Question about Pass & Seymour Electrical Supplies
DIMMER#103-220-3 WILL THIS DIMMER WORK WITH DIMMABLE LED LIGHTING
  • 83 Answers
No it will not.
Posted on Oct 07, 2017
4 Suggested Answers
  • 87 Answers
SOURCE: flickering
#1 cause is a bad lamp,try changing that 1st, 2nd if they are two lamp fixtues you ballast could be going bad/or is. Another solution could be you have a loose common/neutral which is normally the white wire @ the light itself of if it is junctioned @ your switch. I would check those items befor spending the money for a new switch. hope this helps.
Posted on Oct 03, 2009
  • 760 Answers
SOURCE: using this dimmer on an outlet that has dimmable
Yes this is not unusual. Any triac conrol device must have a load large enough to turn it off. I have some switches operating compact flourescnts that do the same thing. My cure was to add one incandescent lamp on same switch, and my load devices work fine too.
Posted on Aug 10, 2010
info30036
SOURCE: if the legrand dimmer 400w - pro21 can function
We also had problems with dimming LED light bulbs until we found these bulbs at LED Lighting Wholesale. Check them out!
http://www.ledlightingwholesale.com/c/64/par-20-dimmable-light-bulbs-led-lighting-wholesale-par20
Posted on Jun 02, 2012
Defiant motion security light. When I installed dimmable LED flood light, it no longer goes dim as it did previously
That is probably because LED lamps draw very low current compared with incandescent lamps and a standard dimmer requires a load to work correctly..
Nov 07, 2017 | Office Equipment & Supplies
My led lights start to strobe when I turn on exterior light that is fed from the same line circuit. Solution?
There are two things coming into play here; the lamps and the dimmer(s).
First; LED and CFL type lamps that are to be used on a dimmer switch - must be identified for that use. Looks for the word dimmable on the packaging or bulb itself. These lamps are generally a little more expensive than their non-dimmable counterparts. If it does not indicate it is dimmable, then it isn't - and should not be installed on a circuit controlled by a dimmer switch.
Second; a dimmer switch that will be used to control LED and CFL bulbs (that are identified for use with a dimmer) must also be identified for use with dimmable LED and CFL bulbs. Again, these dimmer switches will be identified for this use and will cost more than those that work with standard filament type bulbs.
Lutron has dimmers for your circuit called a "C•L™ Dimmer" and supports Incandescent / Halogen, Dimmable Compact Fluorescent (CFL) and Dimmable Light Emitting Diodes (LED) type lamps. have a look here:
Lutron Maestro Dimmer and Switch Models
Also, be wary of the total load (wattage) of the lamps being controlled. If you have multiple dimmers in the same box, derating of the switch's wattage capacity (due to increased heat) will be required.
Dec 03, 2015 | Maestro Electrical Supplies
I have 2 led transforms connected to a toggle switch. Can I put a toggle dimmer 600W controlling these transforms?
That depends on several things. Some LED power supplies are not dimmable, and will flash instead of dim properly when used with a dimmer. Many will work just fine. There are also specialty dimmers that are designed to work with transformers, though I've not found them much different.
Oct 30, 2015 | Electrical Supplies
Can I use a dimmer switch with light bulbs whose packaging makes no mention of whether or not the bulb is "dimmable"? (be they incandescent, CFL or LED)
Most old dimmer switches do not work with energy saving/led bulbs, they will work fine with the old style filament bulbs, the newer dimmer switches will be compatible with energy saving bulbs and will indicate on the packaging!
Dec 27, 2014 | Electrical Supplies
Viking range hood dimmer switch
Sorry we have no part locating services here at this website.
Apr 17, 2017 | Kitchen Ranges
If the legrand dimmer 400w - pro21 can function with led dimmable light "philips master led spot "
The answer is NO. You need a Trailing Edge dimmer to control LEDs.
The Phillips master LED spot manual says
Lighting controls: bulbs are dimmable 20-100% with ""select"" Trailing Edge RC devices
http://www.prismaecat.lighting.philips.com/FredhopperPDFWebServiceInter/docts/1d8ea75f-e889-424d-92dc-450fbeb85f6a/Smart_LED_Spot_da.pdf
The Legrand pro21 manual does not say anything about being a Trailing edge dimmer.
http://www.legrand.com.gr/gr/gr/liblocal/internet_greece/PDFS/NOTICES/IOBL/ROOSTATES/775637EN.pdf
Legrand diagrams show what appears to be incandescent bulbs, and say nothing about LEDs
LEDs cannot be dimmed as ordinary incandescent (tungsten) bulb.
More reading:
Wikipedia article on dimmers includes technical stuff on Trailing edge dimmers
http://en.wikipedia.org/wiki/Dimmer
2 sites show LEDs bulbs that dim:: both seem new ...
http://news.thomasnet.com/fullstory/LED-Bulbs-feature-smooth-dimming-range-566574
http://www.earthled.com/lumiselect-dimmable-led-light-bulbs.html
Oct 11, 2010 | Legrand On-Q/ ALC 600W Dimmer Switch,...
Electrical Supplies Logo
280 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
Mike Squire
Mike
Gil Shultz
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
