Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Washer (approx. 7 years old) has slow stream when filling
Maytag top loading washer has a slow stream on each side of where the water comes out to fill the tub and it takes about an hour to get the tub filled with water.
  • Anonymous Mar 14, 2014
    TUB CAPACITYS OF MAYTAG WASHER OF OLD
  • 21 Answers
Follow the two inlet hoses from the back of your machine. They should each end at a valve (one for hot and one for cold). Make sure that these valves are all the way counter-clockwise and that the hoses are not kinked or pinched.
Posted on Jan 19, 2009
  • bruceinMD Dec 12, 2010
    Check the fill filers. Remove the hoses from the back of the machine and clean the filters.
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
Water problem
Apr 01, 2009 | Washing Machines
Water fill, discharge and noise problems
to reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
Feb 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore top load washer approx. 10 years old
f7686aa.jpgPump is leaking around the drive shaft.
To get to the pump CLICK HERE
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Stops and starts on warm water fill
Try taking the hoses off the machine and cleaning the screens in the hoses and the screens in the water valve. They get plugged and restrict the flow of water. if these are clean then the sand in your well has damaged the water valve and you must replace it. The part number is 285805 and is around 30 bucks.
Nov 20, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Atlantis MAV6000 Top Load Washer Logo
174 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
