Question about Lincoln Welding Tools
I got a miller suitcase hooked to my lincoln ranger 250 gxt to use flux in my suitcase do i need to use the work lead as a grould like a mig dose
    Problem Solver:
  • 11 Answers
Yes
Posted on Jan 20, 2013
luxur4
  • 92 Answers
SOURCE: lincoln mig welder
Check the earth clamp, make sure all the cables or in good condition and secured, if the unit is three phase, get an electrition the ensure all the phased are functioning. test the fuses with a meter, get back to me if all is OK
Posted on Jan 23, 2009
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
CarlGehrke
  • 169 Answers
SOURCE: Wire feed not working Miller 250 mig welder
If the knob spins all the way around (and especially of it didn't always do that), it's broken. This could mean that the nut that holds the rheostat in place has come loose, or it could be that the wiper inside the rheostat has broken off the shaft. To find the voltage measurements, correct schematics, etc, I'd need to know the serial number of your welder.
Regards,
Carl
Posted on Feb 23, 2009
  • 23 Answers
SOURCE: no gas flow
You never mentioned switching the polarity, this must be done when switching between wire types, Connect polarity appropriately, for steel use dual mix carbon dioxide/argon and set flow to 25-30 and give it shot. Good Luck!
Posted on Apr 22, 2009
  • 225 Answers
SOURCE: what is the 250 class mig welder to buy the miller
I was warrenty repair shop for lincoln, esab ,miller, hobart,and clark for five years .my expereance with lincoln as far as customer sevice they dropped the ball alot,miller on the other hand had great cusomer service.My opinion the miller family is the way to go for dependability,parts,and service.
Posted on Jul 12, 2009
Ranger 10,000 has low weld output and ac output
This is not a simple question. Take this magnificent machine to a service shop.
Aug 25, 2014 | Lincoln Electric Ranger 250 GXT AC/DC Arc...
Lincoln ranger 250 will not shut off
Without more info I say it is a short in the switch. If not the switch trace out the wires and look for a bare spot.
Bryan
Mar 30, 2014 | Lincoln Ranger 250 Gxt Welder Generator...
Auto feed stopped
check fuses first, then Check the 24 volt relay for function. If it makes contact, the problem is likely the SCRs on the control board have failed.
Feb 07, 2012 | Lincoln Ranger 250 Gxt Welder Generator...
My machine will not drop idle when just running
Hi:
There are only three problems that can cause the idle speed to stay in high:1) The idler switch is on high position. Switch it back to the middle.2) Machine is on auxiliary power. Switch it to panel position.3) You have a faulty PC board or idler solenoid. Need to see a repair man.Good LuckDavid
Dec 15, 2011 | Lincoln Ranger 250 Gxt Welder Generator...
It will strike an arc but has no power to burn a rod doesnt matter how small new or old rod is.only has 150 hrs on it
it sounds as though there is a fault with the rectifier. In which case you'd need to take it to a repair shop to get it repaired properly
May 29, 2011 | Lincoln Ranger 250 Gxt Welder Generator...
How do you hook a miller s-22p8 wire feeder to a lincoln ranger 10,000 plus engine driven welder?
you can't, the S-22P8 it's not a volt sensing wire feeder, it requires 24V or 115 with an adapter. FOr CV machines only.
Dec 08, 2010 | Miller Electric Mfg Co 903376 Deltaweld...
Welding Tools Logo
103 people viewed this question
Top Lincoln Welding Tools Experts
joe2639
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
