Question about Magellan Battery for RoadMate 2145T-LM, 2136T-LM, 2120T
Reset magellan roadmate 2145 - Magellan Battery for RoadMate 2145T-LM, 2136T-LM, 2120T
  • 3 Answers
SOURCE: Magellan roadmate 300 wont turn on!
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
Posted on Jan 26, 2008
  • 54 Answers
SOURCE: Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Posted on Mar 10, 2009
  • 1111 Answers
SOURCE: My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
Posted on Jun 15, 2009
  • 1111 Answers
SOURCE: no programs work in magellan 300 roadmate
your manual is here http://magellan.cachefly.net/manuals/MRM_300na_en.pdf
Posted on Jun 17, 2009
  • 184 Answers
SOURCE: reset button for a magellan
Hi allen,
Magellan RoadMate models 1340, 1440, and 1470 are normally reset as follows:
The reset button is located on the right side of the unit. Press a blunt object like a long-shaft ballpoint pen or a cut off toothpick
into the small hole and hold for approximately 15 seconds. The unit should do a fresh reboot. Sometimes these GPS units can be reset by holding the Power button down for 10-15 seconds to completely shut the unit down. Then, do the same procedure for 10-15 seconds again, to power it back on.
Also, here's another procedure you really only try as a last resort, if the unit is on, but acting up with various menus and functions. Use this very carefully...
While on the main Menu Bar at "System Settings", tap the left corner twice, right corner twice, left corner once, and finally, right corner once. You will see a 'Hidden' menu with a "Reset for first use". Press that option and the unit will perform a hard reset. Hopefully, you can continue all you setups from this point.
Also you can download a complete manual from this link:
http://www.magellangps.com/assets/manuals/Magellan_RoadMate_1440_EN.pdf
The manual won't tell you all these little tricks, so it might be a good idea to make a hard copy of these notes (in case you ever need them again...lol). I hope this helps. Please let me know how it turns out, and contact me if you need further help.
Regards, Bill
Posted on Sep 17, 2010
How do you reset a magellan roadmate 1220?
As a general rule, for Magellan RoadMate models the RESET BUTTON is on the right side inside a small hole; the use of a pointed object (tip of a pencil, a ball-pen, etc.) is required to apply pressure on this button in order to perform the RESETTING PROCEDURE.
You may also can try to hold down the POWER BUTTON for 10 seconds to power off the device; then repeat the same procedure (holding down the POWER BUTTON) for other 10 seconds to power on Magellan RoadMate.
Mar 08, 2011 | Magellan RoadMate 1220 GPS Receiver
My magellan roadmate 1440 will not turn on? Is
get a new one.. no way to fix unless u get a new battery
Dec 18, 2009 | Magellan RoadMate 1440 Car GPS Receiver
Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
  1. [PDF] Magellan User Manual 3519k - Adobe PDF - View as html The Magellan RoadMate 800 is a vehicle ... segments totalling 360 degrees. Starting at the Prime Meridian (which is ... 11.2 Resetting the Magellan RoadMate ...www.magellangps.com/assets/manuals/MRM_800NA_en.pdf
  2. Magellan RoadMate 360 Manuals, Support and Troubleshooting - GPS Free download of Magellan RoadMate 360 User Manual. Troubleshooting ... Resetting the Trip Computer " • Viewing a Saved Trip Report " • Deleting a Trip Report " ...www.retrevo.com/support/Magellan-360-GPS-manual/id/421ag200/t/2 - 109k - Cached
  3. Magellan_RoadMate_360_North_America_Manual Documents_and_Forms ... Magellan RoadMate 360 North America User & Instruction ManualGet access the the ... Resetting the Trip Computer. Viewing a Saved Trip Report. Deleting a Trip ...store.payloadz.com/str-asp-i.388383-n.Magellan_RoadMate_360_North_America_Manual_Othe... - 189k - Cached
Sep 18, 2009 | Magellan RoadMate 360 GPS Receiver
Magellan roadmate 1430 calibration is wrong
try a hard reset again using a paper clip, insert it in the little pin hole on the side to reset the unit. if that fails, get the 3.12 update (if you havent already) off the magellan site..you must register the unit with magellan before you can download the update.
Jul 02, 2009 | Magellan RoadMate 1430 GPS Receiver
May 27, 2009 | Magellan RoadMate 1400 Car GPS Receiver
Magellan roadmate 1412
Try the reset button on the side above the plug in.
Jan 14, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Magellan roadmate 3000t not working properly...
This happened to me, I had to send it back to Magellan for repair.
Mar 12, 2008 | Magellan RoadMate 3000T GPS Receiver
Magellan Roadmate 360 reset
Called Magellan tech support, According to them you can't delete previous addresses, the unit will just override old destinations as you put in new ones.
Dec 01, 2007 | Magellan RoadMate 360 GPS Receiver
Magellan Battery for RoadMate 2145T-LM, 2136T-LM, 2120T Logo
114 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
