Question about Exercise & Fitness
The magnet is missing from my key for the Proform 908cs treadmill where can I get a magnet to fit the key I ordered a key and this key did not come with a magnet
Why do the keys not come with a magnet?
  • 21 Answers
Search fFITNESSREPAIRPARTS.COM for a key. Otherwise any "rare erath" strong magnet should be strong enough to set the sensor off.
Posted on Jan 05, 2013
ButtFuzz
  • 463 Answers
SOURCE: Proform 860 QT doesnt have power
There's a little breaker near the main on/off switch that has tripped. Re-set the breaker. (also check the main on/off switch, typically near where the power cord enters the treadmill...
Posted on Mar 13, 2009
SOURCE: Proform 765 EKG
If I understand correct, the treadmill will not run correct unless you have the safety key in. Well yes this is correct because once the safety key is removed the treadmill will stop. If your treadmill is running extremely fast just by turning it on, you may need a new speed sensor. www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
  • 103 Answers
SOURCE: My Proform 8.5 personal fitness trainer will no longer work
Hello there, It seems that you have a stuck button or a problem with the ifit card area. Yes I know you probably dont use it but just listen. If you have the demo card for the unit try putting the demo card into the ifit slot and press it in and out a couple of times. This will sometimes correct this problem. If that does not correct it then you will need to replace the console or possibly disconnect the ifit section from the console itself. Either way you will need to remove the console.
If more info is needed please leave me a note here and I will get back to you asap.
Good Luck! Tim
Posted on Jan 11, 2010
Testimonial: "Tim, Thank you very much for your help. I already had the console apart so I just unplugged the ifit section and it works perfect. Randy"
SOURCE: i have a pro form performance j4 treadmill. i
It is just plastic. You can wedge a piece into the slot
Posted on Feb 02, 2010
  • 95 Answers
SOURCE: I have a Sportsart treadmill
I would think that it can't hurt anything to try another magnet but if you end up needing to buy another one here is one website that sells them: Sportsart TR20F safety key
Posted on Apr 18, 2011
Cannot turn on proform 380 cs treadmill
1) test the outlet wall with a desklamp, if the lamp turn On THE circuit is o.k otherwise, the problem is fuse blown or c. breaker tripped, reset or replace fuse.
2) test the power cord for open or faulty. with VOM usin continuity
3) test the fuse y/o c.breaker inside of machine and reset or replace.
4) Turn on the machine if the machine keep the same simpton, test the key(magnet) the key is a magnet, test vs your magnet from seal magnet of your refrigerator for atraction or repulsion, if doesnot pass the test replace the magnet from some hardware like home depot.
and PROOF again, can be work. see the block,
Otherwise if the problem keep you must call some tech profesional, maybe you have Main switch open or defective and need replace, or power supply, capacitor, transformer, etc defective. or faulty.
God bless you
Sep 20, 2012 | Proform 380 CS Treadmill !
I lost my safety key for crosswalk advanced 525x. How can I turn it on without the key?
1) I do not recommend to do this. because you must bypass the electronic circuit and you can damage many ICS. if you do not have knowledge in electronic digital. Remember the treadmill fitness is very High Tech machine delicated.
2) will be better go to www. proform.com go to customer service and then parts & manual and order the parts, the best solution.
sincerely.
Jul 12, 2011 | Proform Crosswalk 500 Treadmill
Do you have to have key for proform xt70 to use it?
The short answer is Yes , it will not run without the key being in place. The key lanyard clip are designed to shut down the treadmill should the user fall while using the treadmill to help prevent serious injury. The long answer and I would not advise anyone to do this , but it is possible to take the console apart and bypass the safety switch. I would only do this if I did not have a key and wanted to test to see if the machine worked . Some models can be tested with a round magnet in place of the key others need a plastic card trimmed down to fit the slot .
Hope this helps and remember safety first !!
Dec 25, 2010 | Proform XT70 Shock Treadmill New!
UNIT DOES NOT POWER UP. I CHANGED THE POWER BOARD WITH NO RESULTS. POWER BOARD 120 VOLT LIGHT IS ON. 9 VOLT DC LIGHT IS ON. PWM & TACH LIGHTS ARE NOT LIT. CONSOL DOES NOT LIGHT UP
If its a Icon Health and Fitness branded treadmill (proform,image ,healthrider etc.)The safety key activates the on off switch for the console. (micro switch activated by safety key)Check for 9-12v going to console. Unless it has a magnet switch. What brand and model ?
Sep 11, 2010 | Reebok Acd1 Treadmill Motor Control Board ...
MISSING SAFTY KEY CAN YOU BY PASS TILL REPLACED
ive got given a 625 pro form treadmill and the key is missing i know i can order one but for now i just want to use it is there any way of bypassing the key so i can use it. thanks in advance
Oct 12, 2009 | Proform Quick Burn Pro Treadmill with 12...
Proform 500i not working.
Try putting the treadmil in a cooler location. the heat is effecting the mother board.
Mar 23, 2009 | Proform Crosswalk 500 Treadmill
I have lost the safety key for my Weslo treadmill
Hi I folded up a piece of paper several times to make it into a small rectanguler shape and inserted into the slot for the key and it worked.
The replacement key doesn't need to be magnet just small enough to fit the shap of the slot is fine.Mine was a Weslo cadence 1000 (bought in 2002)
Jan 29, 2009 | Exercise & Fitness
Exercise & Fitness Logo
100 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
