Question about LG 47 in. Flat-Panel LCD HDTV
LG 48" tv works, but (this function is not available now.) keep flashing while on. No function buttons on tv or remote work!
SOURCE: LG 37LC7D remote doesn't work
 I heard that Best Buy is still selling these models despite this known problem- I am trying to have mione fixed but was told the replacement part is on back order until DECEMBER!
Posted on Oct 31, 2007
jerryg50
  • 1667 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
  • 235 Answers
SOURCE: Remote not working on my LG 37LC2D
Try replacing batteries and reprogramming both remotes.
Posted on Jul 05, 2009
omaharox
  • 165 Answers
SOURCE: "Function Not Available" error on LG 47LG50 LCD TV
A software upgrade may resolve the issue if not the main Pcb. would need replacement.
Contact LG during normal business hour 8-6 central time.
1 800 243-0000
They may help you out also let them know if you are having a lipsync issue.....Wink wink
Posted on Jan 20, 2010
SOURCE: LG TV keeps flashing This function is not available now.
unplug the TV. hold down the power button for 30 seconds. plug the TV in.
this worked for me :)
Posted on Jun 29, 2010
Hi i need to find a sky plus code 47lh300-za for this LG TV can you help?
Hello
Setup codes for LG TV with Sky are:
065 244 405 318 037 398 191 459 245 389 060 275
065
742
743
726
508
584
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4*Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5* Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Jul 21, 2011 | LG 47LH3000 LCD TV
Sky remote control code needed for lg tv - model 37lk450
Hello
Setup codes for LG TV with Sky remote are:
065
742
743
726
508
584
1*Select any channel on the TV.
2*Point your Sky+ remote control away from the TV and press the tv button.
3*Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button. If this works try the other TV functions.
Please note:- in der to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
Jul 16, 2011 | Televison & Video
I have a Samsung LN40c530F1F and I accidentally pressed the button below the power button labeled "DVD receiver/TV" and now nothing works at all on the remote. I have tried re-pressing the...
Take the battery out like about hour for a hard resetting.After putting the battery back in u should push the button that said TV only.The remote should be functions again for the tv again.
Jun 18, 2011 | Samsung LN40C530 TV
Do you know the sky+ remote code? So I can operate the volume control on the sky+ remote. I've tried loads already hope you can help.
It would help to know the model number of your LG TV. However, you can try the generic codes for LG which I've listed here:
Rev 8 remote: 1293, 1206, 0206, 0065, 0904
Rev 6 remote: 0065, 0742, 0502, 0672, 0634, 0136,
Rev 4 remote: Same as Rev 6
RC1600/00 remote: codes not available and unlikely to work with your TV
** Your Sky remote version can be found on a sticker inside the battery compartment. **
Try these codes but if they don't work, please post back with your TV model number. It's possible that your remote does not have a code which will work with your TV, in which case, you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due but I've not been able to confirm this yet.
Hope this helps - please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | LG Televison & Video
I have just purchased an LG32lcd 450 tv, I cannot get the handset on Sky to work as they do not have a code to do this as the tv is new to the market, can you please help with this
OK, as you already discovered there is no specific code for your remote. You can try the generic codes for LG which I've listed below. Your TV may use the same flash patterns as some other older LG TVs so these codes might work.
Try these codes but if they don't work it's unlikely your remote will work with your TV - you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due - which will hopefully contain a specific code/flash pattern for your TV - but I've not been able to confirm this yet.
Nov 23, 2010 | LG Televison & Video
WHAT SHOULD THE RETURN/EXIT BUTTON DO ON MY REMOTE IT ONLY SEEMS
If you look on page 48 & 49 of your LG TV’s user manual, you will see your TV remote and a description of the buttons.
Your particular remote does not have a previous channel button or function. That backwards arrow button is to return one step in an interactive application or other user interaction functions.
However, if you get the full size LG TV remote it does have a “FLASHBK” button that will go to the prior channel. Some programmable TV remotes have this feature too.
You can go to the TV store and ask to use the larger LG TV remote that has the “FLASHBK” button on your TV on display to see if your TV will perform that function.
Good luck.
May 21, 2010 | LG 42LH200C LCD TV
On/Off Button on TV not working, constant flashing message
www.lg.com/us/tv-audio-video/pdf/47LG50_spec_sheet.pdf
http://elektrotanya.com/lg_lcd_tv_la84a_mfl41370007_47lg50-ua.pdf/download.html
Above user manual top, below is your service manual, perform the troubleshooting procedures and you should be able to localise your problem.
May 13, 2010 | LG 47LG50 47 in. LCD HDTV
Apr 06, 2010 | LG 42LC2D 42 in. LCD HDTV
LG REMOTE WONT SWITCH FROM AM/FM TO DVD
HI THERE, I FIXED THE PROBLEM MYSELF BY KEEPING THE FUNCTION BUTTON ON THE DVD PLAYER PRESSED UNTIL IT FLASHED ""MODE"". THEN I PRESSED IT IN SEQUENCE TILL IT CAME UP WITH DVD/TV THEN IT AUTOMATICALLY SWITCHED OVER TO THE DVD FUNCTION MODE. ALL DONE. BUT THE TV/DVD BUTTON ON REMOTE STILL ISNT FUNCTIONING OR CROSSING OVER CHANNELL. HAVE TO DO IT MANUALLY VIA DVD PLAYER. EVERYTHING ELSE WORKING EXCELLENT. THANKS ANYWAY. HOPE THIS INFORMATION WILL BE OF USE TO YOU IN THE FUTURE. I CUD CHARGE YOU FOR THIS INFORMATION BUT I WONT THIS TIME.... LOL. MERRY CHRISTMAS AND GUDBYE...
Dec 13, 2008 | LG Televison & Video
LG 47 in. Flat-Panel LCD HDTV Logo
51 people viewed this question
Computer Repairing
Computer Repairing
