I have tried using the alba lcd22advd as a monitor for my pc but can't view the whole picture on the screen. how do I adjust it so that I can see the whole desktop page?
The icons & toolbar are are at the edge of the screen, not visible so I can't see anything to adjust through the pc
  • elaine Lawrence Jan 07, 2013
    Many thanks for your suggetions. I can now view the whole screen (by ajdusting the tv to PC screen mode) and the wallpaper is very clear also but the text is blurred. Both on the icons and in word for example. Any ideas? I have tried adjusting zoom, pixels etc but so foar nothing has solved it. Thanks
  • Brian Sullivan
    Brian Sullivan Jan 07, 2013
    These icons what are they ? if you right click on the icon you will see options
  • 27,725 Answers
You might need to fit screen . Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system. Also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal , larger or custom settings
always click APPLY after making any changes. Right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add to the Toolbar File Edit View Favorites Tools and Help On the top of the internet page you should see some tabs file edit view favorites tools and help Click on the view tab on the drop down list you should see a zoom % and full screen option. Click a different percentage also a text you might try a different text although this will not increase the of the page only the text fonts inside it
There might be a menu button on the monitor where you can adjust reduce / expand the screen s usually located on the underside of the monitor of course this will depend on your brand of monitor.
Hope this helps.
Posted on Jan 05, 2013
SkullyFox
  • 93 Answers
SOURCE: graphic card problem? monitor?
sounds liek graphics card is shoy, i had very similar problem, changing the video card worked a treat, its not a Inno3D is it?
Posted on Dec 11, 2007
rahul26485
  • 611 Answers
SOURCE: Heavy white lines accross the screen
change the ram and viedo card agian
Posted on Jun 07, 2008
SOURCE: Monitor will not start up!!
سلاموو..
يوجد لدي"acer T310" المشكلة الي فيه...نسيت الفلاش ديسك مشبوك فيه...ولمن أعدت تشغيله طلب مني أضغط على "F1" لحفظ التغيرات .... وأنا طبعاً فصلت الفلاش ديسك بدون ماأضغط ال"F1" وأعدت التشغيل.....هنا ظهرت المشكلة..لم تظهر الشاشة.
طبعاً حاولت أفصل الرام عشان أسمع إذا بيجيب صوت إنه الرام مش موجودة ....لكن ما جاب صوت نهائياً...
ومش قادر أحدث ال"BIOS" لأنه ما يدخل على ال"DOS" نهائياً...
فيا ريت من معاه حل لايبخل عليا ويرسل لي على البريد الموضوع تحت..لاننا صدق زعلان على خسارة الجهاز..
وشكراً على إهتمامكم بنا...أخوكم ....كمال حيدر
البريد هو/ aboulshamiz@yahoo.com
ولكم جزيل الشكر والإمتنان
Posted on Nov 30, 2008
SOURCE: Wallpaper only, no icons or programs available for use or viewing
extending ur desktop means creating an extra monitor-space to strech ur desktop width, which means you can actually see your mouse pointer waving throught both screens when u slide it. If you want to have the same display on monitor 2 as with monitor 1, you should choose the option 'clone' to display identical items on two screens. If the option is not available in your software then maybe you can download a third party software from download.com or something to have it done.
Posted on May 29, 2009
  • 2069 Answers
SOURCE: Dimension 9200 PC Desktop: monitor stays in safe mode and won't let me see an...
check your vga settings. you could restart it in vga mode first.
Posted on May 20, 2010
My alba lcd22advd keeps flickering while on fav channel
check for a dry joints at the inverter board for the screen back light, which may have loose contact.
Aug 10, 2012 | Alba LDVD1538WDCH LCD TV
Alba model LCD22ADVD not recognising DVD's. Message
Either a dirty or a bad optical pickup unit in the player---if bad it will have to be replaced and usually cheaper to buy a new set.
May 21, 2012 | LG Televison & Video
I have a 19in Emerson Flat Screen TV that I am using as a PC Monitor and it isn't using the full screen. How do I fix it to use the whole screen?
You might not be able to. If the screen size doesn't adjust with the wide/view mode/picture format button on the television remote control you have to change the resolution on the pc. You right click on an empty spot on the desktop, choose properties, and then choose the settings tab. A lower resolution will cause the image to fill the screen but the icons get really big. The image isn't as refined. However you may be able to play around with it enough to find a good enough resolution and a view mode with the Emerson remote that will work out for you (a combination of the two).
May 31, 2011 | Televison & Video
Lcd22advd need unlocking code
9,7,3,5 in DVD mode then press 0. Worked for me!
Sep 27, 2010 | Alba DVD-108 DVD Player
I'm using this as an additional monitor for a HP 10" netbook and the picture is stretched & distorted & doesn't fill screen. The vertical adjustment just moves the whole thing up and remains...
Solution goes this way, to maintain the aspect ratio of the monitor, take note of this. Your HP 10inch notebook have different resolution compare to your additional monitor, But I'm sure you selected the dual view mode or the duplicate mode that is why you have distorted display on your additional monitor, to let the additional monitor decide and maximize its resolution, try using the extended view option, you can change the resolution of your additional monitor without affecting the resolution of your 10 inch laptop.
Oct 21, 2009 | Acer X183HB Monitor
How do I reduce the size of the picture on my PC monitor
try going to page on the top right corner click on that and then click on zoom and make sure the zoom is set on 100%
May 18, 2009 | Sova DSV32P112 32 in. LCD Television
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
