Question about Anuman Interactive Home Budgets for Dummies (25648) for PC
Software issue When installing software I get the following message HBFD.exe has stopped responding.
  • 7 more comments
  • weetodd Feb 19, 2008
    I am trying to install "Home Budget for Dummies" on Vista. I get the following error: "Requires Help System 4.73 or higher." I tried using the compatability wizard and using Win2000 and got the "HBFD.EXE has stopped working" error, so I dowloaded the MDAC file from microsoft as suggested, to no avail.
  • Anonymous Jun 27, 2008
    need 4.73 help system or better
    for home budget for dummies
    thank you/
  • Anonymous Jul 31, 2008
    it is not working with vista
  • Royals85 Sep 13, 2008
    I am trying to install "Home Budget for Dummies" on Vista. I get the following error: "Requires Help System 4.73 or higher. I tried the MDAC solution and it didn't work. Running VISTA 64 bit.....
  • cct776606 Nov 05, 2008
  • Anonymous Dec 28, 2008
    Same problem, needing 4.73 help system or higher.
  • apsbhandari Jan 28, 2009
    Can not run Home Budget for Dummies on Vista but runs fine on XP
  • Anonymous Feb 09, 2009
    Same problem, tried everything
  • Anonymous Apr 27, 2009
    same problem!! no solution??
Install MDAC 2.8. (http://www.microsoft.com/downloads/details.aspx?FamilyID=6c050fe3-c795-4b7d-b037-185d0506396c&DisplayLang=en) There's no need to uninstall anything - just put it straight over the top of the current MDAC install. good luck
Posted on Jun 27, 2007
I have a program(taskhost.exe) which I can't close, and is preventing me from logging off, or shut down my PC
Taskhost.exe is part of windows. killing shouldn't affect anything critical. It's function is to run script that need to run at certaint times. low priority stuff. Recomend you run antivirus and anti malware software. also run windows update. those 3 things tend to find the majority of issues. then open your control panel and look through the add programs section and see if anything has been installed that you don't want. Many time programs install other programs that will cause your computer to have issues.
Feb 09, 2014 | Computers & Internet
Usb error
To resolve this issue perform the following:
  1. Click the Browse button on the error message.
  2. Browse through the CD to Drivers -> windows 2000_XP .
  3. Select the file hppcp504.cab , and click OK .
  4. The error message "The Software that you are trying to install has not passed the windows Logo Test " appears. Click Continue Anyway .
  5. If the error message "hpc20155.xml on HP LaserJet P2015 Series CD is needed " appears again, follow steps 1-3.
  6. The required files are copied, and the driver is installed and ready to use.
If the issue still persists then perform the following in the order listed before trying to reinstall the software.
  1. Go to Start -> Control Panel -> System -> Hardware -> Windows Update.
  2. Set the option to Never search Windows Update for drivers .
NOTE: It is important to re-enable the Windows Update function after installing the printer software, otherwise the updates for all the other software on this computer will be blocked. After disabling Windows Update, complete the following steps. Be sure to reenable Windows update after installing the software:
  1. Disconnect the USB cable and remove the device listing from Device Manager
  2. Go to Start ->All programs ->HP ->P2015 ->Uninstall , "OR" Go to Add & Remove and check for the P2015 and uninstall .
  3. Then go to Printer & Faxes . Select the HP LJ P2015 icon and press the Delete button on the keyboard. After deleting the printer icon, go to File and Server properties . Go to Drivers tab and remove any P2015 drivers if listed.
  4. Also delete the following files/ folders C:\program files\HP\toolbox Fx or P2015 C:\documents & settings\app data\tool box Fx
  5. Run the scrubber.exe . Find this on the cd X:\utils\ccc\scrubber.exe & scrubber.ini NOTE: The Scrubber utility can also be downloaded from the web if the original installation CD is not available. However, it is only available as part of the full software installation package named hp_LJ_P2015_Full_Solution_AMWE.exe on hp.com . Once the files are extracted to a folder just open the util folder then the ccc folder and the scrubber.exe file will be visible.
