Question about Steel Series Steelseries 5H V2 Headset
Right earphone dosen t work
Recently i don t heard sound on right earphone but on the left is everthing ok
The sound from the left output device dosen't work
I would also first switch left and right to check the cables
Feb 20, 2013 | Simmons SD7PK Electronic Drum Set
No sound
- Did it work before, or have you never heard the voice of this toy ?
- No sound from the loudspeaker, AND from the earphone plug ?
- if yes, have you tried uninstalling the sound driver (in the Device Manager, Multimedia Audio Controller), and reinstalling it (it should sit in c:\util2\drivers\sound - if not you'll find it there :
http://toughbookcentral.com/panasonic-cf-18-drivers/)
- if not (sound OK from the earphone), perhaps you have change the RAM on your device (for this you need to unplug the loudspeaker), and incorrectly reseated the small sound connector ?
Dec 19, 2011 | Panasonic Computers & Internet
Hello there, i've recently bought a terratec aureon 5.1 pci sound card and the sound work fine but my mic doesn't. its not muted or anything and i enable the right mic aswell but it still doesnt...
depending on which operating system you are using this will vary
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it or
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
hope this help you
Aug 18, 2011 | TerraTec Electronic Aureon 5.1 PCI Sound...
Absolutely no sound from the computer at all and yet the sound test says everything is working properely... have gone on the net to try to fix with no luck
did you check to see if the speakers are muted, Go to the little speaker icon in the tray (toward the right), left click on it and open the "mixer", you should be able to see if the sound is muted there. If it isn't muted, try plugging in some earphone and play some music or something you know works on your computer. If you hear sound from the earphones, then you know your sound fuction is ok and that the problem may be the spearkers ( if this is a laptop, you could still have a spearer problem, but more difficult to fix) hope this helps.
Mar 14, 2011 | Dell Computers & Internet
The sound is coming out perfectly in the right earphone but it is barely coming out in the left earphone
Then you need to adjust the earphones plug in, adjust it gently and it will sound right on both earphone. It is the plug that is causing the problem. Adjusting it will solve the problem for you.
Jan 11, 2011 | ILuv Audio Players & Recorders
Left earphone has lower volume than right
Maybe you can try adjusting the plug, or the wire within the left earphone is rusted, or change the sound effects on a computer.
May 03, 2010 | Philips Audio Players & Recorders
Headphone problem
Hi there and welcome at Fixya, the support team (lfete)
Please try with another pair of earphones and see if it works :O)
If it works with the another earphones, then you have to check yours :
1.See if the cable and connectors are ok
2.Try to move the cable a little bit all the way (you can move it up and down)
3.Then be sure that it is inserted the whole way in, some times you can connect the earphone nearly in to the product, that means one of the right/left side will not play.
If is still not working please return here again
Hope it helps
Have a nice time over there
Please rate my answer
Mar 12, 2010 | Audio Players & Recorders
Sound from 1 side only!
your ear input female jack is stripped try another new pair of earphones if not you may have to take it in for service.
Nov 05, 2009 | SanDisk Sansa E280 MP3 Player
Earphones right side won't play...
I inserted a drill bit that fits the exact size of the aperture and twisted it around a few turns and it is working better.
Heath Robinson eat your heart out
Jun 07, 2009 | Audio Players & Recorders
Steel Series Steelseries 5H V2 Headset Logo
18 people viewed this question
Top Steel Series Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Steel Series Radio Communication Expert? Answer questions, earn points and help others
