Question about SNK Magnavox 15MF227B 15 in. LCD TV
TV repeatedly turns off after starting until it's warmed up
When you turn on the TV it will turn off several times in the first 5 minutes before it stabilizes and stays on. Each time it turns off, it has a different symptom. Symptoms include: Sometimes will begin with a VERY loud fuzzing sound (two different fuzz sounds) just prior to shutting down. Screen also distorts when this happens. Sometimes will shut down silently. Sometimes will shut down and automatically restart. Sometimes will shut down and stay off. Sometimes will shut down, auto restart, but freeze and require removal of the plug to restart the unit.
moorah1
  • 181 Answers
SOURCE: magnavox plasma tv model 42mf230a/37 sound but ni
Replace lower scan converter PCB, which plugged into Y-Sustainer Board, located to the left of the display if you poke back cover open. There are 2 of them, but in some models might be the one, long PCB.don't wait to fix it! otherwise, you will knock out Y-
Sustainer and upper scan converter. That will cause you to spend few hundreds to fix it.
Good luck,
Alex's TV Service,
Philadelphia,
Pa, 215-806-5980.
Posted on Jan 21, 2010
  • 736 Answers
SOURCE: My magnavox 42mf438b lcd tv will be fine for about
that set is highly rated by users .. it first came out in early 2009 (i think) so you might check to see if any warranty remains ... the display is illuminated by several lamps .. each lamp has its own high voltage inverter .. all the innverters are powered by an output of the low voltage power supply (often 18 volts)... i would suspect a problem with that low voltage power supply.. either a bad capacitor or a thermal issue .. .. ..
Posted on Apr 10, 2010
  • 84 Answers
SOURCE: Out of the blue, our TV screen has decided to go
There is a part called a projector in your tv, it projects images, sometimes it expires or gets finicky, i would recommend replacing that part.
Posted on Jul 17, 2010
  • 6 Answers
SOURCE: The tv picture is going out. It turns off and on
Chinese piece of ****. It is what the USA deserves.
Posted on Jul 22, 2010
budmrtn
  • 11361 Answers
SOURCE: My magnavox 42mf230a lcd tv
The 24vdc power supply may be going out due to bad DC filter caps, look for bad caps with leaking/bulging tops first (notes: bad caps can look normal too).
Then check the backlight inverter board to see any sign of burnt parts. Please try my guide below.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make a kit for you.
Posted on Aug 14, 2010
Toyota Corrolla 1995. The heater does not work, I replaced the thermostat and have put a lot of antifreeze.
bleed cooling system, probably there is air trapped in the heater core preventing warm coolant to circulate into the heater core. try this
1 open radiator cap fill coolant and put heater in hi heat
2 start engine and wait until you see the coolant start to circulate
3 squeeze hose several times watching if coolant volume decrease
4 add more coolant and repeat 3 until coolant volume stays same or start overflowing.
5 check if heater giving off warm air or repeat 3 and 4 until warm air blows on heater.
or find the coolant bleeder screw, do 1 and 2
open bleeder screw until coolant come out, do this several times until no air comes out when opening bleeder screw, fill coolant in radiator.
Dec 11, 2013 | Cars & Trucks
KF50XBR800 Rear projection LCD TV on and then standby
from how long you have this problem? and what made it start?
do u remember the cause?
Dec 28, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Will not start until engine turns over several times
Check fuel pressure, ignition spark, and compression and report findings.
Aug 04, 2012 | 1986 Pontiac Fiero
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
Jun 03, 2011 | Innovage Jumbo Remote Control
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
How to set time of day clock on 2007 1200n
Turn the key to ACC,
press the button on back of speedo several times until time is displayed,
press and hold for 5 sec, 12HR begins to blink,
press and release to switch between time formats,
press and hold for 5 sec, hours will blink,
press and release repeatedly to set hrs,
press and hold for 5 sec to get blinking minutes,
set minutes similar way,
press and hold for 5 sec to save, when minutes stop blinking the time is set,
turn the key to off.
Jul 27, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
My tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Apr 24, 2009 | Televison & Video
SNK Magnavox 15MF227B 15 in. LCD TV Logo
23 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
