Question about Gear Head WIRELESS keyboard/Mouse
OPENING THE BATTERY COMPARTMENT ON A GEAR HEAD WIRELESS KEYBOARD: I can't get the battery compartment on my keyboard to open in order to replace the batteries. It is a Gearhead wireless keyboard. The battery cover has a hole and a button beneath the hole. I pushed the button and that didn't do anything. I put the point of the scissors in the hole and tried to pry off the cover but it didn't come off easily and I didn't want to break it. What shall I do?
2 Suggested Answers
digecorp
  • 92 Answers
SOURCE: How do I get my Gear Head Wireless Keyboard shut down.
It has no off function. It uses little to no power when in stand-by (Not in use). It even has an auto off function after a delay. Just replace the batteries when they run out.
Posted on Apr 12, 2010
Testimonial: "Thanks-so is 3-4 months for batteries normal?"
Nexxtech keyboard 800 728 2. Opening battery compartment
try using a small percision flat blade screw driver....find side with dimple use screwdriver and push outter piece in toward the middle and lift ..
Aug 13, 2016 | NexxTech Computers & Internet
How do I change the battery of the keyboard
The battery compartment slides open. Try using a putty knife in the joint of the cover and housing to pry it open. Be patient getting it into the joint and twist it.
Wireless Keypad for Garage Door
Dec 11, 2014 | Building Materials
My keyboard. Won't charge.help
Are you sure it's rechargeable? Most wireless keyboards use standard alkaline penlight batteries, either AA or AAA size, which last about a year (some more, some less). Open the battery compartment on the keyboard and replace them. Or do you have a wired unit with a cable that runs from the keyboard to the computer? If so, check the connection to make sure it's plugged in properly.
Oct 31, 2014 | Computers & Internet
How do I open battery case on HP wireless keyboard
Please attach photos for your keyboard to make it easy to he
May 22, 2014 | HP Computers & Internet
How do i open dv7-1451nr?
Instructions
Shut the Pavilion dv7 down and close the screen. After unplugging all cables from the computer, turn it over and remove the battery.
Unscrew the six Phillips-head screws holding the large T-shaped panel to the bottom of the Pavilion dv7. Remove the panel and set it aside.
Remove the keyboard locking screw--marked by a keyboard-shaped icon--from the top part of the compartment exposed when you removed the T-shaped panel. Reserve the screw.
Remove the black Phillips-head screw from next to the wireless adapter inside the T-shaped compartment. This screw holds the Pavilion dv7 optical drive in place.
5
Pull the Pavilion dv7 optical drive gently out of its bay, and then remove the two Phillips-head screws from inside the empty drive bay. Reserve the screws.
6
Remove the Phillips-head screw next to the circular intake fan vent in the corner of the Pavilion dv7.
7
Remove the five Phillips-head screws from inside the empty battery compartment. You should now have removed 16 screws in all. Turn the Pavilion dv7 over and open the screen.
8
Insert a spudger or other flat plastic tool into the seam between the speaker grille and computer casing on the right side of the Pavilion dv7. Gently pry up to begin removing the speaker grille from the computer. As you do this, move the spudger to a new location to pry different areas until the grille is completely disconnected. Mind the ribbon cable connecting the center of the speaker grille to the logic board, and do not lift the grille any higher from the computer than the cable allows.
9
Push both sides of the speaker grille cable lock forward until the cable slides easily out of the logic board connector. Set the speaker grille aside.
10
Remove the four Phillips-head retaining screws above the top row of the Pavilion dv7 keyboard. Lift the keyboard up and forward, and place it face-down on the palm rest.
11
Unlock the Pavilion dv7 keyboard cable connector using the same method as for the speaker grille connector. Slide the cable out of the connector, remove the keyboard and set it aside.
12
Place the new Pavilion dv7 keyboard upside-down on the palm rest. Slide the keyboard into the connector, close the lock and rotate the keyboard down into the computer. Replace the four Phillips-head screws.
