Question about Breville BCG800XL Grinder
Not grinding on fine
Grinder will only grind on coarse
2 Suggested Answers
SOURCE: Hi. On the Breville CG10 coffee grinder, is the
Yes, 1 is finest and 9 is coarsest.
From the manual: 8 - 9 Percolators 4.5 - 6 Espresso Machines - Steam System 3.5 - 5 Drip filter coffee makers 2.5 - 4 Espresso machines - pump system 1.5 - 2.5 Espresso machines - semi automatic pump system
Posted on Dec 28, 2010
Talea ring the grinder will not stop gringing
The Talea model is with a Ceramic grinder system. This can happen when the grinder outlet is clogged with coffee grounds. Fresh beans cannot enter the grinder as the outlet is clogged. Remember, the grinder in any machine is a grinder. It does not shovel the coffee grounds out and clean the outlet when it is clogged.
1- Check if the grind setting is too fine (powder like). If so change the setting to coarse. Fully automatic machines do not need fine grind. Keep the grind fineness like the table slat grain.
2- Check if the beans are dark roast and oily. Oily beans are a slow poison for any fully automatic machine. Change the beans to Non oily medium roast type.
Oct 16, 2014 | Saeco Talea Ring Plus Espresso Machine
My mazzer coffee grinder brings out medium to almost a whole bean grinds ,,,am trying to get a fine grind(for the espresso) but it's not working ,,, i've tried to move the scale to all the numbers but the...
Lets do this, remove the bean hopper, and make sure there are no beans in the burr chamber. Then looking down at the collar with the numbers back up screw if there is one on it. Now if memory serves me right clockwise is coarse and counter is fine. Look down in the burr chamber, notice the nut in the middle, turn it with your fingers that will move the bottom burr, if burr turns freely we will move on if not plug in grinder and let it grind out remaining beans. With beans gone unplug grinder, then turn collar towards fine until you cannot go no more, now try turning nut it will be hard if not impossible to move, turn collar towards coarse until you can barely move bottom burr with fingers, you will hear and feel the burrs touching, that will be our bottom setting. Now pick a spot on the grinder you can use the small notch in the middle, count out 16 notches towards coarse and turn collar to that point. Use the notches around the collar not the ones on the top next to the numbers. Your grind should be almost perfect, depending on blend and machine you might have to adjust 1 notch to the left or right after testing.
Aug 11, 2010 | Mazzer Coffee-grinder SUPER JOLLY Electric
Cleaned the Solis Maestro grinder and re set it to a fine espresso setting but the grind is coming out very course. What should i do?
Hi Your burr is not locked in. You need to remove the beans from the hopper. Remove the hopper. Remove the burr. Turn the grinder upside down over the trash can. Put the burr back in only make sure that the burr is down. Install the bean hopper and when you turn the bean hopper it should move the burr. Then you can adjust your grind. Make sure that the grinder is running is your going to a finer grind or you could break the grinder. You can turn it to a coarse grind any time.
Jan 12, 2010 | Solis Maestro G385 Electric Burr Grinder
Does not grind evenly When I try to grid a coarse grind for french press coffee I get a lot of small grinds.
I was a little confused at first but where ir says coarse on the adjustment "wheel" is actually the fine setting. If you want coarse you need to turn it the opisite direction. If you look cloosely you will notice there is an arrow beside where it says coarse pointing to the right and beside where it says fine there is an arrow pointing left. It kind of makes no sense, but I guess since they've been making it for like 70 years they figure why fix it. I hope this helps, I had the same problem the first time I used mine, and the manual doesn't really mention it.
Nov 04, 2009 | KitchenAid A-9 Electric Burr Grinder
Saeco Italia coffee too weak - grindes too coarse
Remove beans from chamber, then remove the 2-3 screws in the chamber, then lift hopper slightly and turn adjustment knob towards the middle number, or halfway between fine and coarse. Then lower hopper make sure the gears line up together, set screws add beans and adjust finer.
Oct 08, 2009 | Starbucks Saeco Italia Digital Barista...
Parts and Grind Selection
The current Kitchenaid A9 burr grinder glass jar is interchangable with the original Hobart/Kitchenaid A9 glass jar; therefor, the gasket should also interchange - contact Kitchenaid customer service to order a gasket.
Setting the grind is accomplished by grasping the body of the ginder in one hand and the grind-selector ring (collar that the jar screws into) in the other. Hold the base tight and turn the selector ring clockwise for a finer grind, counterclockwise for coarser. Be careful not to completely unscrew the selector ring; if you are not sure how much adjustment is left, screw it all the way clockwise until it stops (finest grind); then, back it off, up to one full turn to make the grind coarser.
The selector ring has the words coarse, medium and fine cast into it; these are rough postition markers. There is a triangle cast into the body of the grinder, just above the brand name, that can be used to diral in a preferred level of grind. I use a medium-coarse grind for drip coffee makers; to do likewise, position the selector ring so that the triangle is pointing midway between the words coarse and medium.
Dec 21, 2008 | KitchenAid A-9 Electric Burr Grinder
Grinder setting stops at drip. Can't turn further to espresso.
Another suggestion is while the grinder is off, turn it up side down and rotate the bean hopper from coarse to fine a couple of times. This will clean out grounds that have gotten into the threads and it will prevent the bean hopper from not turning to a finer grind.
If you start to get a clog in your grinder, open it up to a coarse grind for a few seconds. The coarser grind will clean out the chute and then you can turn it down again while it is still grinding.
Dec 15, 2008 | Solis Maestro Electric Burr Grinder
Astra home electric grinder
Turn adjustment ring towards fine, until it cannot move, then back towards coarse about 5 numbers, that should give you a good start on the grind.
May 17, 2008 | Astra Home Grinder Electric
Saeco De Luxe Coarse Grind
You could have knocked it out of its shaft or worse, Cracked the shaft itself.
Settings could be off too, It fairly common. Recheck the chamber, and make sure the plastic casing isn't cracked and the grinder doesn't wabble at all. It should be fairly firm.
If it isn't firm, bad news, cracked shaft.
May 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Coarse Grind
il y a de l'eau qui passe en dessous du plateau avec du café moulu
Breville BCG800XL Grinder Logo
43 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
