Question about Kenmore Washing Machines
MDEL 796 40512900
RINSE SPIN CICLE STUCK ON AND RELEASE LITTLE WATER SPIN 2 OR 3 TIME AND STOP AND DO AGAIN AND AGAN AND DO NOT DRAIN
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
SOURCE: I also need the answer...
where is the lint trap located
Posted on Apr 07, 2008
drsn
  • 42 Answers
SOURCE: Washer won't spin or drain
whats the make of your washer, if its the older models it might be the lid switch, switch might be defective, but i still need the make/brand of the unit to be more specific.
Posted on Apr 14, 2008
michiganfan9
  • 179 Answers
SOURCE: Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Posted on Dec 29, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
F-21 code several times. We clean the pump. Start again the rinse/drain and spin cicle, and now present sd code and later f-21 code. What we need to do.
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 04, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
My Kenmore Elite total care system gets stuck on the Pause Cool Down step and then again on the spin setting. It doesn't even drain after rinsing.
The washer has a temp sensor for the rinse cycle , so just set the temp to warm water and it will stop getting stuck, because it wants the water to be warm when it rinsing ,ok hope that helps you! Ericc
Jul 03, 2010 | Kenmore 24032\24036 Top Load Washer
Washer won't drain or spin
you need to check the water pump... it may be clogged with detergent or something to that effect.. or just replace the pump itself..
Oct 11, 2009 | Washing Machines
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Dec 06, 2007 | Washing Machines
Kenmore Super Capacity stuck on rinse
Krom, sounds like the machine is syphoning. Check the drain hose and make sure there is a air gap and that it is not too far down the standpipe or drain. To test it hold the drain hose right at the drain top and see if the problem stops...Catriver...post back.
Jan 18, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