13
Slide the speaker grille cable into the connector and close the cable lock. Push the speaker grille into its original position above the Pavilion dv7 keyboard. Press gently on all parts of the speaker grille until it is flush with the computer casing.
14
Close the screen and turn the computer over. Replace the five screws inside the battery compartment, the screw next to the intake fan vent, the two screws inside the empty optical drive bay and the screw inside the T-shaped compartment.
15
Replace the t-shaped panel on the bottom of the Pavilion dv7 and its six screws.
16
Slide the optical drive back into its bay and replace the securing screw.
Jan 10, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
How do I remove and replace the cmos battery A135 toshiba
If you have idea about it ......but this link can help you ...in this.. check it.....http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
Please rate and vote if you found this one helpful
Thanks
Sanjay Kumar
Apr 25, 2011 | Computers & Internet
Hp g60-630us how to remove keyboard
1) Remove ALL electrical sources.
AC adapter and Battery. Leave the Battery Compartment Door off.
2) Laptop closed turn it over, battery compartment facing Away from you.
3) Looking at the inside edge of the Battery Compartment that is towards you, there are 3 screws to remove.
They are right along the edge that faces you.
There is one in the middle, and one on the right side, that are down in a little indention. (A small drop in the case)
There is one to the left.
Philips head screws. Remove them, place them in a multi-compartment container, and mark the compartment for where they came from.
(DO NOT mix the screws up that you are going to remove)
4) Turn the laptop over, open it.
Carefully lift the Front of the Keyboard up to an angle. (The Front of the Keyboard faces the LCD screen)
DO NOT lift it straight up.
There are plastic tabs that protrude from the back of the Keyboard, and go into the Keyboard Cover.
(The dark rectangular shaped piece of plastic that surrounds the Keyboard, and ends at the Palm Rest, is the Keyboard Cover)
Ease the Keyboard forward towards the LCD screen. Lay it down next to the LCD screen, and on the Keyboard Cover.
You want to be able to access the Keyboard cable's connector.
The Keyboard cable connector is the white connector in the middle, with the ribbon cable leading from it to the Keyboard.
This is a ZIF connector.
Zero Insertion Force.
The ZIF connector is made of two parts. It opens, but does NOT separate into two parts.
The white tabs you see on either side are eased towards the LCD screen.
Use your fingernails.
Push on one 'ear' a little, then go to the other side. Keep alternating back, and forth until the ZIF connector is open. It only opens up about 1/4 inch.
This action opens the ZIF connector, where the flat ribbon cable can be eased out of it.
(To reinstall, line the ribbon cable up in the connector, Insert it until it stops, then squeeze the white 'ears' towards the front of the laptop. {Towards you)
Use EXTREME care when opening, and closing the ZIF connector. If you break it you have to replace the motherboard.
Remove the Keyboard.
Regards
joecoolvette
Nov 01, 2010 | HP G60630US Notebook
How do you open mouse to change battery
You have to first find the compartments for the batteries on both the mouse and keyboard. Most likely they will be on the bottom of each device and only held shut by a latch. Sometimes on mice there is a button that you will have to push in order to have the compartment open up.
Sep 07, 2010 | Dell Wireless Keyboard Optical Mouse w0147
My battery is down wireless mouse. Does it also
Battery compartment on the bottom of the mouse and beneath the keyboard.
Dec 17, 2009 | Logitech Wireless Access Duo Optical...
How to replace screen on Pavilion dv7-1040us. is diferent from other hps I have replaced, cannot figure out how to remove it.
Here it is! Have fun!
  1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
  2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Lift the LCD panel out of the display panel enclosure.
LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
  1. Place the LCD panel into the display panel enclosure.
  2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery2_bing.gif.
  1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
  3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
    Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  4. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  5. Place the wireless LAN Minicard in a static dissipative bag.
Before you begin: Remove the battery.
  3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
  7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
  2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
  9. Tighten the two captive P1 Phillips-head screws.
Dec 09, 2009 | HP Pavilion dv7-1240us Notebook
Gear Head WIRELESS keyboard/Mouse Logo
23 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
brian soufane
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
