Question about LG 42LC2D 42 in. LCD HDTV
LCD-TV with no coaxial input
I have a Olevia 19" LCD-TV (monumental waste of money, by the way) w/o a coaxial input. The TV is the 2nd on a dual-tv cable box, and so the only cable available to hookup is coaxial. I finally got it to work by using the AV Show 242 modulator. This device was such an unbelievable hassle to program, that I vowed that someday I'd find a better way. That day has come - one year later and the module has stopped working! Any ideas will be greatly appreciated!
    Brigadier General:
  • 8,619 Answers
Hi!
You need to buy a RF Coaxial to 3RCA converter to use it with your tv. You can buy it from---
http://www.antonline.com/p_42089-NX_490612.htm
or from
http://www.nextag.com/Cables-to-Go-RAPIDRUN-603107488/prices-html?nxtg=239a0a24051c-A4A551EB842EC678
Thanks
Rylee
Posted on Jan 19, 2009
    Scholar:
  • 62 Answers
Ambry which advertises a "Coax Cable TV to RCA Video Audio Demodulator" for $80.
Another possible solution is for the two different inputs on coax is put 1 of them straight into the tv via the coax connector, the other coax cable would go thru a VCR. Most VCR\'s are usually equipped with RCA outputs (the better ones have both right (red) and a white (left) sound connectors), all have the Yellow (video) output. The cheaper ones have just the video and 1 output which with a combiner adapter cable will give a simulated stereo to the tv. At least that way the tv can be programmed for certain channels, you switch the tv\'s inputs via the remote control to the input source (the vcr) and use the vcr\'s remote to get the other channels, assuming you programmed the vcr correctly. Try it you might like it!
Hope this helps.Good Luck.-->
    Sergeant:
  • 378 Answers
You cannot use RG 59 coax to input the monitor - except for an antenna connection. You really should place the tv near the vcr and dvd player so that cables that come with the units can be used.
I don't recommend converting the rg coax to signal coax as they are totally different capacitance. And you should not run outputs from a dvd player or vcr for more than about 10 feet unless you use special rf amplifiers to prevent losses.
    Genius:
  • 2,920 Answers
Take it nd have a coax hookup installed on it so you can hook up direct...im not sure what else you can do
  • LG Master
  • 19,396 Answers
Coax signal is analog. The only way to connect it to one of the inputs you have on this TV was using a converter , like the one you have.
The alternative is replacing the cable box.
    Scholar:
  • 160 Answers
It should be loose connection of the cable just check it.also remove the cable and reinsert.or also can be the problem of module internal connections needs to be checked.
Where is the coaxial output on the LT-2722 twenty-seven inch LCD TV from Norcent
Many new TV's do not have a standard coaxial input anymore. The industry has moved on from that and you might have to get an external tuner to get an input like that. I found an old review from 2006 and it shows the antenna input on the bottom side where the power cord plugs in. http://www.geek.com/xyzcomputing/norcent-lt-2722-27-inch-lcd-tv-571351/
Jul 07, 2016 | Televison & Video
I have a Olevia LCD HD TV that has no sound no picture n vertical colored lines??? Any answers or suggestions or is this tv DONE??!!
we unless you spend money on it to repair it is done for sure .what do you have as an input , antenna or cable or satellite service
Jan 22, 2015 | Olevia Televison & Video
Olevia 37" LCD TV will
my olevia a 232 s12 2nd hand tv . gift from a relative wont power on .just had the blue light on.i was able to reset my 32 inch olevia by pressing and holding down the power button much like a computer to reboot.might work for you.
Aug 20, 2011 | Olevia LT32HVM 32 in. LCD Television
How do you hook recorder up to tv and dvr cable box
Simple. Connect the composite output from the VCR to the composite input on the back of the Presidian. Then connect the coaxial output from the back of the DVR to the coaxial input on the back of the Presidian. Then connect the coaxial output from Presidian to the coaxial input on the back of the TV. Turn everything on and enjoy! :-)
Jan 05, 2011 | Dual Presidian DVD Recorder
I have a customer on the phone who has a olevia flat screen and can not locate an input for his cable wire. where are they located?
here are the only signal inputs located at the back of the tv.
1 x HDMI input ( 19 pin HDMI Type A )
2 x component video input ( RCA phono x 3 )
1 x VGA input ( 15 pin HD D-Sub (HD-15) )
Audio line-in ( RCA phono x 2 )
2 x S-Video input ( 4 pin mini-DIN )
2 x composite video/audio input ( RCA phono x 3 )
1 x headphones ( mini-phone stereo 3.5 mm )
1 x SPDIF output ( TOS Link )
1 x audio line-out ( RCA phono x 2 )
1 x subwoofer output ( RCA phono )
1 x serial
If you are looking for a coaxial cable input.. it is actually not available so you have to connect a converter from coax cable to RCA cable for you to connect it on your tv.
Jun 04, 2010 | Olevia 237T 37 in. LCD TV
How to hook updvd player to tv set
if the dvd player has hdmi connection use that.
if the TV has hdmi input use that.
if you can do both of these then use the TV remote to switch input to hdmi when the dvd player is on.
as an extra you can use toslink optical or coaxial digital cable from TV to home theater receiver for surround sound.
Jan 02, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Insignia NS-LCD19 is not producing a picture
You might need to change the input on the TV. I'm almost certain that it will have a DVI and Coaxial input among others.
Check the monitor for an input button or pull up the menu and see if there is different input selector.
Oct 13, 2009 | Insignia NS-LCD19 19 in. LCD TV
I have an Olevia 23t lct hd tv. I am plugged in
you said you are using composite cables..? that means you have some kind of cable box ? if you want to get HD channels you have to use a HD box that is supplied by the cable company.. the HD cable box then has to connect to the tv with component cables (green,blue, red cables) or HDMI cable.. to send the HD signal to the television.
May 13, 2009 | Olevia 237T 37 in. LCD TV
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
LG 42LC2D 42 in. LCD HDTV Logo
947 people viewed this question
Computer Repairing
Computer Repairing
