Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Convergence problem, how to fix with my remote?
I had my convergence checked and the repair guy solved it by using the remote and it appeared he new a code. Can this be shared with me so I do not need to call him back any help is appreciated.
  • adamswifeh Jan 22, 2009
    Thank you blueextc 3221
  • 15,935 Answers
There is a secret service menu to converge the Sony KP53HS30.
Caution: Be careful, there are many settings that can be tampered with. Some may be hard to undo.
Procedure: (use the remote control for these steps unless noted)
1. Turn TV off with System Off (under flap on remote)
2. Press: Display, 5, Volume +, then Power. If successful, service text will appear on the screen.
3. Use 2 & 5 to select the PJE Category.
4. Press 9 to get to fine convergence adjusting.
5. Press 6 several times to get the convergence screen of choice. I like the grid.
6. Use the remote's arrow keys (joystick), move the brackets around until you have found the area to adjust. Press the center of the joystick to change the bracket from white to a color. Use the joystick to adjust the color. Press 3 to change color to adjust. When done, press center of joystick again.
Note: Try to keep the grid even and squared up.
7. Repeat steps 5 and/or 6 for all parts of the screen that need it.
8. Once done, you need to save your settings. Press: Mute, Enter. Then on the TV, press "Flash Focus"
9. Turn off power.
TV is ready to use.
Posted on Jan 19, 2009
Convergence option dropped from menu on rca tv
thats a very easy repair if you can solder Replace FL231, DL231 and CL230 then resolder the flyback that will solve the issue. You can get the Kit called ITC222 and ITC222a Convergence option missing repair kit from www.tvrepairworld.com which has the replacement parts and the CD with repair instructions.
Jan 01, 2012 | RCA HD52W56 52" Rear Projection HDTV
VS-60719 60 in. Rear Projection Television: Blue Convergence is off, can't solve by using the ...
When the convergence problems happen.100% ur tv convergence board the 2 STK convergence ICS,and some or all it resistors are dead.These parts must be change,to be solved convergence problerms.Tries Websites like TvrepairWorld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.Only if u know how to do soldering,and have soldering equipments and solders.The shop will cost u $300-350 for the parts and labors.
May 18, 2010 | Mitsubishi VS-60719 60" Rear Projection...
TV appears blurry, and when using the remote to solve remote and buttons on tv are not allowing to re adjust colors for a clear pictue
It sounds like you're describing a problem with the convergence being out of adjustment. You have lost the power supply to the convergence amplifier, therefore the microprocessor isn't detecting that the circuit exists, and isn't offering it as a choice in the adjustment menu. There can be LOTS of reasons why that is, but none of them are one that you can repair sucessfully or safely. The problem is definately a power supply related issue that you should have a professional repair.
Good luck.
Nov 26, 2009 | RCA HD52W56 52" Rear Projection HDTV
Different Kind of Convergence Problem - RCA 52 inch
The FL231 fuse is dead.There 3 retangles squares the one in the midle is dead near the right side of the FBT high voltage transformer.the big plastic block with a red wire hook a cap to ur CRT.
Sep 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My philips 46PP8621 is cloudy and any white in the picture is so bright, i need shades. I cant fix it. It is unwatchable. Please help!!!!
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 15, 2009 | Philips Televison & Video
My magnonox is cloudy too!
You guys are awesome! I picked up one of your kits and fixed my TV in less than 1 hour. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Jun 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
SONY TV PROBLEM
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 03, 2009 | Sony KP-46WT500 46" Rear Projection...
Warped screen, double images
  • Screen looks 3D
Apr 26, 2008 | Sony KP-51WS510 51" Rear Projection...
Panasonic PT51HX41E Colors are all messed up
You need to change the convergence ic's IC7001,IC7002 = part# STK392-110. Also check for any burnt or discolored resistors nearby. (about a $350 - $500 repair)
Aug 20, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
378 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
