When I turn the computer on it will turn on and off on and off then when I heat it with a hair dryer for 60 sec it turns on
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
Try trouble shooting with a can of "freeze it" (spray coolant available at Radio Shack) while it is warm and working. Spray small areas of the PC board and see if it goes off. Repeat to confirm once you narrow it down. Sounds like a bad component, loose connection, or cold solder joint. But this means you have to have some knowledge of removing parts to expose the PC Board, etc. And also knowledge of doing proper repairs once the fault is located. If not, leave it to a professional or you may cause more damage.
Posted on Jan 04, 2013
I got the damm over My sony Vaio S series laptop, I'v cleaned several times, but it is shown again, (my building is so old), how can I clean the damm forever?
Best way I have found to dry out a computer is to use a hair dryer on the lowest setting or no heat and blow it carefully into the vents on the laptop. I have done this successfully on Toshiba and VAIO laptops I used on my boat. Just be careful not to get the hair dryer too close to any plastic to avoid melt damage but on lowest heat or no heat setting that should not be a big issue.
Dec 06, 2014 | Sony VAIO SVS15116FXB 15.5" Windows 7 Home...
How do I know when the thermal fuse for my whirlpool deut electric dryer is bad?
Take it out. check it with a multimeter set on ohms. Get a hair dryer turn it on hotest setting. with meter leads on each end of the thermal fuse have someone hold the hair dryer blowing hot air on fuse. It should show continuity through it when cold. After heat is applied it should show 0 or infinity. If its working properly move on to over temp switch.
Sep 02, 2014 | Whirlpool GEW9250 Electric Dryer
Casio not turning on
Hi Danny,
is it correct battery.
please check if it is good.
leave it a half an hour wit case opening or heat it with 10-20 secs with hair dryer and try again with good battery,
regards,
nuwan
Jan 16, 2014 | Casio FX9750GII Graphic Calculator
I HAVE 60 ' INCH FATBACK WHILE THE TV TURNS ON THE SCREEN THAT TELLS YOU , SETTINGS , STAYS ON UNTIL IT WARMS UP ....YOU GO TO YOUR REMOTE AND HIT MENU , IT DISAPEARS....BUT ONLY WHILE ITS WARM .
Got a heat related issue likely on main signal board---might be able to localize it (suspect a flat pack chip) with a hair dryer to heat the board just a bit.
Nov 05, 2012 | Televison & Video
The dryer starts, it fires. But after like 30 to 60 sec. burner shuts off. All filters and exhaust are checked.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 27, 2010 | Maytag Atlantis MDG8400AW Gas Dryer
I have a Westinghouse DG400JXW1 gas dryer. The burner ignites on initial start. After approx. 60 sec. it shuts off. 60 sec. later the igniter comes on but the burner does not ignite. This repeats itself...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 25, 2010 | Dryers
The dryer runs about 10 seconds then shut off. It
Maytag gas dryer , runs for about 15 sec. heats up , then completly shuts off , Checked thermal fuse & it was blown , replaced & it ran for about 15 sec again & blew fuse again ....help .
Apr 26, 2010 | Maytag PYE3300 Dryer
My rca d52w26 turns on for 5 minutes then shuts off let it sit for 20 minutes it turns on for another 5 any ideas
Try to cleaning it from inside first thing without switching it on as sometimes power is stored for upto 30 -60 secs (POWER SWITCHED OFF)- maybe alot of dust is gathered & messing with circuits, use a hair dryer or a cloth - then switch it on.
if it doesnt work then it maybe a fualty transformer - its difficult to know without doing a few checks.
good luck
Sher
Oct 20, 2009 | RCA Televison & Video
2000 RCA REAR PROJECTION TV WONT TURN ON
You are going to have to have a repair person come look at it, If its the same problem we are having. But for now you can take a hair dryer to the back of the tv heat up the back on the left hand side then try turning it on. Is it a 52'? Thats what im doing. And lots other people on this site. Very common problem with this tv from what I can see. But try the hair dryer and call a repair shop.
Jan 17, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
My AC
One might think so, YES the compressor is running till it gets hot and tripps on hi-temperature, and after it cools down awhile, the switch willcautomatically reset itself and back- & forth......Thank-you-very much!
Jul 25, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
