Question about Stanley Bostitch BT1855K 18 Gauge Brad Nailer
BT 1855 wont shoot nails
Air compressor and nail gun are both fairly new. The air comes out, but no nails come out. Have tried tightening everything up and moving the brads higher and lower in the channel. Any help would be GREATLY appreciated!!!
5 Suggested Answers
  • 1388 Answers
SOURCE: bostich gun problem
If the piston/driver is broken, the gun will fire however nailing will not take place because the piston will jam in the cylinder. Sometimes the cylinder will also crack when the driver goes. If the piston is not broken but stays down, then check the cylinder check valve, worn lower bumper, bent driver or cracked cylinder. 18 guage nailer has a very thin driver which will easily bend or break. Parts however are not expensive.
Posted on Nov 25, 2008
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
  • 384 Answers
SOURCE: bostitch nail gun model n62fn when hooking up air
It is passing gas.
Posted on Sep 02, 2009
rowdy45176
  • 2176 Answers
SOURCE: My brad nailer will not shoot any nails. When I
it sounds like the piston/driver might be stuck or the firing valve is malfunctioning. there are 4 screws to remove the top cap and you can see if the driver is damaged. Also before removing check to make sure there is not a nail jammed in the nose assembly. This tool is good for breaking the pin on the piston.
Posted on Oct 16, 2009
When i tried to use the nail gun, it only produce a little pop and no nail came out
Try spraying Carburator cleaner to clean out the air chamber on the gun, and where the nail comes out
Sep 26, 2015 | Air Tools & Compressors
Why might my nail guns not work?
Have you lubricated either nail gun? If not, go to Home Depot and get a bottle of air tool oil. It's in tools by the compressors. Disconnect the air hose from the tool. Pour about a teaspoon of oil into the air inlet of the tool. Reconnect everything and try it 10-20 times with no nails in the tool. Then try it with nails. Good luck.
Sep 14, 2015 | Porter Cable Tools & Hardware - Others
My airace framing air nail gun blows air when i try to shoot it
Look for an O ring kit,,many times the firing cap seal splits thus loss of air
Mar 30, 2013 | Air Tools & Compressors
Does the brad nailer only use 2" brads or cam smaller nails be used also
Most nail guns are labeled with the longest nail/brad they can shoot but are capable of shooting shorter nails/brads. There should be a data sticker on the gun, usually on the magazine rail, or at least in the manual that tells you what pressure to operate the gun at, what guage brads the gun can shoot and the size of brads from shortest to longest it can handle.
Oct 22, 2010 | Sears TNT 3 gal Air Compressor with 2 in...
16g wont shoot nails. bottom flat piece comes out
You broke the "hammer" you can open the housing and replace it, fairly simply. You can buy replacement parts at most large scale hardware or tool stores. The task takes about 10 min, and some simple hand tools.
Jan 03, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
Can I change the pressure on the nail gun?
Hi there .
First check if the nail gun have a adjustment screw . Depending on the brand could be in the front where the nails comes out or by the trigger. Second check the compressor by the air hose connection you should have a regulator valve with a gauge and see if you getting the right air pressure .
Hope this help
Aug 29, 2009 | Air Tools & Compressors
Paslode air framer not sinking some nails
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
Aug 11, 2009 | RTO Paslode #650027 2500CT Placement Nail
How to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Aug 27, 2008 | Mountain Air Blow Gun with Rubber Tip
Stanley Bostitch BT1855K 18 Gauge Brad Nailer Logo
254 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
