Question about Fantom Vacums Lighting Canister Vacuum
Where would I find a replacement power head with brushes
Occasionally there are power surges in the power head which causes the brushes to stop, but the main vacuum continues to work. Brushes are also worn down after all these years. Can I replace just the power head and if so, where would I find a new part.
  • Fantom Vacums Master
  • 18,408 Answers
2 Suggested Answers
RJones1125
  • 373 Answers
SOURCE: How do i replace the belt in the Fantom Cyclone XT vacuum
remove the covers over the headlights and under the shiny foul. there are two screws. there are two tabs that hold down the cover over the wheels, they just pop on/off with a click.
on my xt. i had to remove the rolling brush and clean out all the hair that was stuck in the bearings. remove the screw holding down the motor and belt. pry out the roller brush to get to the bearings. there was some serious hair ball in there.
reassembled mine and it works perfectly now :)
Posted on Feb 18, 2009
Kirby G4 was surging, then a flash of light and a pop from outlet!
the surge is caused by a faultering armture, might be caused by low carbons or sticking carbons, strip the motor down for inspection. Or take it to your local kirby service centre shop for clean and service and polish. price range from 39 to 59
Jul 07, 2017 | Kirby Vacuums
What should I check to trouble shoot a Eureka 6865 smart vac making very loud whirring noise? Filter and bag are clean. Hose is unblocked.
Hi, it's Jim from Crucial Vacuum!
I'd say at this point if you've checked your bag, filter and hoses it may be time to check your brush roll and belt. These two fast moving parts, when loose, damaged or just in need of replacement may occasionally give off an odd noise.
Turn the power wand over to expose the base plate that covers the brush roller. The power wand can get dirty and collect debris in the brush roller over time. The grinding noise may be something stuck in the brush roller, causing it to hit the edges when the vacuum is operating. Removing obstructions and cleaning dirt and debris collected over time should allow the vacuum to operate quieter. Unscrew the base plate cover with a Phillips head screwdriver. Lift out the brush roller and belt. Cut away any obstructions, such as string, hair or rubber bands, from the brush roller. Wipe the brush roller and belt with a damp rag to remove any dirt and allow them to air-dry. Wipe down the brush roller housing and inside the base plate with the damp rag. Any noticeable difference now once it's dried and turned on?
Should you need any replacement parts for your Eureka in the future please feel free to order direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Check out our lineup of Eureka replacement parts at the below link.
http://www.crucialvacuum.com/catalogsearch/result/?cat=27&q=Eureka+6865
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Oct 19, 2014 | Vacuums
Dyson dc 24 brush works intermittently
Broken wires in the side of the machine
Dec 27, 2013 | Dyson Vacuums
Hi Chris, it's Jack at Dyson.
DC24's brush bar is designed to shut itself off for protection if something jams it. Please follow the steps shown in the video attached to remove any threads or hair from the brush bar and end cap, and to check the cleaner head for any obstructions. Once you've done this you should be able to reset the machine.
If you'd like further advice from our experts after you've given this a try, please call the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA). If a repair or a replacement part is needed, we'll be happy to confirm if this is covered under your machine's 5-year warranty.
You can also find help and support by visiting www.dyson.com and clicking 'Support'.
Power head brush wont run
Could have a loos belt, check and replace if necessary.
Nov 23, 2013 | Vacuums
The main brush head on my Dyson Digital Slim will stop turning during vacuuming. I let out on the power trigger, push back in and the brush head will work for a bit and then stop again. My digital slim is...
It's probably due to a build-up of dirt/hair around the brush head or a blockage in the suction head just behind the brush (where the hole is smaller and bends slightly before entering the extension tube. Remove the brush from the head of the machine and also the extension tube between the head and the top of the machine and then gently clear the rectangular hole in the brush compartment with something flexible (maybe a piece of wire or a pipe-cleaner) depending on how bad the blockage is. Then remove any hair/strands which may be wrapped around the brush, and any dust in the brush compartment. It may also be a opportune time to wash out the filter which is located just in front of the handle on the upper part of the machine. Leave the filter to dry completely before refitting (in an airing cupboard or near a radiator - may take some hours)
Oct 28, 2013 | Dyson DC35 Handheld Vacuum
Brushes not turning
Is the motor operating when switched to "on " position? Is so I would have to assume that the belt is broken to the power brush /head. Did you happen to smell burning rubber at all when the brushes stopped working? Look in your manual for replacing power head/brushes belt! WalMart sells most types or your local vacuum repair facility.. check the Yellow pages and let your fingers do the walking.. Good luck
Apr 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a Filter Queen Majestic 360 and am having problems with the powerhead. There is a loud rattling noise in the powerhead, especially when I vacuum thicker carpet. I have replaced the motor, roller...
Hi there, as per your information i guess its a problem of power transformer. He can't supply the proper power in the motor & thats why the noise will come from the transformer. Thanks & waiting for your feedback.
Feb 20, 2010 | Filter Queen Majestic Canister Vacuum
Brush won't rotate when pushed forward
I had the same problem . The reason it acts like that is due to the cable that runs from the vacuum motor to the brush assembly has an intermittent open. My fix was to find the small cable that was causing my troubles and splice it. Making sure that I recovered the insulation. Of course my local repair station wanted to replace it for $75 labor plus parts and keep it for 3 days. I took it home and did it in 30 minutes .
Dec 12, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Fantom Vacums Lighting Canister Vacuum Logo
151 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
