Question about Dell Inspiron 1501 Notebook
Computer screen messed up after connecting to a Projector.
I plugged up a VGA cable from this laptop to a LCD RCA Flat Screen tv and for a while it worked fine, but today when I changed the Mode back to Computer Only and unplugged the cable and turned it off. When I turned it back on the computer screen was totally messed up. Broken screen with horizontal lines all around, couldn't click anything or read anything. It's totally messed up. Now when I plug it back into the VGA cable even if it's in Computer Only mode, it works perfectly fine. Any solutions?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 210 Answers
Sounds like your screen resolution has gotten changed. Plug your VGA cable in and reset it to 1024x768. Then with the laptop on remove the VGA cable. When you connect your laptop to other devices like that, make sure you are not setting the resolution to the same as the TV.
Posted on Aug 25, 2013
5 Suggested Answers
Screwy1010
  • 10 Answers
SOURCE: Dell Inspiron 6000 to TV
On a dell laptop, the key combo FN  F8 cycles through the display options. Laptop screen, External screen, Laptop and External screen at the same time.  Try pressing the FN F8 key to get the video to display on both laptop and lcd and the same time.  If that doesn't work you can also change the settings on what the laptop does when the lid is closed.  Check the power settings in the control panel.
Posted on Dec 31, 2008
Kuwagata
  • 181 Answers
SOURCE: Vertical lines on my lcd laptop screen
It's the connector problems.
If you know what to do, I can guide you:
First, remove the screw all over the LCD case, then you can see the connector, and flexible cables.
Second, remove the keyboard unit(by removing all screw on the unit), after removed, find the edge of the LCD cables, then you can see the connector.
The solution:
1.Try clean this two connector with soft brushes ( paint brush is good ), by removing the cable first,then clean the flexible connector using wet tissue ( use the alcohol ).
2. If still exist, you need to replace the flexible with new ones.
Posted on Feb 26, 2010
  • 998 Answers
SOURCE: Dell 1545 laptop with white
If the display works fine when connected to external screen via VGA connector then then the problem is either with the LCD display panel ( which consists of the display panel and inverter ) or the LCD cable that connects the LCD to the motherboard. You could try to re-seat the cable connection on the back of the LCD panel.
Posted on Aug 01, 2011
  • 105 Answers
SOURCE: no image on projector screen from laptop VGA connection
On most laptops you have to select Function F8 to direct output to the projector or the projector and the laptop display.
Posted on May 07, 2012
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
Can't display from computer to tv
You need to connect the HDMI cable between the computer and the TV. If your computer has no HDMI, you can connect the VGA cable to your TV VGA input. If the TV has no VGA input but has a composite RGB RCA receptacles, then get a adapter cable that has VGA on one end and 3 RGB RCA plugs on the other end.
Jan 18, 2014 | Digimate DGL3201 32" LCD TV
I have a Laptop and an Acoustic Solutions Tv. But what i want to know is how to connect my laptop to the tv? What cables do i need? My laptop has the vga connection but the back of my tv will. i...
I believe the number that you have sent me is the serial number, Your TV should have a name and model #. For example (Sony Bravia model #00000) Yours would be RCA ? #?. The model number should be on the back of the TV. Is the TV an LCD flat screen? If it is and is fairly new it will have a special place to plug a PC into it. With the model name and number of your TV I can look for the manual and lok at the connection set up for your model.
Dec 28, 2010 | Televison & Video
LCD VGA Display goes on and off.
Check refresh rate and setting for external display output. It won't work with unsuitable screen resolution, color depth or refresh rate. Check all three points and I believe you can troubleshoot the problem this way.
Jun 02, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
Connecting wire between pc to tv
Depending on what type of TV you have, connecting your PC to your TV shouldn't be very expensive. Most newer models of TVs come with a VGA input.
Your computer has a cable to go to the computer screen, this cable is known a s a VGA cable, it looks like this:
Your TV might have a VGA input which looks like this:
All you have to do is unplug your VGA cable from your computer screen and plug it in to your TV so your cable will go fro your computer to your TV instead of your computer to your screen.
If your TV doesn't have a VGA input, it will have an RCA input which looks like this:
You can buy a VGA to RCA cable which will allow you to connect your computer to your TV which looks like this:
You can buy a VGA cable here:Click Here
You can buy a VGA to RCA cable here: Click Here
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Feb 19, 2010 | LG 22LH20 LCD TV
Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
Jun 26, 2009 | HP Pavilion DV6500Z Notebook
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Jan 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Connecting Laptop to LCD
VGA cable doesn't carry any audio: use your audio output from PC into TV audio Input (standard RCA).
You need to configure your Display Properties to manage TV screen to get an effective connection.
Either you have a generic Video Grafic Driver add on (I'm using Intel Graphic accelerator) on your display properties either you are using a specific (NVIDIA) driver for your video card.
To check go to CP/ Display, settings Tab and in advanced you should be able to check your choice (if you don't want to go to user manual.
You can also (in CP/ Display, Settings tab configure TV as a monitor and select your option accordingly: use screen resolution on screen # 2 not over native resolution of your VIZIO screen (1080 x 960?) and be sure to use all the parameters as TV can accept.
As soon as TV is configured as per resolution and refresh etc..
check the presentation function on your PC: it's normally a FN key showing a screen icon on key top (on my Acer travelmate is FN + F5) on aspire may be it's FN + F4.
This function key will circle between: PC mail screen -> External screen (as you configured on Display settings) -> both screen.
Jan 04, 2009 | Acer Aspire 3680 Laptop
Projector to laptop
Your post:
  • cords/cables - would depend on what are the available OUTputs from your laptop. Some examples are DVI, 15pin VGA, S-Video and the single yellow RCA;
  • where - would depend on where you are, the DVI and/or 15pin VGA cable would be available from most computer shops, the S-Video and the RCA from most electronic, audio/video stores.
  • how to do it - would depend on the brand & model of your laptop. Normally it would be a combination of the Fn key + F? to enable the external video. Cycling through would yield, LCD only, LCD + external, external only. The F? would be dependent on what laptop you have. Connection wise, it would be a matter of connecting the appropriate cable to match the available output connector of the laptop to a matching INput connector of the Optoma projector;
  • Additionally, depending on the model of the Optoma (more specifically its resolution), it may be to your advantage to initially lower the screen resolution and screen refresh rate of the laptop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 20, 2008 | Optoma MovieTime DV10 Multimedia Projector
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
Dell Inspiron 1501 Notebook Logo
322 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
