Question about Craftsman 829693 Motor
Craftsman WEt Dry vac motor - Craftsman 829693 Motor
reddevil6
  • 1673 Answers
SOURCE: 3.0 h.p. wet/dry vac
Check the motor brushes, either worn down or dust is keeping one of them from laying on the armature. The other would be a bad motor.
Posted on Jan 14, 2008
reddevil6
  • 1673 Answers
SOURCE: need replacement manual
Go to Sears.com, click on the parts link, put in your model number, a parts list will come up, if you manual is available, you can click on it to buy it.
Posted on Jan 22, 2008
SOURCE: craftsman wet/dry vac
It is supposed to have a round plastic plate and a plastic handle with a nut made in it that tightens against the plate to hold the filter on
Posted on Feb 27, 2008
MrScary66613
  • 1990 Answers
SOURCE: Craftman Canister Wet/Dry vac- Motor just stopped working
It is Repairable But, The parts will cost almost as much as a New Vac. I would just get a New Vac and save the Hastle and the Cash. The choice is all yours Though. Please Rate My Response! Thanks!
Posted on Feb 07, 2009
bozcro
  • 867 Answers
SOURCE: Wet/Dry Vac Leaking
are you using a water , foam material filter?
Posted on Aug 01, 2009
Who made craftsman wet/dry shop vacs in the late 70's?
here is a link that may be helpful
http://vintagemachinery.org/craftsman/manufacturers.aspx
it details the manufactuars that craftsman used based on then model and OEM number
Feb 08, 2013 | Vacuums
I bought my first craftsman 9 gallong wet/dry vac - i do not know how to operate it and I don't want to break anything. I have a pamphlet but it is still confusing. can I pour a few gallons of water into...
Hello again.
When it says wet vacuuming, it means that the vacuum will pick up water, not dispense it. When you are using the vacuum to pick up water, you'll need to remove the paper filter element under the motor, inside the canister, to avoid ruining it. When the filter is removed, you will see a plactic ball inside a cage under the motor. It's purpose is to float up on the surface of the water being vacuumed up, and prevent the motor from getting water into it. You'll be able to tell when the canister is full; the noise the vacuum makes will change and sound higher. Also, the suction at the hose will quit. At that point, shut off the vacuum and drain the water.
Be sure to replace the paper filter when you swap back from liquids to solids.
Best regards, --W/D--
Apr 02, 2011 | Craftsman 17026 Wet/Dry Vacuum
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Do I take the filter off when I am vacuuming up wet things?
If it's a paper filter, take it off. If it's a cloth filter that can be washed and dried, leave it on. Your machine will have a float to close off the suction when the tub needs emptying. Anyway, air from the tub only goes through the turbine, not through the motor itself, so you need not worry. It's good practice to run the vac dry for a few minutes after using it wet, just to make sure the turbine's dry.
Aug 15, 2009 | Craftsman 17026 Wet/Dry Vacuum
Trying to remove motor from wet-dry shop-vac.Remove all the screws,but doesn't seem to want to come out. Help!!
Hi Dan:
I am not familiar with this model but some of the consumer wet vac models are build with a module and motor as one part. You will need to replace the entire module
Aug 08, 2009 | Craftsman Vacuums
Craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Apr 14, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Feb 07, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
Jan 13, 2008 | Craftsman 17765 Canister Wet/Dry Vacuum
Craftsman wet/dry vac
Sep 01, 2007 | Craftsman 17026 Wet/Dry Vacuum
Craftsman 829693 Motor Logo
26 people viewed this question
Top Craftsman Vacuums Experts
downhille
Andrew Taylor
Andrew Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
