Question about ViewSonic PJ557D Projector
Have a Viewsonic PJ557D projector. Red "lamp" light came on and no illumination. Bought new new bulb and still the same thing. "Temp" and "Bulb" both blink green and then red, then shuts down. Suggest
  • Joe McDonald Jan 29, 2013
    I tried all the 3 things listed, or at least the first two. No luck. I couldn't get to the menu, since the bulb won't light. I put the new and old bulb in and when I plug it in, the "light" or green "Light" indicator blinks. Then when I engerize it with the switch, the "Light" and the"Temp" indicator light up green, blink a couple of time and it shuts down.
3 Suggested Answers
SOURCE: The lamp continues to flash red lights for power and lamp
I have the same problem as posted too, ordered 3 new lamps and they all still do the same thing. I`m starting to think its the projector that has a problem. Anyone got a solution other then keep buying new lamps and try getting it to work... I mean, after 3, how bad lucky can you be that they are all bad lamps...
Posted on Feb 08, 2010
SOURCE: ceiling mounted PJ551 - lamp light red, power light blinks red
I have PJ 550 exact SAME PROBLEM replaced bulb NOTHING
Posted on Sep 12, 2010
Projector not turning on
seems that the lamp is defective, pls test it
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 25, 2014 | Optoma EP739 Multimedia Projector
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
Mitsubishi HC2 projector
Was the prvious lamp still working?
Jul 16, 2012 | Mitsubishi HC2 Multimedia Projector
I turn on my Viewsonic PJD6251 but the lamp does not come on, and after a few seconds I get 2 red lights TEMP and LAMP. It is new, only 2 weeks I barely used. Good care.
sounds like a bad bulb
projectors get a resistance reading from the bulb and if it doesnt get right value it will give you the double red lights
only other thing it could be is if the fans in projector are not turning on
call viewsonic and tell them issue and make them resolve issue
or
if unit is only 2 weeks old bring it back to store and get replacement or call viewsonic and get them to send you replacement unit - it is too new to mess with it yourself and take chance on voiding warranty
Mar 24, 2011 | ViewSonic PJD6251 Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Lamp and temp lights come on after power up and stay on. Lamp only has 330 hours on it.
OK, that explains it. The bulb you have installed in the projector might be the original bulb that came with the projecoter when it was new. Just becuase it states 334 hours does not mean it is new. In fact, you could have a original bulb with 3000 hrs and reset the hour timer on the projector, which means your 3000 hour bulb might have 3334 hours on it because the person who owned it before you, reset the hour timer.. Best bet, buy a new bulb and reset the hour meter and see what happens. If you have the same problem, then your ballest might needs to be replace which is rare...
May 30, 2009 | ViewSonic PJ400 Multimedia Projector
Dec 04, 2008 | ViewSonic PJ500 Multimedia Projector
Viewsonic PJ550 lamp
Problem 1) The projector should put out a burst of 7000-15000 volts to start the lamp, and then immediately drop down to 60-100 vlts to keep the lamp lit. It sounds like the bulb blowing took out your ballast, or the ballast going out took the bulb (uncontrolled current = overheated bulb = boom)
Problem 2) Thats not a problem at all. HID lighting uses an arc to create light, just like welding creates light. Since it uses an arc, and not the heating of metal, there is no filament to test the resistance of. All the bulb is, is a special mixture of gasses and two very durable electrodes, with a gap in between.
Nov 27, 2008 | ViewSonic PJ550 Multimedia Projector
ViewSonic PJ557D Projector Logo
61 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
