Question about NuTone 36" Allure Range Hood WS1 Series Replacement Aftermarket Ducted
Range hood is blowing air into the kitchen - installed wrong?
Why are there vent openings on top of hood? Shouldn't all air go up and not into the kitchen?
We have a vented kenmore range hood that is vented thru a pipe (out the top of the hood) to the outside of the house; air comes out the top of the hood and blows into the kitchen. why is air blowing out...
Sorry to read about your problem, I hope this helps you out.
you may have a clog, in the vent pipe, not uncommon in the winter for wild things to build nest..
their is also a air damper plate, that might be stuck, this damper prevents outside air from blowing back in
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Kenmore Kitchen Ranges
Not sucking up steam or smoke
Have you tried changing the filters, they could be clogged.
Dec 08, 2009 | KitchenAid KWCU205HSS Kitchen Hood
Do vented range hoods blow air into the house?
sound like not installed right,most hoods are convertible and the blower must be rotated to vent outside. Hopes this helps,please rate my solution :)
Jun 25, 2009 | Kitchen Ranges
Kitchen hood not venting outside
check to see if the dapper is opening. that is piece of metal in the flue that keep the air from the outside coming in or check if there is something plugging the top part of the flue on the roof. plus you can go roof and look down and see if there is anything blocking it.
Jun 21, 2009 | Kitchen Ranges
Venting hood to outside wall.
install ducting along with closing flap (so outside wind does not blow in) and power first !
Jan 25, 2009 | Jenn-Air JXT8142ADS Kitchen Hood
Downdraft
I would double check that the installer used the correct vent hood outside. The correct one has a spring that keeps the outdoor flap closed when not in use. Cleaning the outdoor flap area may also help it seal a little better. Even if the right hood was installed, you might check to see there is a spring present (or signs that there was one.
I have never had air blow out the downdraft, but I do feel cold travel to the fan unit which makes the floor cold in front of the range.
Jul 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Air blows thru the Front of the fixture
on theese if your going to vent them out the top you have to turn the fan housing so the front is vent is blocked if i remember right
Jan 10, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Kitchen hood
Yes you can , usually they got hole on top too , just make sure when its done that the air is going out and it will be fine . I
Aug 22, 2007 | Whirlpool (RH3736XLS) Kitchen Hood
NuTone 36" Allure Range Hood WS1 Series Replacement Aftermarket Ducted Logo
Top NuTone Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a NuTone Kitchen Range Expert? Answer questions, earn points and help others
