part distributor in your area.
Mar 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire affinity front load washer ATF6000FS1 wont fill with water
Hello hitman43 - Are the house valves turn on fully? Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Contact a professional to move forward accurately.
Jan 01, 2013 | Frigidaire Affinity ATF6000F Front Load...
Affinity dryer burning clothes
Probably a seal around the drum or blower needs to be replaced.
Affinity service manual
Nov 24, 2012 | Frigidaire Affinity FAQG7011KW 7.0 Cu. Ft....
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