  6. Paste these files at the following path and run the scrubber.exe C:\windows\system32\
  7. Empty the recycle bin
  8. Turn the printer back on.
  9. Now install the printer software again. Connect the communication cable to the PC and printer when prompted during the installation.
Jul 23, 2010 | HP LaserJet P2015 Printer
My dell all in one AI920 does not scan. the button is not respondiong neither can I get it to respond from the desk top.I keep getting a message which says dlbkaiiox.exe-entry point not found. how can i...
That message is telling you that you have a software problem, try removing the associated program that goes with that exe, and re-install/repair install it again. To find the program search for that exe and it should be in the programs directory.
Jan 27, 2010 | Office Equipment & Supplies
I cant find hpc20155.xml
This is direct from the HP website. some files were renamed... it works!
ISSUE: During the LaserJet P2015 Series USB installation, the following error message is displayed: 'hpc20155.xml' on HP LaserJet P2015 Series CD is needed SOLUTION: The HP LaserJet P2015 EWS driver on Microsoft Windows Update and Windows Market Place Web sites is newer than the driver that is included on the product CD that shipped with the printer. Because of this. the Microsoft Windows (Found New Hardware Wizard) will install the driver from the web. Some file names are inconsistent between driver version 1.0.0.12 and version 1.0.0.10, including the hpc20155.xml file, hence the attempt for the driver to search for the hpc20155.xml file will fail, and prompts the error message. To resolve this issue perform the following:
Sep 07, 2009 | Office Equipment & Supplies
Aioc.exe
What you need to change is your screen resolution to either 800 x 600 or to 1024 x 768 (in your desktop settings)
What is happening is that your Lexmark all-in-one center doesn't think your monitor can handle the program (or something to that effect).
You will NOT have to restart your computer either.
Just restart your Lexmark All-In-One program and you can start scanning.
Aug 25, 2008 | Lexmark X7350 All-In-One Printer
Lost my installation CD and downloaded the software from HP but doesn't work
ok..
remove the old software first
then get another fresh set of drivers, make certain that your operating system has the latest service pack installed.
re install the drivers
try it again
Jun 24, 2008 | HP DeskJet 3940 InkJet Photo Printer
Legacy
Please try the following:
Click Start >> Run >>
Type the follow command in the Open box.
"net.exe stop wuauserv" (w/o quotes)
Press Ok
Repeat the same for the following commands:
regsvr32.exe wuapi.dll
regsvr32.exe wups.dll
regsvr32.exe wuaueng.dll
regsvr32.exe wucltui.dll
regsvr32.exe MSXML3.dll
regsvr32.exe qmgr.dll
regsvr32.exe qmgrprxy.dll
net.exe start wuauserv
Restart the machine and try again.
May 01, 2008 | Computers & Internet
Xp error message
Try the following:
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Navigate to and delete the following entries:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc2k5" = "C:\WINDOWS\SVIQ.EXE"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"Fun" = "C:\WINDOWS\system\Fun.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc" = "C:\WINDOWS\dc.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"run" = "C:\WINDOWS\system32\config\Win.exe"
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\"Shell" = "Explorer.exe C:\WINDOWS\system32\WinSit.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"load" = "C:\WINDOWS\inf\Other.exe"
  5. Exit the Registry Editor.
Nov 10, 2007 | Microsoft Windows XP Home Edition
Qx5 is not responding
the microscope may be trying to draw too much current from your USB ports, your computer will disable the device if it does this. When this happens one of the easiest (and cheapest) solutions is to acquire a Powered USB Hub (with it's own Plug top power supply). This should aleviate any extraneous current draw to the Power supply.
Apr 28, 2007 | Digital Blue QX5 Microscope
Anuman Interactive Home Budgets for Dummies (25648) for PC Logo
554 people viewed this question
Top Anuman Interactive Computers & Internet Experts
Alun Cox
Are you an Anuman Interactive Computer and Internet Expert? Answer questions, earn points and help others
