Question about Samsung V20 XTC 1800 Notebook
Mouse touch pad dont work
I opened my laptop and now my touchpad dont work. There is a white cable with a blue tip that came loose but i dont know how or where it goes.
  • shaq18ataq Jan 20, 2009
    Outside???? The cable is attached to under the touchpad. The loose cable is the one that should be attached to the motherboard. I figured out where the cable (think its called a ribbon cable) should go but the touchpad still dont work. Not sure if i connected it the right side up.
  • Anonymous Mar 29, 2014
    I'm using a mouse on my notepad so want to disable my touchpad.
Where is this white cable coming from? Is it inside the laptop or outside?
Posted on Jan 19, 2009
Disable touchpad - usb mouse is installed and working
Either your driver for touch pad is missing or flex cable of your touch pad is disconnected. Check in Device Manager if your driver for touch pad is there, if that part is fine then you have to open your touch pad and reconnect the flex cable.
Mar 01, 2015 | Computers & Internet
How does a touchpad work on laptops
a touchpad works off the static electrical charge that resides all living tissue as far as I know. if you were to statically charge that piece of metal you are referring to, it would work. as far as why the mouse pointer doesn't jump when you touch a specific spot on the touch pad is because people, in general, don't want it to so the software that controls it has been designed not to.
Jul 06, 2014 | Computers & Internet
My mouse pad in my computer wont work when i tap it
It will depend on what touch pad (and related software) is installed on the particular computer, but you will find the tap option under the Control Panel. Open your control panel, select "Mouse" There will be a TAB in the mouse properties called "touchpad" (surprise, surprise!) where you can toggle tapping on/off.
Hope this helps. PS: if you DONT see the touchpad option - you will first need to install the drivers/software for your touchpad. Most HP touchpads are the Synaptics Touch Pads - Find the drivers here: --> Click here!
Feb 07, 2011 | HP Computers & Internet
Laptop Touch Pad will not work
if you plug usb keyboard onto your laptop it will probably turn the touch pad off.
If no other keyboard is attached there is usually a switch to turn off the touch pad.
also if you attach a mouse this may disable the touchpad so you dont move the mouse pointer when you are typing
Jul 10, 2010 | Acer Aspire One PC Notebook
My laptop touchpad not working , we can only use the mouse instead
check the connector of you touch pad.. or then lock of that..
Jun 26, 2010 | Acer Extensa 4620 Notebook
Acer aspire 5517 touch pad not working.
Also on this laptop you can hit Fn+F6 to enable or disable the touchpad as well there should be a touchpad disable button to the right of the power button that can be very easy to accidentally press.
Mar 15, 2010 | Acer Aspire 5315 Notebook
Cannot tap touch pad
There is not a whole lot of information that you are giving us. There would be two reasons the touchpad does not work...one, there is a small button above the touchpad and if it is red (orange) the pad is off and you have to tap that button until the light turns blue. If the light is blue, then the tapping part of the pad has been turned off in mouse properties. Open control panel > mouse Properties > device settings > click on settings button and enable tapping. All other touchpad settings are in there to modify also.
Sep 12, 2009 | HP Pavilion dv6000z Notebook
I have an HP laptop with a touch pad mouse that sometimes makes the cursor go all over the screen. When this happens, a small box appears on the tip of the cursor and nothing I do will stop it from making...
you need new touch pad mouse or reseat connectors on motherboard/touchpad, you will have to open computer to do this (not easy if you dont know how to do it)
May 09, 2009 | Toshiba Satellite M35X-S161 Notebook
Laptop touch pad mouse does'nt work while charging
my toch pad dont work when my laptop is charging i have inspiron 1525
Feb 26, 2009 | Dell F3534 Touchpad
Touchpad
When the touch pad stops working it's one of three things. 1- A driver glitch, unistall the touch pad drivers from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers automatically. 2- The touch pad connector has worked loose. Take the palm rest with the touch pad off, disconnect the cable, clean the connectors, and reseat the cable firmly. 3- the touch pad has failed and will need to be replaced. The driver glitch is the most common, I believe that it should take care of the problem. Let me know.
Aug 06, 2008 | Dell Inspiron E1705 Notebook
Samsung V20 XTC 1800 Notebook Logo
145 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
