Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell proheat 2x carpet cleaner when the switch is turned on the brushes rotate fot 2 seconds then STOP ,, iIf I turn it off and on again ithe brushes will rotate for 2seconds and STOP again ?? brushes rotate for
  • Official Brand Answer
  • 315 Answers
Hey, sorry to hear you're having difficulty with the brushes. Here's a quick link to troubleshooting steps.
http://www.bissell.com/FAQDetail.aspx?id=1128&cid=ccsocial
Posted on Jan 07, 2013
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Bissell proheat 2x carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 04, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My bissell proheat 2x dual dirtlifter is not succioning very well then the carpet smells
We have several parts here for the Proheat 2X,
Proheat 2X Shampooer Shampooer Parts
It may be a clog in your tank, preventing the water being sucked back up. Check your tank and tubes for clogs or damage. Make sure the brush is still rotating and the belt is not broken too.
800-775-6586
GoodVac com
Feb 26, 2015 | Bissell 2X Proheat 9200 rug cleaner
I am trying too use my Bissell Proheat 2X, but the brushes will not rotate. What is wrong?
1. Can you hear the electric motor in the base unit going?
2. You may have a broken drive belt.
Type the following link into your browser. It will bring up the user guide to the Model 9500p upright ProHeat 2x.
Sep 21, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brushes not rotating
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
45wtw
Jun 21, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Anyone know why my Bissell Proheat 2X Turbo Model 9300's brushes won't turn anymore
If the Brushes don't rotate, & you have two brushes; 1). Turn unit on side. ( Make sure unit is up-pluged) 2). Rotate the front brush roller, if the second roller moves at same time, 3). Locate a small ribbed belt that goes from the further back roller, to a small ribbed pully. (Gates belt #177-3m5) ( on side under a clear cover) The belt may not be broken, but may have carpet fuzz / lint covering the belt ribs, causing the belt to slip. If that belt is OK and you find that the small pully doesn't turn the belt/rollers, the problem is with a small internal direct drive motor, that drives the brush rollers. At this point return the unit, as Bissell has a design defect & is using cheap parts.
Nov 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
We have a 2x brushes bissell carpet scrubber. Do
heatman101
x
Aug 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
heatman101
May 30, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Clean Shot brushes do not turn, belts in place.
heatman101
rgh
Apr 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. petedcurtis@gmail.com
Apr 18, 2008 | Bissell Vacuums
Bissell proheat 2x
Check the brush motor, I have had to replace of few of them. If the brushes aren't turning, this could be the problem.
Apr 18, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
416 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
