harborfreight.com Logo
SKIP SHAW Posted on Jan 04, 2013
Parts for haul master nodel 67597
Parts for haul master electric trailer jack model 67597 i need a pin #18
Have 2001 Sierra 2500 diesel. All lights work on truck and trailer except brake lights on trailer.
Hello. It seems there is an electrical 'break' between the electrical jack of your truck and trailer. This could be the jack itself or a broken wire(s) of the trailer. Good luck and keep me informed; if you want to.
1helpful
Bought a foldable Utility trailer (Haul Master) 1,195# capacity yesterday. Would we be able to purchase the back 4 FT section of frame only? Item # 62648
this is fixya we dont sell products you can try checking for parts with seller or notify haul master themselves
2answers
I have a 7 pin adapter on my truck and my trailer has a 4 pin adapter, i bought a 7-4 pin adapter and my trailer lights still not working properly
Trailer lamps usually have dual filiments in a single bulb, whereas newer cars have sepaprate bulbs for each function. The two different types do not play well together. Go to a good parts store or u-haul dealer and they can provide a logic box that can fix this issue.
1helpful
I hauled a trailer about 40 miles and when I went to leave the clutch pedal went to the floor no resistance and wouldn't disengage clutch master cylinder has fluid throwout bearing has been making noi
It sounds like the throw out bearing separated. You will want to change the clutch and pressure plate when you replace the throw out bearing.
1helpful
2answers
2013 Dodge Caravan,Bought the towing package which includes the 4 pin hook-up for lights,brake lights and signals. Trailer is a12 foot box Pop-up with electric brakes.Problem: Local rec.trailer service...
Perhaps the Chrysler Corporation will not warranty or authorize the 7 pin system for two reasons. 1) The vehicle may not be structurally compatable with a trailer heavy enough to need electric brakes. (This is extremely likely). That means , if you hook up such a vehicle, and something goes wrong, Chrysler does not want to get sued becasue your car wrecked and it was the trailers fault. 2) The 7 pin system includes a "hot" wire from the battery or fuse box or wherever, and the Chrysler makes no such electrical harness on their cars. They also know, if you add such a harness, and it shorts out, they are responsible for any ensuing fires.
That being said, most any company who sells trailers might add the wriing harness and fix you up, but a good way to start would be to go by a "U-Haul" outlet and ask them about it. If they find in their literature they cannot add the 7 pin harness, you may have to find someone who can "cobble" it for you.
Be blessed.
3answers
Caravan trailer wiring
some van don t have a ground wire. hook up to trailer put jumper cables to frame of trailer and van if works install a ground wire plug
Hi, we recently bought a 2010 Honda odyssey and ha...
is the trailer attached to the ball on the van?? could be a ground problem,,run a jumper from hitch to trailer see if that works,,
1helpful
Does an 01 safari with the towing come with an
Towing and hauling usually means it has some options to make it easier to tow or haul. In this cas it will have a hitch and the plug for teailer lights... It will have a few other extras as well maybe even heavier brakes but no electric brake control or wiring in the fron for it. Sorry...
1helpful
2answers
Can't find location for trailer elect hook-up
there is no factory connector you must tap into the existing wiring for brake, turn signals, tail and running lights, they make special adapters to "piggy back" into these wiries, U-Haul trailer rental can do (install and sell) this kit for u very cheap.
3answers
Wiring for a trailer
u must install the fuses for the system in he underhood heavy duty fuse box, it will be marked trailer tow
Top harborfreight.com Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a harborfreight.com Computer and Internet Expert? Answer questions, earn points and help others
